Old Aug 18, 2009, 09:33 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by usmc_VTOL_mech
GARY.......
TWO PLEASE!!!!!!!!!!!!!!!!!
(gotta love twins!)
Thanks Cory. Since were gonna meet up this weekend. How 'bout you maiden the Skyworld powered F-16, while I get video and still shots?
Maybe I'll charge up the batts in the Prospeed too.
Jayb1rdz,
Yeah, send me your addy.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Aug 18, 2009, 09:55 PM
efflux RC's Avatar
Joined Aug 2009
More information concerning specs for the 70mm units.
Being a startup, I'm sure many of you might be leary of many aspects of this new product, and myself as a newcomer to the marketplace. I am not a salesman or a BS'er. You will always get straight talk from me, and and answer, only when I know it. If i am guessing or estimating, I will tell you.
So with that said, I'd like to share some info from the mfgr that i rec'd today(As i will from time to time) Some of this has been stated previously, but please note the THRUST @ 1274w that I highlighed.
Thanks, Gary
Copied from my email from Skyworld:
For not to get misunderstanding i show you more clear below please check :
Item no. : JP-700
69mm dia, 8-bladed
High Watts: 1274W
High RPM : 62012 (Because Electrics an impulse the correct High PRM is about : 49000 RPM
High AMP: 90A
Turst 1850g (4.08lb)
* Please kindness note below infomation's before you to test it . Thank You Very Much ~
About ours this Series Metal EDF Power system
it's to improve the old type Plastic material EDF power system
because old system when motor in the high speed the high hot heat will to cause
the plastic material to dissolve then to cause the FAN to explode !!
and Fixed on the airplane after if setting not too good the Plastic EDF pipe also easy
to change the shape to cause the FAN explode !! ............
Site Sponsor
Old Aug 18, 2009, 10:20 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
I ordered one to compare against the rcmart 8 blader.
lavochkin is offline Find More Posts by lavochkin
Old Aug 18, 2009, 10:35 PM
efflux RC's Avatar
Joined Aug 2009
That's great Joe. Unfortunately I don't have a gazillion EDFs and rotors around to compare to. But I'd love it if you and anyone else would share your findings here.
Thanks, Gary
Site Sponsor
Old Aug 18, 2009, 10:41 PM
lavochkin's Avatar
Joined Oct 2006
I am comparing just to my others in a plane, not bench comparing. Too many complainers out there for me to even want to attempt that. Ill do my comparison by flying the jet with it in it. It will outperform the plastic rc mart unit hands down. Maybe not a ton with the numbers, but the added cooling factor of the aluminum will put it in its own class for sure. They sound great thats for sure!!
Old Aug 19, 2009, 03:06 AM
iceman3 is offline
Find More Posts by iceman3
Norway
Joined Mar 2005
Hi all, just subscribing to this thread.
iceman3 is offline Find More Posts by iceman3
Old Aug 19, 2009, 03:34 AM
efflux RC's Avatar
Joined Aug 2009
Welcome iceman.
Site Sponsor
Old Aug 19, 2009, 05:19 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Plugging in and listening with interest for the upcoming 90 mm version
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old Aug 19, 2009, 05:48 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
will you have audio by before the preorder date is up? i'm on the fence, but i'd really like to hear it first.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Aug 19, 2009, 07:16 AM
Naval Warfare is offline
Find More Posts by Naval Warfare
Screw the wind, let's fly!
Naval Warfare's Avatar
United States, GA, Sautee Nacoochee
Joined Feb 2008
subscribed
I'm in
Naval Warfare is offline Find More Posts by Naval Warfare
Old Aug 19, 2009, 08:46 AM
ced_toulouse is offline
Find More Posts by ced_toulouse
France, Midi-Pyrénées, Toulouse
Joined Sep 2007
just received mine, i have JP-550 and JP-700. i will use it on a small A4 skyhawk (1.2Kg) instead of a WM-400+typhon 2W20. I don't know if I'll get more power but i love the heatsink idea!
both EDF were delivered with an engine cone and added length cone tube (like on the WM-400); everything is aluminium, except the blades.
the JP-700 was sent with a BL motor that looks great, i'll give it a try too.
Cedric,
ced_toulouse is offline Find More Posts by ced_toulouse
Old Aug 19, 2009, 10:02 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
This sounds great, Gary! I wish you the best of luck with your new business. I'm definitely keeping an eye on this thread...
Are the impeller blades aluminum too? If so... that would be mighty cool but you might run into AMA issues (which matters to some of us...not so much to others).
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Aug 19, 2009, 12:01 PM
efflux RC's Avatar
Joined Aug 2009
Thanks for the well wishes.
The impeller is glass filled nylon.
Pete,
It will be two weeks before I have any stock in house, so I will extend the Pre order period until Thurday, August 27, 2009
Site Sponsor
Old Aug 19, 2009, 12:45 PM
efflux RC's Avatar
Joined Aug 2009
Originally Posted by Naval Warfare
I'm in
Great to see ya here Dale, Let me know when your ready to build that faaast jet!
Gary
Site Sponsor
Old Aug 19, 2009, 01:08 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
the 90mm version better be able to take 3.5-4kw...id buy one of those in a heart beat!
corsair nut is offline Find More Posts by corsair nut
Discussion New ARF EDF COMING but at what price? FCBrosius Electric Ducted Fan Jet Talk 132 Mar 10, 2006 12:54 AM
shhhhh..........sneak peak at Superfly RC Mite EDF Review! AMCross Foamies (Kits) 0 Dec 09, 2004 03:07 PM
New Mount for 50-XC (direct IPS drive) system at Radical RC, Testers wanted radicalrc Parkflyers 0 Jul 15, 2004 11:04 AM
