Old Aug 20, 2009, 01:18 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Depends on the current load of the motor. If you go HV you need less motor mass and add a cell extra I noticed on a wm400 fan a 2w20 does get hot when static tested but is plain cold after 4 min wot flight. It has been proven a 120gr motor can run 1200W all day long on HV. Only issue is that the Voltage margin on HV can be quite difficult to predict because of the lower Amp draw/voltage sag. The KV tolerances of a motor may result in a suprisingly wide power range when going HV. I think this is the reason why mf do not want to advertise HV?
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Aug 20, 2009, 01:38 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Erik, I think it's more about having the motor run near it's max efficiency. Often times we over amp 2 pole motors because they have small wire and too many turns to get the kv low enough for us. I just toasted one such motor
Gary, that looks (words I can't say here) !!!
I wouldn't expect that motor to last at much more than 1200 watts, but maybe the aluminum will make a big difference. If it does, then you have a product there with a nice advantage.
Steve C
Steve C is offline Find More Posts by Steve C
Old Aug 20, 2009, 02:29 PM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
Steve C
Steve,
My interest in this EDF was purely by design, without having yet proved it's self to me. (But the tests are coming)
The heat sinking capabiltilites are wonderful, in my opinion. (see below) And the rotor, well..You have that info already.
The motor will have to prove it's self though.
I disassembled the unit (after I assembled it for installation) and got some dims for you guys. Yeah, good long motor. All 57mm of it.
Motor shaft dia.................3.17mm
motor length.......................57mm
motor dia........................28.05mm
motor fairing ID................28.18mm
EDF motor hsg ID.............28.16mm
EDF motor hsgOD.............30.41mm
EDF motor hsg depth............21mm
EDF rotor hsg ID..............68.70mm
A note about heat sinking and motor mounting:
As you can see from the dims above the clearances between the motor and the EDF housing/motor fairing are only are only .004-.005 (0.10mm) per side.
Very Important: When assembling the unit, The thermal transfer compound must not only be applied to the front end cap of the motor, but to the body tube, axially, in ribbons from the front to the rear. Slide the motor fairing on without rotating it. this will allow for air to pass from the front of the motor to the rear. The motor fairing is now a hest sink, as well.
Also note the orientation of the motor wires in relation to the wire slot in the motor fairing. Bending the wires in this fashon will ease assy of the motor fairing. DO NOT rotate the fairing during assy.
See photo below.
After assy, I removed the excess compound with a Q-tip and cleaned up with denatured alch.
Please note the dia of the motor hsg ID, as this may cause fitment problems with other inrrunner motors.
More to come, Gary
One Six Right is offline Find More Posts by One Six Right
Old Aug 20, 2009, 02:55 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
"OOPS....I did it again"
^^^ what's her name?..............
Oh well, just call me 'Brittany'
Gary
Photo of thermal compound is being edited to show the compound applied axially, in ribbons from front of the motor to the rear.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Aug 20, 2009, 04:12 PM
Joined Dec 2003
Hi Steve,
we load our motors in edf always over the mf specs starting with NiCd
If you fry it you pushed it a tad to hard.
Old Aug 20, 2009, 04:29 PM
efflux RC's Avatar
Joined Aug 2009
Another design discovery??
I think this is very important.
I noticed this previously, but dismissed it as a non critical machining difference between the front and the rear of the EDF Housing. There is a step (reduction) in the dia (about .010-.015) at the front of the stators, and continuing to the rear. (That much?..what was I tinking?) I now believe this is intentional, and would add to the efficiency of the unit by reduction of the (already minimal) Rotor/Housing gap. I also noted that the rear of the Rotor can be mounted very close to the step without any rotational interference.
For what it's worth, me likey.
Site Sponsor
Old Aug 20, 2009, 04:53 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Did you run it yet ....where can one buy that heat transfer compound?
