Old Feb 21, 2013, 06:06 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Great graphics! Do you print on paper and than adhere to the foam?
Petefoss is offline Find More Posts by Petefoss
Old Feb 21, 2013, 06:40 AM
SoNicK is offline
Find More Posts by SoNicK
SoNicK's Avatar
The Netherlands, ZH, Zoetermeer
Joined Aug 2012
Jep, the glueing was done with cheap Hobbyglue cos the sprayglue ate my foam.
Next time i need to find some 3M-77, does probably a better job and gives a neater finish.
The paper printed on was quite thick and heavy :-(
SoNicK is offline Find More Posts by SoNicK
Old Feb 21, 2013, 06:46 AM
SoNicK is offline
SoNicK's Avatar
Joined Aug 2012
SkyCart SoNicK's design
Iff you like you can use my design,
it would be great when someone wants to build a SkyCart he can choose of multiple designs. See attached PDF.
Enjoy,
SoNicK
SkyCart_SoNicK
Old Feb 21, 2013, 07:20 AM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
SoNick
Thanks! I jumped on that and saved it right away!
I haven't gotten my SkyCart under control yet, and I think I have to redo it to get the weight out, and the new style front axle to get the angle of attack right. So If I do, it will be with your fantastic graphics!
Thanks for sharing.
dbacon is offline Find More Posts by dbacon
Old Feb 21, 2013, 07:34 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Enjoy,
SoNicK
Attachment 5555065
SoNick,
Thanks for posting the great artwork.
I added a link to your artwork in the first post of this thread.
leadfeather is offline Find More Posts by leadfeather
Old Feb 23, 2013, 05:28 AM
Hapewin is offline
Find More Posts by Hapewin
Germany, BW, Stuttgart
Joined Apr 2012
my Snoopy-Skycart is difficult to control especially landing, so I removed the wheels, and try to learn more about how to fly and get a smooth landing, and after some more succesful landings, I will put the wheels back to the skycart. But at all, its just a funny thing!
CU
Hape
Hapewin is offline Find More Posts by Hapewin
Old Feb 23, 2013, 05:40 PM
Winging it >
Joined May 2006
The rear wheels have the biggest effect on control. Being mounted on the elevons, they take some getting used to. As you can see in some of the videos, once you get the feel for the control this design it can do some great aerobatics.
Old Feb 24, 2013, 09:12 AM
Terranozavr is offline
Find More Posts by Terranozavr
Terranozavr's Avatar
Russia, near Vladivostok
Joined Jun 2008
very strong wind ~ 13-15m\s and mini crush.
обрезка (0 min 18 sec)
Terranozavr is offline Find More Posts by Terranozavr
Old Feb 24, 2013, 09:44 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Terranozavr,
You are a hearty pilot, hats off to you, AND your photographer, because that looks like some adverse weather conditions.
Old Feb 24, 2013, 10:04 AM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Ouch 30+ miles/hour wind?????
Old Feb 24, 2013, 10:22 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Pete,
I didn't realize it was 33.5 MPH, egad!
Old Feb 24, 2013, 10:26 AM
gr8flyer55 is offline
Find More Posts by gr8flyer55
Joined Dec 2012
If you use expo on aileron and elevator, what percentage gives you the best survival rate on ROG? I've seen some bad wing rock on take offs.
I'm at the point in my fff construction of the Skycart where I am making a decision which radio to use, computer mix or vtail mix plug-in board on a standard radio. My standard radio has no mix, so I opted to use the mixer board if I must. I might use the Hummer fuselage for a lower profile and less drag. Also, I am going with the drop front axle. Any construction hints for using fff? I used Fabric-Tac glue which works very well for this foam.
John
gr8flyer55 is offline Find More Posts by gr8flyer55
Old Feb 24, 2013, 02:26 PM
SoNicK is offline
SoNicK's Avatar
Joined Aug 2012
Made my maiden today, it did ROG, didn't expect it ;-) at 14 oz. He wants to backflip when it comes loose. fried my motor at the 3th time trying, . So need to get a better one. Keep you posted.
Old Feb 24, 2013, 04:03 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Here is a handy chart that may keep you from frying motors...
http://members.jcom.home.ne.jp/42232...aticthrust.htm
I put "90" in "Efficiency" and the RPM in "U/Min" but first you must calculate RPM by motor KV times cell Volts.
Old Feb 25, 2013, 01:53 AM
SoNicK is offline
SoNicK's Avatar
Joined Aug 2012
Thnx, handy tool, starts with 4S, think i will set cell voltage at 2,775V x 4 = 11.1V (3S)
It probably had to do with motor timing, only my motor or ESC can't be timed. Next time i buy programmable ESC's so i can change the timing and won't burn out.
Help! go cart muddriver Large Scale Cars 17 Dec 08, 2007 04:40 PM
For Sale bikes truck and go cart squeekbetty Cars - Cars and Parts (FS/W) 2 Jul 11, 2007 10:27 PM
Help! - Go Cart still sick, What's the cure? mrebman Life, The Universe, and Politics 8 Jun 19, 2002 10:04 PM
5HP Go Cart - Gummed up Carb, what do I do? mrebman Life, The Universe, and Politics 7 May 20, 2002 06:27 PM
