Old Aug 15, 2009, 01:46 AM
FAKHREALAM is offline
Find More Posts by FAKHREALAM
Alam
RENO
Joined Aug 2007
New Product
New Osd Design For Fpv With Data Logger
Hi
I am starting a new OSD for FPV which will include
1) LAT
2) LON
3) HOME
4) ALTITUDE
5) BATTERY VOLTAGE
6) LOAD CURRENT
7) ENGINE RPM
8) LOAD POWER CONSUMPTION
9) TEMPERATURE
10) ALTITUDE
11) HEADING
12) SAT STATUS
13) DISTANCE FROM HOME POSITION
14) AIR SPEED
15) GROUND SPEED
16) AUDIO ALARMS
User can switch different screens by RX ch or it can be configure by USB port through PC.
Here is the OSD board I did year back and can be programmed using SPI port.
If you want you can buy it from
http://thesiliconhorizon.com/store/a...oard-p-78.html
MAX 7456 OSD Development board
[alam7456]
$47.50
In Stock
Click to enlarge
Alam Tech's MAX 7456 OSD Development board has everything you need to develop your text-based on screen display solution utilizing Maxim-IC's MAX 7456 chip.
This board will take your SPI data stream and overlay it on a NTSC or PAL video input.
This is the only non-Maxim MAX7456 development board produced!
Suggested applications
* UAV / FPV data video overlay
* Security system video overlay
* Consumer video electronics overlay
Featuring:
* small 2"x2.8" footprint
* SPI communication upto 10 Mhz speed
* NTSC or PAL video input / output on RCA connectors
* All Sync lines on headers
* 7-12 Vdc input, approx 250 mA
* Schematics and PCB layout included
Fakhre Alam
FAKHREALAM is offline Find More Posts by FAKHREALAM
Old Aug 15, 2009, 04:16 AM
jsullivan05 is offline
Find More Posts by jsullivan05
jsullivan05's Avatar
United States, IL, Belleville
Joined Aug 2009
Well this looks fun... and complicated lol...
jsullivan05 is offline Find More Posts by jsullivan05
Old Aug 15, 2009, 10:51 PM
Alam
RENO
Joined Aug 2007
Its a start let see how it goes, using PIC32, have lot of power. I am thinking if I can design OSD with GPS under US$ 70.00, what you think with USB or RS232 interface with multiple parameter pages.
Most of the suppliers are selling data logger, gps and OSD as different units as well as sensor, kind of if u add all its over US$275 - 300. Its way over the cost.
Let me know what is the best way, the way they are doing modular and charging more money or put all in one, just GPS outside.
Data logger is noting but a main micro with EEPROM to store the GPS parameters and sensor values. It can be download to PC by USB or COM. Kind of same unit is programming the OSD chip.
Note: Any input will be good.
Fakhre Alam
Old Aug 15, 2009, 11:25 PM
Joined Aug 2009
well you get it up and running and I'll test one out for ya lol
Old Aug 15, 2009, 11:59 PM
Alam
RENO
Joined Aug 2007
PM me I will add you to my tester list.
Thanks.
Fakhre Alam
Old Aug 16, 2009, 01:01 AM
Joined Aug 2009
Done heh, how many months out do you think you are?
Old Aug 16, 2009, 03:05 AM
Alam
RENO
Joined Aug 2007
I am checking what PIC32 board need to order,
1) MAX7456 OSD board is all done, I have 4 working one, share with testers.
2) Current/Volatge measuring need to do.
3) Air speed board is all done.
4) GPS parsing function in C are all done.
5) PIC32 board and debugger I need to order and put EEPROM to store parameters.
6) Visual C++ PC program is kind of 50 % done.
I think you will get working one prototype in month and half. With GPS we are talking about $60 to $70 for testers. The best thing is that if you know C you can program PIC32 and use my code as base and make your own.
