Old Aug 10, 2009, 10:40 AM
Disarray is online now
Find More Posts by Disarray
Disarray's Avatar
United States, GA, Gray
Joined Apr 2007
45cc delta wing rebuild
Well, I am rebuilding my coroplast delta wing. This is what it used to look like:
This is what it looked like when I opened the plane up. It is amazing how busted up on the inside it was:
Here are the bones of the new one:
Disarray is online now Find More Posts by Disarray
Old Aug 10, 2009, 11:39 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
it sort of leaves one speechless as to how much was left to keep the wings from folding up. amazing. Tough stuff that coroplast is.
Looks like it will have a lot less flexing now.
Nice plane.
You were lucky, around here, we only had small politcal signs. They didn't have any big ones for me to snag. Either that or someone beat me to them.
earlwb is offline Find More Posts by earlwb
Old Aug 10, 2009, 12:17 PM
Disarray's Avatar
Joined Apr 2007
Ha, you misunderstand, the damage was done by the impact, not a failure in the air. No way that thing could have flown if the spars were broken.
Old Mar 13, 2010, 11:01 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I was curious as to if you got your new delta flying or not.
About where did you set the CG for it? Did you use the entire 4x8 foot sheet of coroplast for it?
I got lucky and snagged a few big 4x8 foot sheets after our local primaries this year. So I am trying to decide what to build with them. I happen to have a magneto 25cc and a 32 cc RC gasoline engine I could use on one of these maybe. The 25cc is cool as it has crankcase mounting lugs like a regular glow engine has.
Old Mar 13, 2010, 08:43 PM
Disarray's Avatar
Joined Apr 2007
Ya, the delta flys and it is a full 4x8 sheet, so I have 16 square feet of wing area. Iirc, the cg is at 18" from the nose of the plane, but I will double check when I go out to the garage.
And if your's comes out anywhere near as heavy as mine, I suspect 32cc may not be enough to do much more than fly in a circle. My 45 labors hard to pull it.
Old Mar 13, 2010, 10:16 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Thanks for the info, I appreciate it.
I do have a 50cc engine with CDI ignition, I just sort of like the magneto ignition, even if it weighs more, for its simplicity.
Old Mar 24, 2010, 09:48 PM
Wayne V is offline
Find More Posts by Wayne V
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
How much does it weigh ?
Wayne V is offline Find More Posts by Wayne V
Old Mar 24, 2010, 10:03 PM
Disarray's Avatar
Joined Apr 2007
25 to 30 pounds, never have weighed it. It does float like a dream though.
Old Apr 12, 2010, 12:59 PM
Disarray's Avatar
Joined Apr 2007
Just adding a pic
Old Apr 15, 2010, 07:58 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
It is looking nice. Did you use elevons or elevator/aileron setup for the control surfaces?
I can see separating the control surfaces to help control unwanted flexing but still use elevons.
Old Apr 15, 2010, 08:56 AM
Disarray's Avatar
Joined Apr 2007
Yes it uses elevons. I wanted to use 4 servos for some redundancy.
Old Apr 15, 2010, 02:56 PM
jamiejig is offline
Find More Posts by jamiejig
Joined Nov 2005
what glue was used in the rebuild
jamiejig is offline Find More Posts by jamiejig
Old Apr 15, 2010, 05:38 PM
Disarray's Avatar
Joined Apr 2007
Hot glue on the lower half and gorilla glue on the upper.
Old Apr 16, 2010, 03:13 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yeah the redundancy is a great idea. Also splitting up the control surfaces like that reduces the flexing that might occur with a long single surface, so it would have more stiff control surfaces then.
Old May 02, 2010, 10:23 PM
Disarray's Avatar
Joined Apr 2007
The wing tips fluttered wildly during a high speed pass. I need to figure out a way to strengthen the section that extends out past the spar.
Anyone fly the Foxbat delta wing pusher? sticktime Foamies (Kits) 26 Feb 21, 2005 08:34 AM
How to estimate CG on a Delta wing leftysdeceiver Electric Plane Talk 4 Oct 07, 2001 09:10 AM
DeltaSTAR 500 Electric Delta Wing Gary L Trapp Jr Aircraft - Electric - Airplanes (FS/W) 0 Sep 29, 2001 05:03 PM
60 Delta wing... exowatt Foamies (Kits) 5 Jul 20, 2001 03:54 AM
Looking for delta wing foamie sloper Ben74 Foamies (Kits) 3 Jul 09, 2001 12:12 PM
