Go Back   RC Groups > Aircraft - Electric - Helis > Multi Rotor Helis
Old Aug 16, 2009, 05:20 AM   #31
KCV6's Avatar
CF blades
Hey Sven,
Was thinking more along the lines of "Airy" blades, never used them before but they seem to be popular. I should just lay up my own CF ones, I havn't done any CF work for a while but I still have a few metres of weave and some R180 kicking around.
Cheers.. Mark
KCV6 is offline Find More Posts by KCV6   Reply With Quote
Old Aug 16, 2009, 05:23 AM   #32
Originally Posted by erdnuckel2
The ones on the Lama 400D are the tuffest ones on the market right now (and the only {CoAx}-blades in this size anyway - or why else would I have started cutting them down to fit my Esky Big Lama?
Only thing that would resemble what you are talking about (IMHO anyway) would be someone finally coming out with "real" carbon fiber blades ....
Sven
Sven, are you saying the Lama 400 is even bigger than the Big Lama from Esky?
kodak_jack is offline Find More Posts by kodak_jack   Reply With Quote
Old Aug 16, 2009, 05:25 AM   #33
TriC-2
Yes Jack, it is ... actually significantly!
Edit:
It is almost the size of a Blade400 or Belt CP - just the rotor is quite a bit smaller in diameter.
erdnuckel2 is offline Find More Posts by erdnuckel2   Reply With Quote
Old Aug 16, 2009, 05:32 AM   #34
TriC-2
Originally Posted by KCV6
Hey Sven,
Cheers.. Mark
Airy blades seem to be popular, you are right - but they only cut it for the smaller birds - if you dig deeper Mark, you will see that ALL the blades made by aftermarket companies for the size of the Esky Big Lama are tooo flexible - now imagine they have to be even bigger for the Lama400. ( )
What you are suggesting (and probably will be doing soon - something for what I kinda envy you for being able to do) is the ONLY feasible thing in my eyes ... if you know hhow to, make your own CF blades!!
Regards,
Sven
Old Aug 16, 2009, 05:41 AM   #35
KCV6's Avatar
A perk of being in the Aerospace Industry More so from the point of view of getting stuff at trade and having some good equipment available so long as I don't interfere with Safety health and environment or any current workload. It use to be a lot simpler.
Hard part will be coming up with a consistent "blank" to CF over, otherwise you are limited to a pressure moulded lamination purely of laid up CF to a thickness which is no where near as strong, although I must admit I am tempted to try this approach first.
Cheers.. Mark
Old Aug 16, 2009, 05:55 AM   #36
TriC-2
Cheers.. Mark
That is exactly how a guy who posted his "How to ... build your own helicopter blades" guide did it for the smaller L3/L4 - layers of CF - that's it. But of course the smaller birds are a lot lighter and you need a lot less strength and resilience (besides a few other things ) from the blade ...
Old Aug 16, 2009, 06:02 AM   #37
KCV6's Avatar
ProE here I come!
Guess I'll take an A and B into work and do some ProE 3d modeling and see if I can get 2 aluminium dies cut on the 3 axis. There is probably enough curvature in the blade so they won't flex, but they won't be as strong.
Yep, with cam and 2200mAh pack (and all the paint. LOL) my 400 comes in at 722.1 grams.... definately hefty, spot on 640 grams without cam or blades
Mark
Old Aug 16, 2009, 10:33 AM   #38
Mark
If you go through all the trouble of making dies, you might as well go into business!!! Do you work with composites at work? I thought Uncle Sam was the only one watching from up there?
Old Aug 16, 2009, 08:35 PM   #39
KCV6's Avatar
Uncle Sam... been known to work for him..
Not directly working with composites these days, have drifted more into Optoelectronics, however we have in the past, and I use to do replacement CF side covers, brackets and bits for bikes.
I'll have a word to the Plant Manager and see if he would be willing to let me slip some 3 axis time in. If I can get good accurate dies cut the actual CF bit will be the easy part. The CF cloth is actually not badly priced here in Aus as there is no import duty or taxes on it.
Cheers.. Mark
Old Aug 17, 2009, 03:01 AM   #40
KCV6's Avatar
Flybar movement restriction.
One thing I'd like to try is limit the amount of movement in the flybar and therefore the upper blades.
I have tried to simulate upper to lower blade strike and fortunately Walkera seem to have spaced the blades far enough appart that this won't happen at full servo extent. The top blades do however seem to move a lot when following the flybar. I would have thought this free movement could be limited to a certain degree which may in turn reduce the efect wind has on the helo.
Feel free to join in and comment.
Old Aug 17, 2009, 05:12 AM   #41
TriC-2
Been done for the smaller Lamas in Germany by Skytec (if I understand correctly what you suggest):
They make a rotorhead called "Speed" in which the angle the flybar can have in reference to the rotor axis is limited to a certain maximum degree. (Because of the design of their rotorheads there is practically NO sideways (lef/right) flybar movement possible anyway and with this particular rotor head the up/down movement gets limited.
Sven
Old Aug 17, 2009, 08:19 AM   #42
KCV6's Avatar
Thanks Sven
Yep, you do get my drift. I was thinking of machining up a new top retainer with deeper sides so it limits the amount of angle the flybar can pivot. I realize this will probably decrease the stability, or ability of the 400 to correct itself, but it should also limit how "out of control" it gets on abrupt change in direction. My spare flybar has arrived so I will start playing around a bit with length and put some temporary shims on it to limit it's movement to see how it effects the flight performance.
Don't get me wrong the 400 Lamas standard fly very nicely, I just can't help tinkering. LOL
Old Aug 17, 2009, 08:35 AM   #43
TriC-2
What is to get wrong about it? The Lama4 flies nicely (even more so if it happens to be of those that come from the factory with the servo horns in the 2nd hole) ... and yet it is the most modded heli on the planet (coax, that is)
Tinkering or ... "tinkeritis" (I think that is the term doctors gave that psychological condition ) is a very useful and admirable trait (in our hobby anyway) and the rc helis would surely not be where they are today if it weren't for the people who suffer from it ...
Regards,
Sven
Old Aug 17, 2009, 10:20 PM   #44
KCV6's Avatar
Tinkeritis...
Unfortunately Tinkeritis has been known to lead to indebtitis which is sometimes followed by sparebeditis.
Agree wholeheartedly
Cheers
Old Aug 18, 2009, 10:05 AM   #45
KCV6's Avatar
2 night flights
Put 2 partial 2200mAh packs (about 10 mins worth on each) through it tonight under the back yard floodlight. Mostly hovering with rapid stick inputs to try to unsettle it.
With the shorter tail moving the weight closer to the main shafts and the reduced weight on the flybar it is a lot more responsive and as expected a bit more "stick intensive" to fly. Breeze was all over the place but no more than 5 mph. I will have a crack at shortening the flybar by 1 weight loop each end and limit the flybar pivot by a couple of degrees at a time next. I'm surprised that with all the added weight this thing still has more power than you need. half stick is hover I may have to rig up some more weight just to see how much it can lift.
Careful! Beware ! Never ever buy Walkera Lama 400D beachbumbora Multi Rotor Helis 327 Today 10:34 AM
Discussion Walkera Lama 400D helicopter mini review: ehirobo Multi Rotor Helis 23 Aug 10, 2009 09:33 PM
Video Modified Lama 4 vid. Stamp Helicopters - Electric Videos 0 Jan 31, 2009 01:39 AM
Discussion My modified lama 2 with lights airmech1979 Multi Rotor Helis 1 Jun 20, 2006 01:24 AM
Bored? Want to fight?
Join the RCGroups clan!