Fakhre Alam
Old Aug 16, 2009, 03:09 AM
Joined Aug 2009
I've only studied C# a little, no C or C++ for me, shouldn't be too hard to figure out if you already have something working
Old Aug 16, 2009, 04:44 AM
Alam
RENO
Joined Aug 2007
I have to code written year back, you can understand it, its modular, OSD have it own c and .h file, GPS parsing have it own c and .h file same for air speed and com's. Kind of not very good written but good to go. I am Engineer and want to learn from you all and try to teach if I know some thing. Knowledge sharing is a good thing if I will not let u know u will learn from some where else any way. Some of my friends make Cruise missile in around 2 years using Virtex-3 with DSMAC with pin point of 10 meters, I am so behind when I compare my self with them. We are here to make world better.
Fakhre Alam
Old Aug 16, 2009, 11:29 AM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
PIC32 has a lot of available power, so it is all up to your skills. But man I find this quote kinda odd:
Originally Posted by FAKHREALAM
...Some of my friends make Cruise missile in around 2 years using Virtex-3 with DSMAC with pin point of 10 meters...
...We are here to make world better.
Fakhre Alam
lol, like "Pax Romana" or something like that.
Elcheapo is offline Find More Posts by Elcheapo
Old Aug 16, 2009, 01:20 PM
Alam
RENO
Joined Aug 2007
Guys u can not make cruise missile with DSMAC by PIC, it was just an example that technology is not a thing you can hide for long time. We all can learn and make things but the key is learning on regular basis.
Fakhre Alam
Old Aug 17, 2009, 05:04 AM
Alam
RENO
Joined Aug 2007
My old design using the LPC2106 board and my own designed MAX7456 board (SPI OSD board) along with LS20033 GPS.
Fakhre Alam
Old Aug 22, 2009, 02:00 AM
Alam
RENO
Joined Aug 2007
Here video of my MAX7456 based OSD year back. Enjoy.
MAX7456 OSD WITH LIVE GPS FEED (0 min 34 sec)
Fakhre Alam
Old Oct 16, 2009, 12:45 AM
Alam
RENO
Joined Aug 2007
Part list for OSD (Cost will be under US$100 or may be around US$70 with the GPS)
I am using MAX7456 AlamTech OSD board and my ATMEGA48 board with LS20033/31 GPS. Instead of using ATMEGA48, I am using ATMEGA328.
Here is the part list.
1) LS20031 GPS
2) Voltage/Current indicator board
3) MAX7456 OSD BOARD.
Here is the snap of all the parts I am using. All programming will be in C/C++.
If some one interested they can buy parts from
MAX7456 OSD BOARD
Voltage/Current Monitor
http://thesiliconhorizon.com/store/a...play-p-93.html
GPS
You can get GPS from me, pm me or email me at fakhre@rocketmail.com
Note: Cost will be under US$100 or less, may be around US$70 with the GPS.
Thanks.
Fakhre Alam
Old Oct 17, 2009, 04:17 PM
Alam
RENO
Joined Aug 2007
Low cost OSD project based on ATMEGA328 and MAX7456 OSD chip
I just ordered ATMEGA328 from www.digikey.com, firmware will test on simulator 1st then on chip. It will based on MAX7456 chip, low cost solution.
Note: If any one interested in programming in C or development for this project get back to me, email me at fakhre@rocketmail.com or PM me.
Note: Developer can buy stuff from sparkfun, digikey, it a open source project.
Thanks.
Fakhre Alam
2 new tail blades for hummingbird with gear mphsjeep Aircraft - Electric - Helis (FS/W) 1 May 20, 2005 11:52 PM
Trying new wing design for Slow Stick sirdirk007 Parkflyers 2 Jan 10, 2005 12:33 PM
New motor design for genius members Ray280 Electric Plane Talk 8 Mar 25, 2004 12:04 PM
New Brisk II for sale with Volz Micro Maxx servos glide Aircraft - Sailplanes (FS/W) 6 Jan 03, 2004 08:59 PM
New Zagi Kit For Sale with extras btompkins Aircraft - Electric - Airplanes (FS/W) 1 Apr 22, 2003 08:38 AM
