Old Aug 13, 2009, 09:45 AM
Will work for foam
wingnutt's Avatar
Waukesha, WI.
Joined Apr 2005
Cutting cores for multi-panel & taper wings with ailerons
When cutting cores for a multi-panel, multi-taper wing which will be using ailerons that extend across multiple panels, to you vertically align the airfoils to where the hinge point (top, bottom or center) will form a straight line, or do you align them by the center chord line?
wingnutt is offline Find More Posts by wingnutt
Old Aug 13, 2009, 09:54 AM
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Yep, you are on the right track. align them by the hinge line and rotate the washout aroudn that point to. This will result in a straight hinge that will move more freeley and last longer.
djklein21 is offline Find More Posts by djklein21
Old Aug 13, 2009, 10:12 AM
Will work for foam
wingnutt's Avatar
Waukesha, WI.
Joined Apr 2005
djklein21 - that's what i was figurin', but wanted to be sure before i comensed cutting. Thanks!
For Sale For Sale - Super Dimona wings, with servos snoshoe62 Aircraft - Sailplanes (FS/W) 2 May 03, 2007 07:33 PM
Vacuum bag, wing press, or contact cement for sheeting wings with wood? surfimp Slope 53 Dec 13, 2004 12:00 PM
