Old Aug 15, 2009, 09:09 PM
Siri is offline
Find More Posts by Siri
Siri's Avatar
Joined Oct 2008
Build Log
Catamaran RC65 Adrenaline - 65M class - build log
Inspired by cat pictures from fellow sailors and the success of my 65cm tris I have started a 65cm catamaran build and will share the building progress here.
I'm laminating the hulls now, first pictures will be here soon.
Cheers
Phanchita
Siri is offline Find More Posts by Siri
Old Aug 16, 2009, 09:34 AM
Dick L. is offline
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Hi Siri -
Well - I was back to working on my cat last night, and my initial feeling is the 65cm size might be a bit too small for a cat. Whereas your trimarans housed your gear in the center (wide) hull, the long, narrow beam-to-length ratios of a cat are presenting some interesting challenges.
I finished up the GWS drum winch, and my modified drum at just over 1 inch will fit the hull, but is a bit heavy - I probably have room for rudder servo and may have to put batteries and receiver in other hull in order to maintain balance. It looks to be a very tight fit.
I don't want to go too much smaller for sail winch, as I'm running in the 250 sq, in, hi-aspect ratio sail, so it is possible I may have to trash my ideas for hull mounted radio gear and resort to some sort of (ugly) central pod.
I really think that a 1 Meter size would provide the extra room and buoyancy without a doubt, but then I am moving back to my original 1 Meter and that is a pretty big boat!
As you start to bring a hull design together, let me know your thoughts - and what radio gear you think will fit. I know I can downsize, just not sure by how much. Heck - I just may decide to go with an extended arm on a small servo and live with it. Actually, do not need a full-out winch, as most downwind work is similar to beating - sails close hauled and seldom at 90 degrees to centerline of boat.
Regards
Dick L. is offline Find More Posts by Dick L.
Old Aug 16, 2009, 07:52 PM
Siri is offline
Siri's Avatar
Joined Oct 2008
Hi Dick,
I got my inspiration from this Mini40 CAT - I plan to build mine with the same concept - two hulls with a center daggerboard and rudder.
65cm is very small for a CAT especially if you're trying to downscale a full size design like A-class CAT.
I'm going another way and use the hulls from my Tris instead. May look less sleek but my intention is not building a scale model but a well sailing CAT.
I will use a standard arm servo for the sheets as I do with my Tris, it has proven to be sufficient, easy and fast too.
I will setup the servos and receiver in one hull and the batteries in the other hull to balance the CAT - there is no other way without adding lead.
I expect the CAT to be much more difficult to sail as it will capsize easy unless you make it 1m wide what will look very ugly then.
Anyway build your Flyer and do the sailing tests - we cannot make much progress if we do not have anything to compare.
Cheers
Old Aug 16, 2009, 08:20 PM
Siri is offline
Siri's Avatar
Joined Oct 2008
I have laminated the two hulls for 'Adrenaline' using the moulds from my 'Armageddon' .
I laminated the hulls plain without gelcoat to save weight.
The beams are test fit already.
Next step will be radio installation and building the rig.
cheers
Old Aug 22, 2009, 10:53 PM
Siri is offline
Siri's Avatar
Joined Oct 2008
Hi folks,
I made some progress on my 'RC65 Adrenaline' project. I have created the center platform to attach mast, daggerboard and rudder from 6mm carbon fiber tubes secured to the beams with carbon tows and a little epoxy, have installed the mast & keel boxes and rudder tube and fit the fin and rudder.
I also build a new rig from 6mm carbon tubes.
Here are the pictures:
Center platform with mast box, keel box & rudder tube installed
Keel and rudder assembled
Mast attached - total weight now 375g
Next to do:
  • R/C installation
  • Sails
Have a nice day
Old Aug 23, 2009, 10:57 AM
nigelpheron is offline
Find More Posts by nigelpheron
nigelpheron's Avatar
Canada
Joined Jan 2007
That looks absolutly awesome. Very detailed building and high-tech ideas.