AIR SALLY is offline Find More Posts by AIR SALLY
Old Aug 20, 2009, 05:15 PM
efflux RC's Avatar
Joined Aug 2009
I just ran it a half thottle, while temporarily mounted in the jet. My Thrust Fixture is still waiting completion. So I have to run it in the jet. Sounds sweet at half. I'm currently positioning all components for CG balance before I can mount the fan permanently. final assy and run up is next. The alum definatlety displaces the heat as the EDF is warm, and the Motor fairing is warmer. I ran it on a FP 30c 4500 4s.
Actual flight test and Eagle Tree data will be on FP 30c 3200 4s, because I have two of them.
You can get the compound from Mcmaster Carr, Rodger. If you want I'll post a link later.
"AOS Heat Sink Compound"... 2oz tube
I bought it a while back but I believe this one had the highest conductivity rating of the ones on the site. price..?
Please note that a quantity of the compound will be supplied with the pre ordered EDF/motor units. from the mfgr.
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Aug 20, 2009, 06:26 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Hey Gary,
Can I confirm shaft size.....Now don't get excited.
Is it 3mm or 3.2 as is becoming the 70mm standard??
Ciao J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Aug 20, 2009, 07:39 PM
efflux RC's Avatar
Joined Aug 2009
James it is 3.17mm. I'll correct it above. Thanks.
Site Sponsor
Old Aug 20, 2009, 11:16 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Come on gary your killing me
hook a watt meter up and firewall it
can't wait to hear the numbers
Ron
Ron101 is offline Find More Posts by Ron101
Old Aug 21, 2009, 12:18 AM
Gravity Dodger is offline
Find More Posts by Gravity Dodger
White stuffs here time 2 build
Gravity Dodger's Avatar
Minneapolis Minnesnowtah
Joined Nov 2007
Looks good Gary! How certain are you that these will be available soon or are we going to have to wait over 9 months for these to be available like a certain larger fan system is taking??? LOL
Gravity Dodger is offline Find More Posts by Gravity Dodger
Old Aug 21, 2009, 12:31 AM
efflux RC's Avatar
Joined Aug 2009
Ron,
The RTV that's retaining the EDF will be cured in the morning. Don't have a regular watt meter. but I still need to swap the Dean's on my Eagle Tree to bullets. I converted everything except the Eagle Tree. Will get that done tonite.
MNM
So you like my mini quasi dynawhatzit?
The order has been placed and they should be here in 13 days.
Site Sponsor
Old Aug 21, 2009, 12:40 AM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
This is the worst customer service ever!!!!! I ordered my fan a few days ago and still didnt get it. Plus the owner of efflux wont even return Pm's!!! LOL!!!
Just kidding Gary!!!!
Its nice that a lot of us know you already on here. I cant wait just to see the shroud and this rotor.I hope it is stronger than my Rcmart 8-bladed sickle fans. Makes me wonder if I should start that project next!!
I have three of the 90mm 8 bladed rotors already. I dont have a clue as to what they will take as far as watts go.
All I do know is the 70mm fans sound great.
lavochkin is offline Find More Posts by lavochkin
Old Aug 21, 2009, 02:23 AM
efflux RC's Avatar
Joined Aug 2009
Joe,
I guess I'll have to reply to that first part in a PM (I dare not say it here )
Haven't you been reading.........NOT the RC mart fan...30% glass filled.....70mm:....3.56lbs at 1274w. EDF that sucks motor heat like a..........
Yeah good thing I know you.
Gary
BTW: if folks are interested in preordering the 90mm. I'll get the specs.
I just wanted to see how the 70mm units work out first.
Site Sponsor
Discussion New ARF EDF COMING but at what price? FCBrosius Electric Ducted Fan Jet Talk 132 Mar 10, 2006 12:54 AM
shhhhh..........sneak peak at Superfly RC Mite EDF Review! AMCross Foamies (Kits) 0 Dec 09, 2004 03:07 PM
New Mount for 50-XC (direct IPS drive) system at Radical RC, Testers wanted radicalrc Parkflyers 0 Jul 15, 2004 11:04 AM
