Old Aug 19, 2009, 02:37 PM
thedeuce is offline
Find More Posts by thedeuce
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Gary,
Do you have a website for all this? I am truly interested in it all.
John
thedeuce is offline Find More Posts by thedeuce
Old Aug 19, 2009, 04:11 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by thedeuce
Gary,
John
Hi John,
I will have a domain name and a Web Store shortly. At this time I am taking preorders (the Prices are in POST #1)
Thanks for your interest, Gary
To all,
The email address that you can send orders to was incorrect in one of my posts. Sorry guys. Here is the correct address: effluxrc@gmail.com
Gary
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Aug 19, 2009, 04:21 PM
efflux RC's Avatar
Joined Aug 2009
90 mm Units..................
Due to the number of requests for the 90mm units. I will obtain what information on performance there is ASAP. as well as pricing. the 70 mm units are waiting delivery. A new order will be placed for additional 70mm and some 90 units.
Gary
Site Sponsor
Old Aug 19, 2009, 05:01 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Originally Posted by AIR SALLY
gary can we get just the rotor...i would like to test it in my sky ray with Dons BI 3600 motor to see how close it comes to your 3600kv motor. i dont think Dons motor was designed for 1200+ watts ..but so far it has held up at 900 to 100 kw.
i know your swamped Gary but i would order one if you can answer the ques.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Aug 19, 2009, 07:33 PM
efflux RC's Avatar
Joined Aug 2009
Hi Rodger,
Replacement rotors will be available to customers who purchased the matching size EDF units only. Please note the following liability statement from the mfgr that I posted earlier. Due to the High fiber content, and stiffness (and therefore brittleness) The rotor should not be run in a plastic housing. Even after proper "run in" of the fan, the rotor clearances are quite miniscule. (which contibutes to the high thrust)
About ours this Series Metal EDF Power system
it's to improve the old type Plastic material EDF power system
because old system when motor in the high speed the high hot heat will to cause
the plastic material to dissolve then to cause the FAN to explode !!
and Fixed on the airplane after if setting not too good the Plastic EDF pipe also easy
to change the shape to cause the FAN explode !! ............
Site Sponsor
Old Aug 19, 2009, 07:53 PM
flapdown is offline
Find More Posts by flapdown
Joined Aug 2009
what is the weight of the 70mm fan w/o motor?
and with motor?
Thanks.
flapdown is offline Find More Posts by flapdown
Old Aug 19, 2009, 09:45 PM
efflux RC's Avatar
Joined Aug 2009
MORE INFO and WEIGHTS...
This is the available 3600kv motor for the 70mm units. It comes with the connectors soldered in place as well as the mating connectors. Very nice.
Weights for 70mm unit:
EDF unit, complete with rotor, spinner, motor fairing, and hardware:....96g
3600 kv motor w/ all connectors........................................ ...........169g
Optional Tail cone.............................................. .........................24g
Site Sponsor
Old Aug 19, 2009, 10:05 PM
flapdown is offline
Joined Aug 2009
"3600 kv motor w/ all connectors........................................ ...........169g"
Sorry, but is this the weight of the motor only?
Old Aug 19, 2009, 11:08 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
or you could sell them to people that know how to correctly setup a custom edf....im not to interested in the housing, id like to cut some down for 65mm...if i can do it with a britle e-flite fan, i could probably do it with one of these....just a thought.
Hi Rodger,
corsair nut is online now Find More Posts by corsair nut
Old Aug 19, 2009, 11:33 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Well, I just ordered 2. One for using and the other for destruction testing. If the later holds up with a 3300 mah 35c 5s then it will have a useful life, otherwise.....well that is the whole point of a destruction test isn't it. J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Aug 20, 2009, 12:16 AM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
I guess you can't please everyone. I thought it was great that all the connectors were included. And that the motor side was already soldered.
You won't need bigger connectors. Some motor come with connector, some without. the diff of a few grams won't matter at these power levels.
One Six Right is offline Find More Posts by One Six Right
Old Aug 20, 2009, 02:30 AM
efflux RC's Avatar
Joined Aug 2009
efflux RC TEST JET PROGRESS....
Flapdown,
The reply above was from me, (forgot to switch to business mode)
Finally got off the PC and made some progres on the test jet tonight.
The final glassing is done (tailerons) and ready for primer.
I assembled the EDF/motor unit. I love it...OK, so I'm biased, but that why I got into this. The parts are nicely machined/molded and fit together like a glove. The fan adapter is mounted to the motor shaft via 2 set screws. No fiddling with motor position to center the fan!! there's about .015-.025 clearance between the blade and the housing. All the way around.
Please note that this unit must be assmbled with Heat transfer compound. The preorders will include the compound. but I think the supplier wants to charge me later. We'll work that out. My one sEDF sample did not come with it but I had a tube.
I got the ESC, BEC and rx wired up to the motor, temporarily mounted it in the jet, was just about ready to run it up.........nd my wife goes to bed!!
I was only able to run veeeery slooowly......so, tomorrow's another day.
Here's some pics.
Gary
Site Sponsor
Old Aug 20, 2009, 09:28 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
That is one sharp looking little fan...
please hook the watt meter up and if you have a 4s pack could you run it up for me... lets us know how it sounds
I'm excited to hear you report.. good luck
later
Ron
Ron101 is offline Find More Posts by Ron101
Old Aug 20, 2009, 11:05 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah lets hear it then i'll have to order one...how long is that motor ...looks really loooonnnggg....should have lots of power!
Old Aug 20, 2009, 12:12 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Motor mass is one of the ways needed to dissipate waste heat. I prefer at least 160 grams for a 28mm motor and a heatsink on top of that for anything aproaching 1Kw.
Eric B.
AirX is offline Find More Posts by AirX
Discussion New ARF EDF COMING but at what price? FCBrosius Electric Ducted Fan Jet Talk 132 Mar 10, 2006 12:54 AM
shhhhh..........sneak peak at Superfly RC Mite EDF Review! AMCross Foamies (Kits) 0 Dec 09, 2004 03:07 PM
New Mount for 50-XC (direct IPS drive) system at Radical RC, Testers wanted radicalrc Parkflyers 0 Jul 15, 2004 11:04 AM
