Old Aug 15, 2009, 09:55 PM
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
3A~5A electronic switchjack with lost model alarm and low voltage alarm (4 & 5 cell)
PLD-ESJ-3A-LMA-LVA
With the new ESJ combination, you can switch on/off and charge your plane all with a single 3.5mm plug-socket. Inserting the plug turns off the unit, after which you can then charge your lipo via the 2-wire plug. To turn on the machine, simply remove the plug from the socket.
Specifications:
* Very low weight - 8.5g
* Very small - 28 x 12.5 x 10mm
* 4 and 5 cell NiMH or NiCd input
* 3A constant supply, 5A peak surge capable
* LED-blink voltage state indicator (full scale, eg 4.7V shows as 4 long blinks + 7 short blinks)
* Low voltage alarm (4.7V for 4 cell, 5.9V for 5 cell)
* Lost model alarm (below 1.3mS to trigger)
* Low profile buzzer alarm
Supplied with 100mm 22AWG RX lead, 100mm 22AWG battery lead and combo charge/switch plug.
PLD is offline Find More Posts by PLD
Discussion Lost Model Alarm for use with Hitec Micro 5 Receiver larjim Foamies (Kits) 2 Jun 29, 2007 04:45 PM
Lost Model Alarm stegre Slope 17 Jul 31, 2003 09:34 PM
FS: Hobbico Air Alert lost model alarm, $12 thwang99 Aircraft - Electric - Airplanes (FS/W) 4 Feb 22, 2003 03:49 PM
"Lost Model Alarm" (British "humor") Dave Roberts Humor 4 Jul 11, 2002 10:47 AM
