Old Aug 26, 2009, 01:59 PM
ergocentric is offline
Find More Posts by ergocentric
Aircraft re-kitter
ergocentric's Avatar
15NM from CYYZ on 06L
Joined Feb 2007
open collector maybe?
try a 10k resistor to Vcc
ergocentric is offline Find More Posts by ergocentric
Old Aug 26, 2009, 03:13 PM
meteor is offline
Find More Posts by meteor
meteor's Avatar
Ontario, Canada
Joined Nov 2002
What would that look like in a simple circuit diagram?
I'm guessing you mean: +5V -- 10K -- PPM input on FSK module -- PPM output on radio?
Essentially, when the radio pulls the line low, the module sees low as well, thus making a 5V "negative shift" pulse train. Correct?
Thanks!
meteor is offline Find More Posts by meteor
Old Aug 26, 2009, 04:18 PM
Aircraft re-kitter
Joined Feb 2007
Thanks!
Tie the PPM line to Vcc with a 10k resistor, then scope it.
Open collector means it can only pull a signal down and you must provide pull-up at the other end, works better on long wires.
Old Aug 26, 2009, 10:08 PM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
It Works! :)
Wahoo! It Works!
Super simple. Just put a 10K from the 7805 +5V to the FSK module PPM input, and attach the Futaba PPM output (module pin 1) to the low side. (the photo is just a rough hack, but you could put the 10k across neatly the posts that tie the boards together...)
Now to fix it all up!
Have fun!
Thanks!
Old Aug 26, 2009, 10:41 PM
Aircraft re-kitter
Joined Feb 2007
Excellent work, I was thinking about using one just like it, but not modular with my corona 2.4 for boating.
I got it in a trade with some other stuff.
Old Sep 07, 2009, 08:35 PM
BenziT is offline
Find More Posts by BenziT
Singapore
Joined Mar 2007
Now I need to troubleshoot the voltage fluctuations
http://www.youtube.com/watch?v=guRmRTtsxF4
Any update on this issue ?
thanks
BenziT is offline Find More Posts by BenziT
Old Sep 08, 2009, 11:02 PM
beefcake is offline
Find More Posts by beefcake
United States, WI
Joined Apr 2002
I have an older Futaba "Magnum Jr" AM Pistol grip radio I would like to convert to 2.4. Has anyone had success with an AM radio or strictly PPM FM?
-CaKe
beefcake is offline Find More Posts by beefcake
Old Sep 09, 2009, 03:41 AM
clockworks is offline
Find More Posts by clockworks
Cornwall, UK
Joined Dec 2007
-CaKe
It's probably better to replace all the electronics, rather than just the RF board. It'll work fine, as long as the new main PCB fits in the pistolgrip case.
clockworks is offline Find More Posts by clockworks
Old Sep 09, 2009, 08:28 AM
BenziT is offline
Singapore
Joined Mar 2007
12 V or 5V
Can the hobby king take 12V or only 5V
I am thinking of using my friends old hobbyking 2.4 "daughterboard TX " and implant it into my Futaba
Cheers
Old Sep 09, 2009, 08:46 AM
Cornwall, UK
Joined Dec 2007
Cheers
The Hobbyking uses 8 AA cells, so it's designed to run on 12V. There are 2 regulators on the main PCB that take the 12V supply from the battery box and provide a 5v supplies to all the electronics. There is one regulator for the main PCB, the other is for the RF board.
If you bypass the regulators, it works fine on 4 AA rechargeable cells.
So, if you use all the electronics, you have the option to use 4 cells or 8 cells. If you just want to use the RF board to modify an existing Tx, you must use 5v.
Old Sep 09, 2009, 08:50 AM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
AM/FM is not relevant in this case, since you're dealing with the basic PPM signal before it reaches the RF stage. FYI, the 5U I tested it on was AM.
The tricky part with your radio will be finding the PPM signal. It probably exists as an output on the encoder IC.
Here's an article about converting an Attack 4, which is of a similar vintage (he also talks about a 2PL, which is a lot newer...): http://blog.quantifly.com/
Good Luck!
-CaKe
Old Sep 09, 2009, 01:21 PM
MoFl is online now
Find More Posts by MoFl
MoFl's Avatar
Espaņa, AL, Sevilla
Joined Apr 2007
Cheers
The hobbyking module can take 12 V, as it includes a board with a 5 V regulator, appart from the RF board.
The RF board at HK 4ch & 6 ch systems is designed for 5V. Maybe it can admit some margin arround 5 V because it has a 3.3 V regulator at the input, but probably not much above 5 V because it's a SMD regulator without heatsink (schematics of the RF board here).
Photos of the RF board and the module (RFboard + regulator-bind button board) here.
MoFl is online now Find More Posts by MoFl
Old Sep 09, 2009, 03:51 PM
BenziT is offline
Singapore
Joined Mar 2007
Thanks !
Old Sep 18, 2009, 03:52 PM
Aircraft re-kitter
Joined Feb 2007
I have a couple of JR beat2 AM two channel 27MHz transmitters.
Its on my to-do list
First comes the honeydo list
(when the wife sez honey, do this ...)
I also have the same radio in PCM, so it will help with the dissection and annotation (same radio, different transmitter)
Old Sep 18, 2009, 04:06 PM
Aircraft re-kitter
Joined Feb 2007
-CaKe
even better, he converts a Futaba 2PL to corona 2.4:
http://blog.quantifly.com/?p=12
seems to be offline
http://web.archive.org/web/200906150...ifly.com/?p=13
Discussion 2.4Ghz TX module and 8ch RX test woodsy Australia 11 Aug 25, 2009 07:53 PM
Discussion Assan 2.4ghz TX Module & X8R10 RX Rxgto Radios 0 Mar 08, 2009 10:29 AM
Wanted JR 2.4Ghz transmitter module JayGarcia Aircraft - General - Radio Equipment (FS/W) 6 Jun 16, 2008 10:44 AM
Question Futaba 2.4Ghz TX module and RX like2fly! Radios 6 Dec 23, 2006 08:21 AM
JR 10 Series Tx Module + 2 Rx's (Ch 57) Derek Choice Aircraft - General - Radio Equipment (FS/W) 1 May 13, 2005 09:56 PM
