Old Aug 15, 2009, 02:05 AM
FAKHREALAM is offline
Find More Posts by FAKHREALAM
Alam
RENO
Joined Aug 2007
New Product
True Air Speed Meter
I am starting new project that will measure the
1) GPS ground speed
2) Air speed
3) True Air speed
4) Log the GPS ground speed, Air speed and True speed.
5) Data will be available through USB and serial port.
For now I am using my old board, you can buy that board from
http://thesiliconhorizon.com/store/a...02dp-p-87.html
Fakhre Alam
FAKHREALAM is offline Find More Posts by FAKHREALAM
Old Aug 15, 2009, 02:30 PM
Alam
RENO
Joined Aug 2007
Hi Guys
Give me any input, let me know any thing need to add, any input will be good and appreciated.
Fakhre Aalm
Old Aug 15, 2009, 08:57 PM
Tomapowa is offline
Find More Posts by Tomapowa
R/C Electro-Gadgeteer
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Got to ask... What's the difference between airspeed and true airspeed?
Tomapowa is offline Find More Posts by Tomapowa
Old Aug 15, 2009, 09:31 PM
Ron W3FJW is offline
Find More Posts by Ron W3FJW
Ron W3FJW's Avatar
Tacoma WA
Joined Feb 2008
I think he may mean airspeed and speed over the ground. Will differ in winds.
Ron W3FJW is offline Find More Posts by Ron W3FJW
Old Aug 15, 2009, 09:43 PM
Alam
RENO
Joined Aug 2007
Its kind of use in real aircraft.
1) The true air speed of the aircraft is equal to the speed of the aircraft relative to the earth surface (by GPS or some other means).
2) Air speed is the speed (air mass flow under need/over wings) of an air measure by pitot tube.
One use for keep plane float and the other one use to measure how much distance plane is traveling. In some cases ground speed can be zero but you have +ve air speed.
I am also a life time student learning from your questions. Please correct me if I need correction.
Fakhre Alam
Old Aug 16, 2009, 01:09 AM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
I'm extremely interested.
A question to start with, Will the board your are referend to in the first entry be able to host all three:
1) GPS ground speed
2) Air speed
3) True Air speed
Or do I need three boards for that?
To where are the data going to be logged, will it be a separate logger? I have a Eagle Tree logger, could that be used to log the data?
Thanks!
/Håkan
hakank is offline Find More Posts by hakank
Old Aug 16, 2009, 02:43 AM
Alam
RENO
Joined Aug 2007
1) GPS ground speed
2) Air speed
3) True Air speed
Thanks!
/Håkan
1) I designed air speed board just for my use, for now I will use that one.
2) For GPS, LS20031 is good option, just hook-up with PIC32. PIC32 board will have EEPROM to store all GPS parameters and temperature, current, voltage and RPM sensor interface.
3) OSD board I did year back, for now I will use that one, just connect it to PIC32 using SPI port.
4) Data upload and download and config can be done by PC using serial port or USB, I am learning USB interface, can be done easily on serial then USB for now but USB will be for final product.
5) For prototype we can stack all three board and do testing then for final it will be two PCBS.
6) I did not have enough info about eagle tree data logger, if some can give me some insides it can be use. Not sure eagle tree will give their trade secret.
7) Ground speed can be done by on board GPS.
8) Air speed can be done by A or D pressure sensor using pitot tube.
Thanks.
Fakhre Alam
Old Aug 16, 2009, 02:49 AM
Alam
RENO
Joined Aug 2007
U are right if your head wind is hitting you with 50 MPH and your plane engine is giving 50 MPH thrust you ground speed will be 0, means your are floating in air but kind of stand still w.r.t ground. That's a funny situation.
Your GPS will show 0 MPH or some times your craft will go backward instead of forward due to head wind.
Fakhre Alam
Old Aug 16, 2009, 03:22 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
But you're still talking about three different speeds. I understand ground speed and air speed but what's "true" air speed if it's different from both of those ?
