Germany
Joined Dec 2009
This is the one you use with the original Walkera grips:
http://www.helischrauber.de/shop/pro...roducts_id=470 This one is only working with the Skytec grips: http://www.helischrauber.de/shop/pro...roducts_id=137 Timo |
Canada's Wet Coast
Joined Jul 2008
Mel |
portsmouth uk
Joined Jan 2010
wouldn't it be nice to just by a heli and fly it straight out of the box and not have to mod it to make it do what it should do in the first place?
![]() sure, buy mods for it to improve what you have but not to make it what it should be in the first place? if that makes sense
Canada's Wet Coast
Joined Jul 2008
Want something more challenging for the same money? Try a CB180D, Blade mSR or maybe the new Blade SR. I have the first two, I'd still rather fly the 400D (more relaxing; the mSR can make coffee nervous)... Maybe we expect too much from some budget priced model coaxials that are really designed to hover for just about anyone out of the box and they are limited on purpose to keep pilots out of the trouble. The new L3 is the only one that doesn't really fit into what I'd class as "budget". The price, performance and target audience don't seem to really jive in my mind. But then at best my mind is a cobweb collector... ![]() ![]() ![]() Mel |
portsmouth uk
Joined Jan 2010
![]() till then i will just keep eating the popcorn till i sell off some of my gliders etc to raise the cashSimon |
Canada's Wet Coast
Joined Jul 2008
If I were a betting man, I'd still tend to favour that Marks twin brushless 400D would perform as good or better than the L3 even with it's mods. And maybe even cost less... ![]() For my 400D, I WISH it had one more channel on the RX. Something I could use with my 2801 Pro so I could run anything from light switches to whatever. Just one more servo would be a gas to come up with stuff for it to do. But I think the only way to do that is to replace the RX, then add in a gyro and somehow make it all work. I'm still wearing out my first set of brushed motors so I don't even think I'd change those, just the RX and add a gyro to make it do what it do now but with more channels in the RX. Not really sure how this would be done and if it would perform as good as it does now so I haven't done it... Mel |
portsmouth uk
Joined Jan 2010
Hi guys,
here are my second thought (pun intended ) to my 400D ... I mustered the courage today to seriously contemplate a maiden hover in my 7X12 ft apartment (or better the room within my apartment that I can use for flying) ... just - NO maiden flight for me .It is only one motor spinning, the second one is dead. Now I am trying to figiure if it might be in the RX (I am using the 2401 from my 5G6 with reversed servos) but it looks like it is the speed control unit to me (just need confirmation). I swapped the motor wires and when I do, then only the other motor work - which rules out a dead motor ... I am just not 100% sure, if this also completely rules out the RX or - in other words - identifies the speed control beyond any doubt as the culprit ... ![]() Hope one of you guys has some thoughts for me ... Regards, Sven |
Latest blog entry: The WLToys V912
Canada's Wet Coast
Joined Jul 2008
Never seen any ESC test circuits...sure hope you get it figured out Sven! Mel |
apart from the fact that I think those micro plugs on the RX are a abso lutely major PITA (!!! ) ... at least that is how I understood the Walkera "commercials"/advertisements ... use any 2.4G TX you want and the thing will bind ... should I have misunderstood something there ![]() ![]() I will try your suggestion with swapping the ESC wires in the TX (if I manage to get those darn plugs out of it anyway) and see where that gets me ... and if it doesn't help I hope for some enlightening word from Mark. Once those options are exhausted, I will write MM and see what they are going to tell me ... Thanks, Sven |
Canada's Wet Coast
Joined Jul 2008
![]() ![]() And yep, I finally get what plug you're talking about. I was thinking the servo plugs and you meant the other set. Doh! Homer Simpson moment for me... I never gave it much of a thought when I was working on mine because I've dabbled in electronics (was a technician at one point) for the last 40+ years and those connectors are pretty common. Another connector like the one on the ESC and a matching pin header and you could wire up an adapter cable to fit in between. I did a google search and some guys are reporting they can use a servo tester for an ESC. But the details are pretty sketchy so someone probably tried it once, miracles of miracles a motor ran and everyone else carried on the urban legend? I don't know but it seems odd that there doesn't seem to be a quick, easy, cheap, way to test the ESC. Didn't your 400D come with an RX? Even the second one I got had the RX and ESC in it. Just no TX because I use the 2801. Mel |
I ordered the same specification like you from the same vendor ... 119 BNF - no TX but sure there was a RX ![]() I thought for a while about getting the version MM sells with the 2801 - but then I thought that I already have about 5 (usesless) Walkera TX's, so I wanted to do myself (and planet Earth) some good a not getting a 6th one (... baaaad mistake I guess )Anywho, I will figure this out ... sooner or later (but probly later ) and post my findings ....Sven |
Canada's Wet Coast
Joined Jul 2008
I get it, you were going to use the RX out of another Walkera to test the ESC...ah ha! But you only got 5 TX's? ![]() ![]() ...I lost count of mine. Got a shelf full of those 2401's, bought the 2801 Pro and oh boy, do I like it.I have a Spektrum 6xi (for my mSR) and the 2801 is just as nice as far as I'm concerned. It would really be nice if most of the heli's could be ordered without a TX! Like you I sure don't need any more of them... ![]() Still hope you get it all sorted out. I'm still trying to get my CB180D back in the air after it tried to take on the living drapes and ...lost... Mel |
| Thread Tools | |
| Discussion Walkera Lama 400D | beachbumbora | Coaxial Helicopters | 446 | Sep 04, 2010 06:52 PM |
| Discussion Walkera Lama 400D helicopter mini review: | ehirobo | Coaxial Helicopters | 28 | Jan 05, 2010 12:43 AM |
| Video Modified Lama 4 vid. | Stamp | Electric Heli Talk | 0 | Jan 31, 2009 12:39 AM |
| Discussion My modified lama 2 with lights | airmech1979 | Coaxial Helicopters | 1 | Jun 20, 2006 12:24 AM |
