Go Back   RC Groups > Aircraft - Exotic and Special Interest > VTOLs
Old Aug 15, 2009, 06:05 PM   #16
Excellent work! How dod you make the mold? did you use anothe plane?
capt is offline Find More Posts by capt   Reply With Quote
Old Aug 15, 2009, 06:40 PM   #17
I ABUSE LIPO'S
cray2602's Avatar
Wow, very nice. This is definately the most elaborate attempt at a real VTOL ive seen yet.
Your gyros are working much better than what i have. I left the 40mm fans near the wing roots and moved the batterys to the top of the plank and they worked just fine. The weight was just to low which put the vertical CG to far down. I think i might shelf mine for now and just keep an eye on how yours comes along. I spent all morning tuneing and tweaking my test board with all components installed and just cant get it right. Everything works perfectly but just cant maintain control after an input is given. The correction from the gyros is either too little or too much and they end up oscilating the airframe violently.
Looks like you guys are well on your way. Good luck.
cray2602 is offline Find More Posts by cray2602   Reply With Quote
Old Aug 15, 2009, 07:57 PM   #18
I Can Fly An FP Inverted!
Hal_The_Hacker's Avatar
Send a message via MSN to Hal_The_Hacker
wow this is the best looking f-35 I have come across so far!
nice work, I will be following this thread closely
Hal_The_Hacker is offline Find More Posts by Hal_The_Hacker   Reply With Quote
Old Aug 15, 2009, 11:48 PM   #19
Here Capt, a whole thread on how we made the mold
http://www.rcgroups.com/forums/showthread.php?t=891668
Cray are you using rate gain or heading hold gyros? I would think if your plane is oscelating around a point then the gain is set to high? If its too low I would think the gyro would just not correct enough and the plane would roll over? The other thought is maybe there is noise in the system. Before we ordered the SM2 mixers we had tried basic tests with a GWS v-tail (vtailed with raw throttle in the elevator input and gyro corrected ailerons in the aileron input) and found that the mixer could not cope with mixing the high frequency gyro signal inputs with the lower frequency radio inputs. What we saw were jittery 'noisey' outputs from the vtail. it wasnt apparent with the motors as it sounded like the pulsing was caused by minute corrections from the gyro, but after pluging servos in place of the esc's it was obveous that the signal contained a lot of artifacts from the v-tail mixing. This was the reasion we went with the SM2 mixers. They can cope with mixing the high frequency gyro outputs with the lower frequency reciever outputs. So I dont know if you are using any mixers on your rig, but it may be somewhere to look?
G-force237 is offline Find More Posts by G-force237   Reply With Quote
Old Aug 16, 2009, 12:59 PM   #20
I ABUSE LIPO'S
cray2602's Avatar
Thats probably what my problem is. I am useing the GWS V-tail mixers and my gyros are set to gain mode. Thanks for the info. Im just gonna sit back and watch how your experiment comes out for now.
Old Aug 16, 2009, 04:16 PM   #21
Team30 Micro EDF
NitroCharged's Avatar
Send a message via MSN to NitroCharged
Agreed - those GWS and Turnigy V-tail mixers only have a 200 resolution so they are very steppy (therefore inaccurate). The SM2 mixer has a resolution of ~620 and is so smooth - you can't tell it's there.
NitroCharged is offline Find More Posts by NitroCharged   Reply With Quote
Old Aug 16, 2009, 11:52 PM   #22
check my BLOG
foam and tape's Avatar
subscribed... i've never seen someone work as quick as you before looks great (probibly going to be the first acutal r/c F-35 to transition from hover to forward flight)
best of luck to ya
foam and tape is offline Find More Posts by foam and tape   Reply With Quote
Old Aug 18, 2009, 10:49 AM   #23
Sky-walker's Avatar
Originally Posted by member2006
Awesome I thought that was the real thing
As far as airflow loss, it shouldn't be much of a problem. I've messed around with 90 degree tube bends (1 lb model w/vasa fan 65mm and mega motor 2:1 ) and there doesn't seem to be much airflow turbulence. Just make sure you have the the thrust which these guys seem to have.
I see, but I dont mean the "amount of angle" that is the problem but the smoothness of the bend. I believe that if the 90 degree bend was smooth - (like taking a soft tube or something and bend it)- the efficiency will go without problems up to 88%-90% of the initial thrust of the EDF. But offcourse it is very hard to have a "rotatble tube" and therefore a rotatable swivle- parts-device is better.
Sky-walker is offline Find More Posts by Sky-walker   Reply With Quote
Old Aug 18, 2009, 11:18 AM   #24
F-111 John's Avatar
If it really became an issue of needing every last ounce of thrust during hover, I suppose the center section of the swivel assembly could be curved to maximize efficiency in the hover mode, and just live with the kink in the tailpipe in the conventional flight mode, where the thrust would be less efficient but probably still more than adequate for flight.
F-111 John is offline Find More Posts by F-111 John   Reply With Quote
Old Aug 18, 2009, 11:52 AM   #25
Sky-walker's Avatar
that might be a good solution but, when the rear part rotates.. problems might occure at the curved place
Old Aug 18, 2009, 12:46 PM   #26
I ABUSE LIPO'S
cray2602's Avatar
The biggest problem i can see is that the front and rear lift points will have different amounts of thrust because the rear fans thrust will lose a certain amount of thrust from the ducting. When throttle is increased the front will generate more lift than the rear and the difference will increase with each increase of throttle. A different way of looking at it is if you had more lift from the left wing fan as oposed to the right wing fan. It would be a challenge to control it i would think. But maybe not, i suspect we will soon find out either way.
Old Aug 18, 2009, 01:16 PM   #27
Sky-walker's Avatar
playing with c.g should solve this issue
Old Aug 18, 2009, 03:31 PM   #28
F-111 John's Avatar
True, there might be clearance issues inside the fuselage.
Old Aug 18, 2009, 04:11 PM   #29
I ABUSE LIPO'S
cray2602's Avatar
The thrust changes wont be linear with throttle increases, the front and rear fans will vary in thrust output as throttle increases or decreases because of the ducting. What im trying to say is at 1/2 throttle there might be a 6% loss in eficiency at the rear but at 3/4 throttle there might be a 12% loss. But this could be a mute point, a little tweaking or mixing might resolve it if the gyro doesnt. Im interested to see the results with this build.
Old Aug 18, 2009, 04:35 PM   #30
A gyro should be able to take care of this fact. All the input will be to throttle up to hover higher and the gyro should be able to compensate pitch to make that happen.
bwalt822 is online now Find More Posts by bwalt822   Reply With Quote
Build Log F-35B Lightning II VTOL –Scale Composite Build <Updated: Aug 15> pg.4 Mustang5 Electric Ducted Fan Jet Talk 71 Nov 19, 2009 08:02 AM
Build Log F-22 1/12 scale Composite build kanji Electric Ducted Fan Jet Talk 139 Nov 18, 2009 08:38 PM
Discussion New Ducted Fan for F-35 Lightning II L0stS0ul Banana Hobby 3 Mar 05, 2009 05:11 PM
Discussion Tamjets 1:8 scale composite F-16 EDF video Tamjets Electric Ducted Fan Jet Talk 71 Dec 10, 2007 08:27 PM
Idea Mr. Lin this should be your next plane to built the F-35 Lightning II wedge98 GWS (Grand Wing Servo) 7 Feb 03, 2007 06:15 PM
Bored? Want to fight?
Join the RCGroups clan!
