Old Aug 10, 2009, 10:43 AM
rcxmachines is offline
Find More Posts by rcxmachines
Joined Aug 2009
Cool
Sbach 342 - The wait is over!! FINALLY RC!
RC- Xtreme Machines are proud to present the first RC 30% Sbach 342 ARF.
RC-Xtreme Machines is based in Pakistan. We have been producing planes in the local market for over 16 years. We finally decided to expand and become a global manufacturer and what better plane to do it with other then the SBACH 342. Our hats off to the designer and flyer of the full scale SBACH 342 Mr. Phillip Steinbach. Not only is his plane one of the most beautiful performing pane, but his aerobatics routines on it are simply breath taking. The moment I first saw the plane I decided to build one. We quickly made the prototype and flew it in April this year and we knew then we had something special.
After successfully testing the prototype we started to develop our production models and finally after many sleepless nights and hot flying sessions it is ready.
The Specifications of 30% Sbach 342
Dimensions:
Wing Span: 89 inches
Wing Area: 1585 Sq inches
Fuselage Length (including spinner): 80 inches
Stab Span: 38 inches
Flying Weight: 16 – 16.5 lbs
Wing Loading: 23.27 oz/sq inch
Engine Recommendations: 50 cc – 60 cc Gasoline Engine.
Features:
The whole kit including the design of the aircraft has the single purpose to make the plane perform unlike any other aerobatic RC plane. It should not simply look like the Sbach 342 but also perform like it. The internal design concept, helps make the plane xtremely (couldn’t help myself!) light weight and rigid. The plane has all balsa sides, premium grade plywood parts, carbon fiber parts and Kevlar hinges.
Composite Parts:
1. Carbon Fiber Spinner
2. Fiber Glass Cowl with Carbon fiber reinforcements.
3. Carbon fiber/balsa firewall.
4. Carbon fiber firewall L-Bracket support.
5. Carbon fiber Fuselage wing rib – part of the new design concept.
6. Carbon fiber base plate/rudder servo plate- part of the new design concept.
7. Carbon fiber L supports at various places in the fuselage.
8. Carbon fiber Latch mechanism for hinged canopy!
9. Carbon fiber Wing tube.
10. Carbon fiber dowels.
11. Carbon fiber tail tube.
12. Carbon-Kevlar Main Landing Gear.
13. Carbon fiber reinforcement of landing gear plates.
14. Carbon fiber tail landing gear.
15. Fiber glass wheel pants.
16. Carbon fiber push rods.
17. Carbon fiber Servo control arms including a whopper 5 inch rudder servo arm.
18. All Carbon fiber Control horns.
19. Kevlar Hinges
Most of hardware is custom carbon composite as you can see from the list but other stuff that is included in the kit includes
1. Dubro Wheels (Mains and tail)
2. Dubro tygon extra large fuel tubing
3. Dubro Ball links on all our carbon push rods
4. Dubro Fuel tank converted for gasoline operations.
5. All nuts and bolts are included to complete the kit.
6. Also included will be a template to cut the covering in case you want to
epoxy your plug-in stabs in place. Which we recommend doing.
7. Detailed/entertaining instruction manual.
8. The plane is Pre-hinged (Glued).
9. Covered in Ora cover.
Additional Features.
The canopy is hinged. Makes it whole lot easier plus that’s the way it’s on the real thing
I hope you enjoyed the brief introduction to our plane.
As aero-modelers we have tried to incorporate what we have learn over the last 18 years or so into a plane that is a joy in the air as well as on the ground. We feel ‘the experience’ of an ARF start as soon as you open the box. We have put in a lot of thought process and hard work to make sure that every step from opening the packaging to the perfect soft landing exactly in the middle of the runway is a pleasure and a joy.
Each plane is assembled before putting it in the box. At this stage the wing and stab incidences are checked making sure they are correct, no plane can leave the factory if the final tests are not cleared. In fact at each stage of assembly the builder signs off on his work, so when a plane finally goes in the box we guarantee all parts will fit together as they should and the plane will be true and straight.
When designing the plane all the bolts and screws on this plane are placed at locations that are comfortable to work on. So no tighter cowl bolts that you have to reach way inside to tighten or wing bolts that should have been just a inch away from the former or the fuel tank.
