Old Apr 11, 2003, 05:39 PM
mike98624 is offline
Find More Posts by mike98624
Fly like an... airplane?
mike98624's Avatar
Milford, NJ
Joined Oct 2002
DYMOND SUPER TURBO on 75 AMPS?!?! WILL I FRY MY CHARGER?
Hey everyone,
I just recieved a 75 amp AC to DC power supply from my uncle who is a surplus dealer in Vermont. The Dymond Super Turbo charger manual says that it will take input voltages of 7 amps and up. will it take 75 amps or will i kill it as soon as i plug it in? thanx!
mike
mike98624 is offline Find More Posts by mike98624
Old Apr 11, 2003, 06:34 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Re: DYMOND SUPER TURBO on 75 AMPS?!?! WILL I FRY MY CHARGER?
Originally posted by mike98624
Hey everyone,
mike
The Dymond Super Turbo Charger specs say that it needs an input voltage between 9 and 14 volts. You didn't say what voltage your 75 amp power supply is but if I had to guess I'd say it was 12 volts. In your case this is what you really need to worry about, not the amps. As long as the power supply's voltage is within the 9 to 14 volt range required by your charger it will work just fine. There won't be any danger of overload. When it comes to amps, the charger could overload the power supply, but not vice versa. The power supply's 75 amps is just something that's available if it's needed by whatever device is drawing power from it.
The web site doesn't say how much current the charger requires, but since it charges at 5 amps maximum, it probably doesn't draw more than 10 to 20 amps at the most, and that would be only when charging extremely large numbers of cells at once. In any event your power supply will have way more current capability than you'll need, which is perfectly okay.
The big danger is in making sure that everything is hooked up properly. If you make a mistake, that 75 amp power supply is capable of putting on quite a fireworks display.
Miami Mike is offline Find More Posts by Miami Mike
Old Apr 11, 2003, 06:35 PM
mike98624's Avatar
Milford, NJ
Joined Oct 2002
it is a todd engineering 75 amp. model PC75B. serial # 75B20604355 just in case that helps. i couldn't find any info on it but maybe someone knows about it...
mike
Old Apr 11, 2003, 07:19 PM
rkramer is offline
Find More Posts by rkramer
Frequent flyer
Grand Forks, ND
Joined Aug 2002
todd engineering is no longer around, but they made some really great power supplies used by hams. Wouldn't hurt to verify the voltage with a meter before hooking it up.
rkramer is offline Find More Posts by rkramer
mike98624's Avatar
Milford, NJ
Joined Oct 2002
the output is 13.14 v. (measured w/ digital voltmeter). not going to measure the amps with any ampmeter i have (they are all too low on capacity). so i guess i will go check it out... i will report back l8er. figuring out how to hook it up is easy, red=positive white=negative green=chassis ground.
mike
Old Apr 11, 2003, 08:50 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
What it means is that the PS is capable of supplying 75 amps. Your charger will only load up to 7. Volts sound fine. Plug in and go.
YMMV
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Apr 11, 2003, 08:58 PM
mike98624's Avatar
Milford, NJ
Joined Oct 2002
i just tried it and... SUCCESS! it works great! i had checked the output amps when i first got it in comparison to the readings on the screen, and they were a little low in reality. now they are exact! its great! thanx for all the help guys. no more constantly recharging lead acids so i can charge yet more batteries off that!
mike
Old Apr 11, 2003, 09:06 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Couple of welding leads and you got yourself a pretty versatile machine.
William A is offline Find More Posts by William A
Old Apr 12, 2003, 12:15 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
That brings up a fairly interesting qustion. I have a 155 amp MIG welder. If i plug it into my charger, will it fry?
Comatose is offline Find More Posts by Comatose
Old Apr 12, 2003, 01:50 PM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Originally posted by Comatose
will it fry?
Not just fry, but also pop, sizzle, smoke, poof and maybe even a little dance.
Old Apr 12, 2003, 02:23 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You probably have a 200A supply for your house. Are you worried about plugging your 60W tablelamp into that 200A source? BUT, there is one thing I would do!!! Put a 10A fuse in one of the leads from your power supply to your charger. If you do have a short in your charger, you wouldn't want to dump 75A into it. On the other hand, some of these high quality ham radio power supplies have a dial for limiting the A output....you just dial the max amps you want the power supply to deliver.
hoppy
hoppy is offline Find More Posts by hoppy
Any comments on the Dymond Super Turbo Charger? neonbutterfly Batteries and Chargers 14 Mar 17, 2003 07:49 AM
Fixed buttons on Dymond Super Turbo Charger pullin-gs Batteries and Chargers 0 Jan 27, 2003 10:10 AM
Dymond Super Turbo Charger dave_lilley Electric Plane Talk 26 Apr 24, 2002 02:33 PM
WooHoo! I got my Dymond Super Turbo Charger rtideas Electric Plane Talk 30 Jan 30, 2002 07:30 AM
Dymond Super-Turbo charger gjestico Electric Plane Talk 13 Dec 27, 2001 12:36 PM
