Old Aug 13, 2009, 08:29 AM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
Another Maiden Flight - Good but just off
Seems my motor selections are off lately, little on the small side so I need the opinions of an expert, or group of them
The plane is a House of Balsa Laser Stick 10 (Chea Pass) and is flying with a KDA 22-20L from Hobby City with a 9x5 prop and 3S 2200 pack.
Takes off out of grass in about 25' and flies wonderfully. Club trainer even liked how stable it was compared to a 40 trainer. It flies so well I almost don't want to ruin it. Honestly took my hands off the Tx for a minute while it went one side of the field to the other in a 10mph wind and watched it stay straight and level.
It's a smidgen slow and cruise is at 3/4 throttle and that doesn't leave a lot of extra for fun. I have the ability to go bigger and would like to but don't want to break the bank.
So considering the prop is about maxed when it comes to ground clearance on takeoff should I try a 9x7.5 prop and see if that kicks things up a bit or just put the motor somewhere better suited and look for something a little bigger?
I have this motor on the shelves http://www.headsuprc.com/servlet/the...lectric/Detail but also think it may be a smidge small for the plane.
Thoughts and opinions?
mt_100 is online now Find More Posts by mt_100
Old Aug 13, 2009, 12:27 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
For the House of Balsa Laser Stick 10:
Wingspan 45.5"
Wing area 318 sq. in.
AUW 30 oz.
For excellent performance, you are probably looking for a 1200 Kv outrunner that can handle about 28 amps of continuous current while swinging a 9x6 on your 3S 2200 mAh lipos. Your batteries could easily provide this current level which is just a bit more than a 10C draw. Your motor should weigh around 3 oz. I have attached a WeboCalc projection using the data listed for your ship.
I would say that the motor you are considering as a replacement is in the ballpark, but would agree that it may be a bit small for the level of performance you are looking for. You need just a bit more Kv for extra pitch speed and a little more power-handling capability.
P.S. I am definitely not an expert but think Flieslikeabeagle (author of Webocalc) is. Thanks for providing the example. It's a lot of fun running numbers on WeboCalc. Good luck with your new setup!
whitecrest is offline Find More Posts by whitecrest
Old Aug 13, 2009, 12:50 PM
tom1968 is online now
Find More Posts by tom1968
Still circling in sink...
United States, MA, Grafton
Joined May 2006
Yup, I agree. 1200 Kv would be about right. A Suppo A2814-08, Dualsky XM3530CA-12T, Electrifly Rimfire 28-30-1250, and plenty more would fill the bill.
tom1968 is online now Find More Posts by tom1968
Old Aug 13, 2009, 01:08 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
You didn't mention your current draw. If you're within the current specs, just try the 9 x 7.5, it's a cheap $3 upgrade and the pitch speed will increase significantly compared to the 9 x 5. If that doesn't do what you want then upgrade the motor.
Azarr
Azarr is offline Find More Posts by Azarr
Old Aug 13, 2009, 01:14 PM
I have no friends
Joined Dec 1996
I may play with the gear too. Moving it forward 1/2" will give me a lot more prop clearance and a bigger prop.
Current amp draw is around 14 amps at peak on a 3S 2200 so it is well within it's capability.
Old Aug 13, 2009, 01:20 PM
I have no friends
Joined Dec 1996
I was thinking in the 1200 - 1400 kv range so that sounds about right. Where is a good place to pick up the Suppo motors in the US that is reasonably priced?
Hate waiting two weeks for stuff from China.
Old Aug 13, 2009, 01:25 PM
I have no friends
Joined Dec 1996
What about slapping a 3 blade prop on it like a GWS 9x5 or 10x6?
Anyone think that would produce better results?
Old Aug 13, 2009, 01:50 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
LightFlightRC carries them, I don't know how the pricing compares:
http://www.lightflightrc.com/
They have one of those silly frames web pages that does not let you copy off links to individual frames of info so you'll have to pick your way to the motor pages.
Jack
jackerbes is offline Find More Posts by jackerbes
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Select Products and Motors & ESC, then scroll down the page aways
Ken Myers is offline Find More Posts by Ken Myers
Old Aug 13, 2009, 01:56 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Try Light Flight RC They also provide excellent motor data. There are probably others.
Old Aug 13, 2009, 02:00 PM
I have no friends
Joined Dec 1996
I think I will take Azarr's advice and tinker with the prop a little. It is just to darn nice flying to remotor it right now.
Thinking of picking up a few 3 blade props too.
Old Aug 13, 2009, 02:21 PM
JMBRAD is online now
Find More Posts by JMBRAD
Jody Bradshaw
JMBRAD's Avatar
Salisbury, North Carolina, United States
Joined Feb 2004
Here are 3 good retailers I have bought from.
http://www.headsuprc.com/servlet/StoreFront
http://www.bphobbies.com/view.asp?id=V815101
Wow, 3 people beat me to it with Lightflight RC!!
JMBRAD is online now Find More Posts by JMBRAD
Old Aug 13, 2009, 02:47 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
If you can lengthen the landing gear to accommodate a larger prop, a 10x7 using your present 1000 Kv motor on 21 amps should provide excellent performance. The revised projection is attached below.
Old Aug 13, 2009, 04:33 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I use the GWS 10x6HD prop on all my A20-20L motors.
If you need more power, my suggestion is the SUPPO 2814-8 with a GWS10x6HD or GWS11x7HD for outrageous performance. Max draw will be up to 28A with the 11x7.
2 Sources for the Suppo's - LightflightRC and slickzero. These motors are also sold under the Welgard name and probably others.
http://www.slickzero.com/index.html
and you already have LFRC
http://www.graysonhobby.com/catalog/...php?cPath=9_36
I like LFRC but they are out I see.
Point of reference. My 24oz biplane without battery will take off in about 10' or less with the Suppo 2814-8 and a 11x7GWSHD prop and has unlimited vertical with a well worn old 3s2500 polyquest pack.
hoppy is offline Find More Posts by hoppy
Old Aug 15, 2009, 11:01 PM
I have no friends
Joined Dec 1996
BINGO! Think I may have found the issue. I replaced the landing gear with some new gear for more ground clearance and checked the prop. Turns out I had a 9x5 on it!
Put a 10x6 on, and checked amp draw and it is 18.5 static so very nice.
Plane weighs 30.5 ready to fly so I think it will be a great sport model.
I'll report back as soon as I can get out to fly.
Slermaling and another maiden flight TomO Slope 8 Jul 07, 2005 12:20 AM
Maiden flight crashed on take off 3Dear Radios 20 May 31, 2005 01:09 AM
Newbie Dandy Sport maiden flight - Good news/bad news tridim Parkflyers 43 Feb 21, 2005 03:16 PM
another maiden flight... nose_first Parkflyers 13 Aug 23, 2003 03:57 PM