I'm currently working on a small cat as well, and your posts are very inspirational. They make me want to build, and experiment even more.
Good work.
nigelpheron is offline Find More Posts by nigelpheron
Old Aug 24, 2009, 04:48 AM
Siri is offline
Siri's Avatar
Joined Oct 2008
Thanks for the praise, Nigel.
I will keep you all up to date about my progress here.
Would be a perfect idea if all who are working on a small multihull would post some pics and the concepts of their designs here, this way we could learn from each other and can improve our designs faster .
Cheers
Phanchita
Old Aug 24, 2009, 06:47 AM
Canada
Joined Jan 2007
Yes photos.
I'm still in testing ideas stages; but when things are ready, pics will follow in their own thread.
Cheers,
Old Aug 24, 2009, 12:00 PM
Dick L. is offline
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Please note: This is the catamaran design I am following. Original intent was to "bury" radio gear in the hulls (2" wide") but size of some items a bit too large and will create an imbalance is floating attitude. I have decided to move to a "central pod" - looks like crap, but at this size there aren't many options.
Siri and I have had discussion/correspondence. Have started working on the pod - but family crisis this weekend - our little Sheltie (dog) passed away very suddenly, and family is in a real "down" mood - so will be detained for a while until we can get over this loss.
In the meantime, here is my hull design - based very loosely on the "A" Class current design thinking. At first, I believe I will give up some extra sail area for "safer" sailing. Can always change rig or add jib. Haven't looked at proposed 65M rules lately to see what the sail area maximum is (if any) or if they are following the monohull (RG-65) rule. Probably will use a duble-luff mainsail and not worry about rotating anything. Also first boat will probably retain wood dowels for cross-beams.
Old Aug 24, 2009, 12:05 PM
Dick L. is offline
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
A response to Siri & centerboard.
Since we all know a single hulled catamaran (windward out of water) is much faster than both hulls in, I have dcome up with the thought of allowing the centerboard to let the hull tilt "slightly" - and only enough to allow windward hull to rise from water. Have come up with a way to restrick degree of sideways centerboard movement to (roughly) 10 degrees which should allow windward hull to rise free of water, but not far enought to provided added momentum to capsize to the side.
Again - kind of busy and refocused at the moment - but when time permits I will try to mock-up my idea.
Old Aug 27, 2009, 12:04 AM
Siri is offline
Siri's Avatar
Joined Oct 2008
I found some time to place radio equipment. The rudder is moved with a carbon push rod, all the R/C equipment except batteries sits in one float, the battery is in the other float to keep weights balanced.
I will go for a set of easy sails and hope to launch at the weekend.
Here are some pics from my last progress.
radio tray
some views of R/C installation
rudder with pushrod attached
top view with all rc installed - you can see batteries are in the right float, while servos and receiver are in the left float
Have a nice day
Old Aug 29, 2009, 07:47 PM
Siri is offline
Siri's Avatar
Joined Oct 2008
Yesterday I maidened the RC65 'Adrenaline' Catamaran.
I'm happy with this boat.
video clips from the launch are on my web now:
www.rcsails.com/rc65.htm
Adrenaline First Launch
Have a nice day[]
Old Aug 29, 2009, 07:57 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Great video, looks good on the water.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Sep 08, 2009, 06:15 PM
Siri is offline
Siri's Avatar
Joined Oct 2008
sails cool too
Build Log Bad Boy V2 Build Log srg123cohen 3D Flying 7 Oct 21, 2013 09:24 AM
Discussion B-25 Build Log - Flying Styro kit(Hobby-Lobby) kahloq Electric Warbirds 625 Jan 12, 2010 04:12 AM
Build Log RG-65 Sailboat Class Build Log A to Z ROADTOAD Sailboats 66 Sep 21, 2008 08:59 PM
Question +build log/piccolo/huey paul sant Micro Helis 1 Feb 22, 2006 02:32 AM
Mini-Review Build log/review of the Charger CR-2 and 3D Hobby Shop's landing gear sharky47 3D Flying 0 Jan 22, 2006 03:21 PM
