View Poll Results: 2cell A123 or 5cell Nimh or 2cell Lipo with UBEC for Rx pack?
5cell Nimh 0 0%
2cell Lipo with UBEC 4 18.18%
2cell A123 18 81.82%
Voters: 22. You may not vote on this poll
Old Aug 16, 2009, 11:44 PM
Quixksilver is offline
Find More Posts by Quixksilver
Distributed Manufacturing
Quixksilver's Avatar
United States, NV, Reno
Joined Jun 2009
Poll
Well I really need to think hard about this subject and I need your help. I may have had a brown out in my Rx and that may have been what cause a very bad crash. If that was the case then I need to look into a better solution for powering my 7 high torque servos.
Quixksilver is offline Find More Posts by Quixksilver
Old Aug 17, 2009, 12:59 AM
Franz2002_01 is offline
Find More Posts by Franz2002_01
Ft. Lauderdale, Fl
Joined Feb 2004
2SA123 most times the 1100s are enough
Franz2002_01 is offline Find More Posts by Franz2002_01
Old Aug 17, 2009, 04:58 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Definitely A123 2S 2300 with no regulator (and ideally no switch) will be the safest, strongest and most reliable solution. The pack will hold over 5V at 70A load so even if a servo stalls you will retain Rx operation and control. You get superior performance, vastly longer shelf life, much faster recharge and lighter weight than NiMH and simpler, more reliable and more electrically robust operation than LiPo+regulator.
kgfly is offline Find More Posts by kgfly
Old Aug 17, 2009, 07:09 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The 2S A123 would get my vote for toughness and reliability. And quick charges in the field too.
If you want 6-7V nominal, a pair of 1100 mAh A123's at 80 grams (40 grams each) would work better than the 2300 mAh cells. The two 2300's would weigh 140 grams.
There are also some 17340 (17mm O.D. by 34mm long) 350 mAh LiFePO4 cells on eBay now. Those could be used in a 2S2P for a 700 mAh pack that would be about 70 grams. And various other configurations would give you other voltage choices in packs that are a little smaller and lighter.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Aug 17, 2009, 08:01 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Sing it over and over and over again, Frosty Morn.
http://www.rcgroups.com/forums/showthread.php?t=914941
Old Aug 17, 2009, 09:35 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
I have used all the above combinations.
I would not recommend the 1100's A123.
In my 35% Extra, I run 2 2S A123's without a regulator, 1 rx, 2 switches.
In my Showtime 90 e-conversion, I run a 2S2P 4400 li-ion pack with the CC BEC. CC just released a higher amperage BEC recently too.
What I do not like about the A123's as a rx pack is that you cannot use a loaded ESV to watch the voltage, you need to watch how many MAH have been used. What I do like is the fast recharging. On my 4400 Li-ion pack, I can get over 12 full flights before a recharge and it charges in an hour. The A123's recharge in under 20 minutes since you never use anywhere near the full capacity as a RX pack, assuming you have a charger that can do it.
Honestly, pros and cons to all of the above.
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Discussion Charging a Thunder Power 2cell lipo with a Venom 3cell charge port and 4 wire adapter modfly Batteries and Chargers 0 Jun 22, 2008 11:49 AM
Wanted 2/3AAA nimh 350 mah 4 cell flat for rx pack jondon69 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 23, 2008 08:36 AM
Question Nicad or NiMH for Rx Pack? FlyingW Giant Electric Planes 18 Apr 05, 2007 05:52 PM
Discussion Nicad or NIMH for RX Pack miskin Electric Heli Talk 10 Mar 28, 2007 03:04 PM
Found 2S lipo >=2000 mah for RX pack (or 3S pack to cut down if good deal) Dukester Aircraft - Electric - Batteries & Chargers (FS/W) 4 Feb 18, 2007 07:17 PM
