Old Aug 10, 2009, 04:32 PM
mark2910 is offline
Find More Posts by mark2910
Joined Aug 2009
Help!
Im trying to find out if i could put brushless motors in my cheap rc stealth boat
http://www.amazon.co.uk/Radio-contro...9938992&sr=8-1
One Stealth Ultra Fast Boat
Finished in black
2x 380 racing motors
Speed of 30 km/h
Range of 30 metres
2x high torsion propellers and spares
Propellers stop when removed from water
Radio controller handset
1x set of transfers
Suitable for age 12 years and up
Size: Stealth Ultra Fast Boat L 70.0 cm
its ok but i would like to install brushless motors but when ive read up a little
its going to be harder than i thought lol
im not planning on spending a lot want it to go a bit quicker and a bit of an experiment for me as iam all new to this ive watched some you tube vids and there are some unbelevable speeds comming from electric brushless motors
im just wondering would
2 ( X2PRO Brushless Inrunner motor B3540-16 KV4000 with 45a esc and would i need to buy 2 esc's
these motors are very cheap from ebay item :260455746917
would they be better than 2 brushed 380 motors if i somehow made them fit
i think there a bit big
Dimension: ¢36.0X40(mm)
Shaft: ¢3.175/¢5X12.0(mm)
Weight: 182g
could anyone tell me if there worth buying
any help/comments would be appreciated thanks
mark2910 is offline Find More Posts by mark2910
Old Aug 10, 2009, 05:57 PM
Rex R is offline
Find More Posts by Rex R
Joined Nov 2005
I suspect that by the time you've gotten it running with new motors, you'll have replaced nearly everything but the hull. however were I to remotor it, methinks I'd try a pair of graupner speed 400's(brushed) or if I were to go brushless a pair of feigao 380L 12t or 10t motors(would probably have to change at a minimum the motor/drive shaft couplers, if not the drive shafts).
yes for brushless motors you need one esc per motor
quite likely one could get the boat up to 20-25mph before having handling issues
Rex R is offline Find More Posts by Rex R
Old Aug 10, 2009, 05:58 PM
group11 is offline
Find More Posts by group11
Joined Jun 2009
I wouldn't touch it with a very, very long pole.
group11 is offline Find More Posts by group11
Old Aug 10, 2009, 06:12 PM
Rex R is offline
Joined Nov 2005
lol. problem is, he did.
Old Aug 10, 2009, 06:17 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
For a fast fix. You can get a big leap in run time and extra speed (save weight) going with a 2S lipoly cells 2200mah would do it.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Aug 11, 2009, 01:02 AM
MarcRacer18 is offline
Find More Posts by MarcRacer18
Studying Engineer
MarcRacer18's Avatar
United States, CA, Santa Barbara
Joined Jun 2009
I've heard of people puting brushless motors in the stealth before but the prob is geting the right drive gear in it. My neighbors stealth goes prety good on just a six cell nimh.
Maby upgrade to 380 brushless size motors with water cool and mabe a 14.8 Lipo pack. Will look cool!
MarcRacer18 is offline Find More Posts by MarcRacer18
Old Aug 11, 2009, 03:32 AM
mark2910 is offline
Joined Aug 2009
thanks people i havn't touched it yet im just glad i didnt before i asked on here ive read other posts on people building boats and i know you all have a very good knowledge im thankfull for any advice that will get most speed without blowing my motors up or being too quick too handle and sinking and me having to swim for it as my little lad wouldnt be too pleased leaving it in the pond lol so 2 graupner speed 400's(brushed) would fit in mounts without me having to get a new 1s and would it run better with the 7.2 nimh or 2S lipoly
Old Aug 11, 2009, 03:39 AM
mark2910 is offline
Joined Aug 2009
without having to get new mounts i meant ^ sos for being thick but you will never get knowhere without learning from someone who knows what there talking about
Old Aug 11, 2009, 03:41 AM
mark2910 is offline
Joined Aug 2009
http://www.howesmodels.co.uk/RadioCo...p?SubCatID=111
could any 1 tell me which 1 of these motors would be best to get more speed and would i still have to change my esc's if i got brushed motors ive found the
graupner speed 400's(brushed) very cheap i think in link above
http://www.alwayshobbies.com/Store/M...lectric-Motors
and a bit cheaper ^
Old Aug 11, 2009, 04:00 AM
Rex R is offline
Joined Nov 2005
a pair of either the speed 400 6v or the 7.2v should work nicely. you might not see a large increase in speed, but you ought to see a notable drop in motor temp.
i was wondering how do i find out if there are any events in my area Evil_Genius Electric Flight Events 4 Apr 28, 2005 06:14 AM
Trying to find out the difference between HM-90-Acro and HM-FAI 135 Splash Power Systems 1 Apr 20, 2005 10:27 PM
Im Trying To Find 200mm Body(Painted) smitty413 Car Talk 5 Jul 08, 2004 10:54 PM
Need to find out if this will fly my DR1...... randall1959 Power Systems 3 Jul 08, 2004 01:16 PM
