Go Back   RC Groups > Aircraft - Exotic and Special Interest > VTOLs
Old Aug 18, 2009, 04:48 PM   #31
Although the main risk I see to this project is if the response time of the motors is too slow. In other words, the gyros should be able to detect any uncommanded change in attitude fast enough but the ESC/Motor/Propellor system may not be able to spool up or slow down fast enough.
bwalt822 is offline Find More Posts by bwalt822   Reply With Quote
Old Aug 18, 2009, 04:59 PM   #32
I ABUSE LIPO'S
cray2602's Avatar
The problems ive always experienced is that the response from the EDF is usually too abrupt and it over corrects and ends up in an oscilation. No amount of tweaking and EXPO could stop it. But that is with the cheapo GWS mixers, from the roll control video posted id say thats not a problem with their build. Looks rock solid so far.
cray2602 is offline Find More Posts by cray2602   Reply With Quote
Old Aug 18, 2009, 08:25 PM   #33
See post #13 in this thread for a link to a 4 EDF VTOL that flew incredibly well! Proof that it can be done, this one should fly as well if it is light enough.
capt is offline Find More Posts by capt   Reply With Quote
Old Aug 18, 2009, 10:08 PM   #34
That plane did not look capable of conventional flight and was mostly symmetric which helps things out a little.
The only VTOL that I have seen that was capable of transition looked like a modified Cessna 182 and the plane hung far below the two props giving it more stability.
Old Aug 19, 2009, 07:19 AM   #35
Again and again... the pendulum effect is an illusion, the vectors of thrust tilt with the plane. Putting the rotors away from the CG only help with control authority. And even then only if you put the tilt point away from the CG
Brandano is offline Find More Posts by Brandano   Reply With Quote
Old Aug 19, 2009, 08:34 AM   #36
Nice modelling!
G-force237 how did you come up with the 3d model outline? Did you find a drawing with fuselage cross sections that the rest of us can't seem to find??!! I am working on my own version of the F-35B, but can't find any drawings except for 3 views and model renderings.
vertigo-rc is offline Find More Posts by vertigo-rc   Reply With Quote
Old Aug 19, 2009, 09:30 AM   #37
if multi edf is a problem, one could direct the airflow from one big edf to the sides as well with small traps that u can open/close )
jimbob00 is offline Find More Posts by jimbob00   Reply With Quote
Old Aug 19, 2009, 01:05 PM   #38
Have you seen this? http://verti4.blogspot.com/
Checkout the video.
Best Regards,
=Adrian=
adavis is offline Find More Posts by adavis   Reply With Quote
Old Aug 19, 2009, 02:19 PM   #39
now that i think about that, you are right.
Old Aug 19, 2009, 03:57 PM   #40
This guy did it. Theres also a vid of him flying it outside where he transitions into foward flight... I cant find it though.
rc edf vtol (1 min 25 sec)
bigwood212 is offline Find More Posts by bigwood212   Reply With Quote
Old Aug 20, 2009, 03:40 PM   #41
Sky-walker's Avatar
rc edf vtol (0 min 33 sec)
Sky-walker is offline Find More Posts by Sky-walker   Reply With Quote
Old Aug 21, 2009, 04:38 AM   #42
Great thread
Great work GFORCE, i look forward to following your ambitios project.
Keep up the good work and good luck.
matthew73 is offline Find More Posts by matthew73   Reply With Quote
Old Aug 21, 2009, 07:27 PM   #43
Roll Posts not on CG
I noticed this when planning my own F-35. When calculating the CG of the aircraft (assuming placing the CG at 25% MAC) I noticed that the distance from the CG to the lift fan and to the 3 bearing nozzle at the rear when in hover mode is the same (as expected), but it seems that the roll nozzles are not located on the CG but are somewhat aft. Does anyone know why this is? I realize that on the real F-35 the CG wouldn't be placed at 25%...there would definitely be a lot less static margin in order to increase maneuverability, but I don't see how the CG could be in line with the roll posts? To make a perfectly scale F-35B you would have to cope with the pitch coupling caused by having the roll posts aft of the CG. Anyone have any theories?
  • Name: CG.jpg
Description: Roll Post Location???? Roll Post Location???? 45.9 KB · Views: 373
Old Aug 21, 2009, 07:36 PM   #44
Oops
I somewhat just answered my own question just as I posted the previous message!! It seems I was assuming that the F-35B was a flying wing! I neglected to take the tail surface area into account, which has it's own aerodynamic center which will shift the neutral point of the whole aircraft (and thus the allowable CG position) rearwards!!! I wonder where those roll posts lie with respect to the CG now????
By the way...very nice job so far! Can't wait to see you hover and then finally transition this machine("fingers crossed")!!
Old Aug 22, 2009, 07:12 AM   #45
Seaplane submariner
This is sweet!
Looking forward to see the plane competed (soon?)!
jeeeeeeright is offline Find More Posts by jeeeeeeright   Reply With Quote
Build Log F-35B Lightning II VTOL –Scale Composite Build <Updated: Aug 15> pg.4 Mustang5 Electric Ducted Fan Jet Talk 71 Nov 19, 2009 08:02 AM
Build Log F-22 1/12 scale Composite build kanji Electric Ducted Fan Jet Talk 139 Nov 18, 2009 08:38 PM
Discussion New Ducted Fan for F-35 Lightning II L0stS0ul Banana Hobby 3 Mar 05, 2009 05:11 PM
Discussion Tamjets 1:8 scale composite F-16 EDF video Tamjets Electric Ducted Fan Jet Talk 71 Dec 10, 2007 08:27 PM
Idea Mr. Lin this should be your next plane to built the F-35 Lightning II wedge98 GWS (Grand Wing Servo) 7 Feb 03, 2007 06:15 PM
Bored? Want to fight?
Join the RCGroups clan!