Steve
slipstick is offline Find More Posts by slipstick
Old Aug 16, 2009, 04:03 AM
Ron W3FJW's Avatar
Tacoma WA
Joined Feb 2008
TAS if I can remember back to my flying days a lifetime ago is the proper term for speed over the ground.
Old Aug 16, 2009, 04:27 AM
Alam
RENO
Joined Aug 2007
You can say like that, its just a wording. The true airspeed of the aircraft is equal to the speed of the aircraft relative to the earth's surface (ground).
Fakhre Alam
Old Aug 16, 2009, 05:46 AM
ThermalSeeker is online now
Find More Posts by ThermalSeeker
United States, CO, Denver
Joined Sep 2005
This is actually a question on the private pilot exam. The answer that is expected is :
"True airspeed is calibrated airspeed corrected for non-standard temperature and pressure."
Airspeed indicators work via differential pressure from the ram air pressure of the pitot tube and static pressure. Since the air density will vary with altitude and temperature then the ram air pressure will vary with these changes.
Calibrated airspeed is simply indicated airspeed corrected for any installation errors in the system.
So at sea level on a standard temperature day of 59 degrees F and standard pressure of 29.92 with an airspeed indicator that has no errors..... indicated airspeed would equal true airspeed. As we go up in altitude then indicated airspeed will go down as true airspeed increases.
If he truly intends to do the calculations to show us true airspeed it would be cool to see the true airspeed when DSing your glider on top of your favorite mountain slope, otherwise indicated airspeed is likely close enough.
ThermalSeeker is online now Find More Posts by ThermalSeeker
Old Aug 16, 2009, 07:28 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Exactly right. The term "airspeed" always refers the the movement of the aircraft through the air, and as Mike has said, there is sometimes a difference between indicated and true airspeed. Calculating true airspeed was probably much more important some years ago than it is now, because it often affected navigation, back before the days of GPS. The correct term with which to refer to the movement of an aircraft relative to the earth is "ground speed". Fly at 150 knots IAS into a 30 knot head wind, and your ground speed will be 120 knots.
It's much the same as the differences in altitude readings. "True" altitude is measured above sea level, but what's most important to a pilot is his altitude AGL, or above ground level. The altimeter is adjusted for the ASL altitude of the airport, so the altimeter can indicate to the pilot his altitude AGL. (It needs to be >0)
dmccormick001 is offline Find More Posts by dmccormick001
Old Aug 16, 2009, 08:11 AM
Staffs, UK
Joined Nov 2003
But the person doing the measuring thinks "true airspeed" means speed over the ground (or what most of us call ground speed)...this is not even close to being the same thing as airspeed corrected for specific temperature and pressure.
So my question is still what is the "true airpeed" that Fakhre Alam is intending to measure and how is he measuring it.
Steve
Old Aug 16, 2009, 08:29 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi,
It might be an airspeed that is much much much more precise than the one given by competition ... DO NOT ask how much !!!
Seriously, that will need, temp ( static ... ! ) , Hygrometry and abs pressure, may be a gas analyzer too ( for real true air density ) ...
if my Thermodynamics lessons were right ... of course.
Alain
Acetronics is offline Find More Posts by Acetronics
Discussion sorta cheep air speed meter turbonut Electric Ducted Fan Jet Talk 7 Jun 19, 2006 08:38 PM
Discussion Tiny, Cheap, On Board Peak Air Speed Meter!!??!!?? sno Dynamic Soaring 18 Apr 18, 2006 02:04 AM
Radio Shack wind speed meter cfossa Parkflyers 6 Apr 10, 2003 02:34 PM
Required air speed given wing loading? alaric Power Systems 2 Sep 26, 2001 06:36 PM
Wind Speed vs Plane's Air Speed Ron D Foamies (Kits) 2 Jun 17, 2001 11:47 AM