These are just some examples of the attention to detail that have been put in this aircraft. With no compromise on quality and performance and using only the very best materials for the construction we promise you a model unlike any other in both build quality and flying performance.
THE KIT WILL BE AVAILABLE WITH THE DEALERS SOON.As we are in the process of finalising our distribution
rcxmachines is offline Find More Posts by rcxmachines
Old Aug 10, 2009, 05:00 PM
800mZero is offline
Find More Posts by 800mZero
3DHS Junkie
800mZero's Avatar
Rhode Island
Joined Jun 2005
awesome!
800mZero is offline Find More Posts by 800mZero
Old Aug 10, 2009, 05:09 PM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
Impressive.
Hope you can do an electric version for us....
Flazo is offline Find More Posts by Flazo
Old Aug 10, 2009, 05:22 PM
bouncebk2003 is offline
Find More Posts by bouncebk2003
bouncebk2003's Avatar
Minneapolis,MN.
Joined Mar 2006
Originally Posted by flazo
Impressive.
I would love to have a 25E version.Or one that was around 40"-45"
bouncebk2003 is offline Find More Posts by bouncebk2003
Old Aug 10, 2009, 05:38 PM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
subscribed
flyracer is offline Find More Posts by flyracer
Old Aug 10, 2009, 05:51 PM
Cessna_Flyer is offline
Find More Posts by Cessna_Flyer
Tulsa Oklahoma
Joined Nov 2008
Any idea on the price?? And I just picked up my real sbach from sloair about 3 weeks ago.
Cessna_Flyer is offline Find More Posts by Cessna_Flyer
Old Aug 10, 2009, 08:29 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Subscribing...... and drooling......
chalmrast is offline Find More Posts by chalmrast
Old Aug 10, 2009, 08:33 PM
flyinghigh is offline
Find More Posts by flyinghigh
TDI Abuser
flyinghigh's Avatar
Joined Sep 2002
Ditto!
flyinghigh is offline Find More Posts by flyinghigh
Old Aug 10, 2009, 09:44 PM
Tulsa Oklahoma
Joined Nov 2008
Ditto?
Old Aug 10, 2009, 10:28 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
just simply awesome! i so want one!
MustangAce17 is offline Find More Posts by MustangAce17
Old Aug 10, 2009, 10:44 PM
zypher9 is offline
Find More Posts by zypher9
A piece of sublime engineering
Malaysia
Joined Nov 2008
subscribing too.. any price indication?
zypher9 is offline Find More Posts by zypher9
Old Aug 10, 2009, 10:50 PM
Tulsa Oklahoma
Joined Nov 2008
I dont think so. Cant find any info on the manufactuer
Old Aug 10, 2009, 11:23 PM
FD Pilot is offline
Find More Posts by FD Pilot
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
To re-use a famous phrase "I gotta get me one of these"
FD Pilot is offline Find More Posts by FD Pilot
Old Aug 10, 2009, 11:28 PM
metaltrg is offline
Find More Posts by metaltrg
Joined Mar 2009
ditto?
metaltrg is offline Find More Posts by metaltrg
Old Aug 11, 2009, 12:02 AM
parkfly27 is offline
Find More Posts by parkfly27
that's how i roll!!
parkfly27's Avatar
United States, AZ, Scottsdale
Joined Feb 2008
Now that is one slick-looking airplane! Good for 3000-4000 watt electric i expect. Probably way out of my price range tho...
parkfly27 is offline Find More Posts by parkfly27
Discussion Two Seat Sbach 342 james-bai Fuel Plane Talk 1 Jul 21, 2009 12:05 AM
Complaint Another site pulling threads over from RC Groups rcminiman Site Suggestions / Complaints 2 Jun 18, 2007 10:54 AM
New Product The wait is over..Multiplex Mini Mag is here at BP Hobbies Snow Bird PA-FL Hot Online Deals 1 Oct 11, 2006 12:40 PM
Finally, RC bikes!!! Kev71H Motorcycles 133 Jan 24, 2004 09:46 PM
Just came over to rc groups Ray Fuller Racing Boats - Electric 30 Mar 10, 2003 07:58 PM
