Go Back   RC Groups > Aircraft - Exotic and Special Interest > VTOLs
Old Oct 21, 2009, 08:39 PM   #61
sweet
custom t is offline Find More Posts by custom t   Reply With Quote
Old Nov 07, 2009, 02:31 PM   #62
RC Ryan's Avatar
Cool what CAD program are you using?
RC Ryan is offline Find More Posts by RC Ryan   Reply With Quote
Old Nov 07, 2009, 03:54 PM   #63
Originally Posted by Angry_Monk View Post
Im pretty sure this is so cool that its actually illegal....
I heard the real one got canceled because this RC version turned out better
RCvertt is offline Find More Posts by RCvertt   Reply With Quote
Old Nov 11, 2009, 08:47 PM   #64
Peter W's Avatar
This is the best VTOL jet project bar none, really hope you keep at it, the build quality and philosophy is brilliant and inspirational to me
Peter W is offline Find More Posts by Peter W   Reply With Quote
Old Nov 16, 2009, 11:16 AM   #65
this project seems unfortunately dead =(
jimbob00 is offline Find More Posts by jimbob00   Reply With Quote
Old Nov 16, 2009, 12:10 PM   #66
Peter W's Avatar
they can't give up on it, they've invested hundreds possibly thousands of dollars on this concept as well as tens of man hours.
PLUS I wanna see it in a stable hover sooo bad
Old Nov 16, 2009, 03:59 PM   #67
An earlier post said they would pick it back up over winter break which should be in about a month. This looks really cool but personally I'm not holding my breath for a stable hover because everything is coupled together, possibly more than what off the shelf gyros can compensate for.
bwalt822 is offline Find More Posts by bwalt822   Reply With Quote
Old Nov 16, 2009, 06:12 PM   #68
Peter W's Avatar
it HAS to work cos I want it too
just add gyros to gyros on top of gyros its gotta work!
Old Nov 17, 2009, 01:06 AM   #69
Maybe if each center of axis was pinpointed with a gyro placed there they can get away with the cross coupling...
Besides as Peter said, it HAS to work because I want it to!
EDIT: Its all speculation on speculation anyhow - we just gotta wait I guess....
ben1101 is online now Find More Posts by ben1101   Reply With Quote
Old Nov 17, 2009, 01:22 AM   #70
And if it doesn't, add one more gyro
Originally Posted by ben1101 View Post
...they can get away with the cross coupling...
What is being refered to when "cross coupling" is mentioned? Are we refering to force being unintentionally transferred to something else such as yaw affecting pitch as well or am I missing something here?
exactly, you can actually get coupling in all three axes...
Great. Thanks for the informative explaination as well. Once that thing leaves the ground it's difficult for one force not to affect multiple axes like you said. Throw in some wind and all I can say is that I'm glad I'm leaving it up to others to do most of the programming.
Old Nov 17, 2009, 07:28 PM   #71
exactly, you can actually get coupling in all three axes. Lets say you go to roll...
One of the puffers will spool up and the other will coast down. The one that spools up will accelerate faster than the one that coasts down which will impart a yaw. Also since the puffer fans are behind the CG then this asymmetric spooling will cause a pitch change.
Now lets talk about what the gyros do...
The yaw gyro senses a change in yaw and tries to correct by moving the rear main fan. This can cause a slight change in lift in the back fan resulting in a pitch change.
The pitch gyro should only control the front fan and when it spools up or coasts down to compensate for the pitch changes it causes a yaw change because the fans angular momentum changes.
Also what happens if a fan needs to spool down faster than what is possible to compensate.
Basically the gains on all gyros need to be set correctly so that they do not create a runaway feedback loop that causes instability. Even then the physical limitations of the equipment may not be able to stop it from being unstable.
Old Nov 18, 2009, 01:23 PM   #72
Peter W's Avatar
good info from bwalt thanks, so this is why vtol is soo damn hard hehe
Unread Yesterday, 01:34 PM   #73
Cant you feel the freedom
NuttyPro67's Avatar
Send a message via AIM to NuttyPro67 Send a message via MSN to NuttyPro67 Send a message via Yahoo to NuttyPro67
Ok, so once these guys solve that problem they run into a new one! He said in the first post that his finished project weight is estimated to be around 75 oz! Thats 4.5 pounds guys! Based off of my F-35 CAD models, they MIGHT have 2 sq ft TOTAL of wing area on that plane. (My calculations actually favor in the 1.5 sq ft direction).
This leaves the model with a wing loading of about 35 oz/sq ft, and thats estimating in their favor! Thats about the same wing loading of a turbine model, the stall speed on this model is going to be insane!
Good Luck fellas.
NuttyPro67 is offline Find More Posts by NuttyPro67   Reply With Quote
Unread Yesterday, 03:27 PM   #74
Peter W's Avatar
heavy vtol eh?
what fan are they using?
wonder if the 12 blade 120mm unit from schubeler would be good, it certainly sounds amaaaazing in videos so far
Unread Yesterday, 04:46 PM   #75
actually, a high stall speed will probably help with the conversion, as the wing lift will stop interfering with the direct thrust from the lift fans. However it will make conventional landings hairy to say the least. the NAVY CTOL version has an enlarged wing on the full size one
Brandano is offline Find More Posts by Brandano   Reply With Quote
Build Log F-35B Lightning II VTOL –Scale Composite Build <Updated: Aug 15> pg.4 Mustang5 Electric Ducted Fan Jet Talk 71 Nov 19, 2009 08:02 AM
Build Log F-22 1/12 scale Composite build kanji Electric Ducted Fan Jet Talk 139 Nov 18, 2009 08:38 PM
Discussion New Ducted Fan for F-35 Lightning II L0stS0ul Banana Hobby 3 Mar 05, 2009 05:11 PM
Discussion Tamjets 1:8 scale composite F-16 EDF video Tamjets Electric Ducted Fan Jet Talk 71 Dec 10, 2007 08:27 PM
Idea Mr. Lin this should be your next plane to built the F-35 Lightning II wedge98 GWS (Grand Wing Servo) 7 Feb 03, 2007 06:15 PM
Bored? Want to fight?
Join the RCGroups clan!
