So if I do 10 minute flights, and 6 flights equal 1 hour, than with 21 hours on the motors I should roughly expect 126 flights. I will have to start keeping track of my flights, so I can document some of the details. Thanks! Randy Skeeter, I believe I would order your blades and links from the US, like Jag hobbies, and receive them in 3-5 days, rather than waiting that long. You could always put your order in for spare parts with MM, and have them coming later, but maybe you have other helis you can be flying in the meanwhile. I just hate waiting on parts, so I may pay a bit more, but I do have them here quick. |
Canada's Wet Coast
Joined Jul 2008
![]() Nothing I have bought since has flown as nice as that first 400D ever did either. Including the second 400D I bought as a spare. Methinks quality control might be a bit of a crap shoot at the Walkera factory... ![]() Oh yea I should mention that I was using lube on the motor ends and wiping off any excess before each flight day (not each flight). Got the idea from Mark. Just a wee drop of dino juice on the motor end bearings with a tooth pick... ![]() Mel |
I keep pretty good track of my lipo packs, and how many times cycled, so I can compared different brands and how they hold up. So by doing this I have a good idea of the time on my motors also.I know what you mean about the different characteristics in helis. I have 2 blade cx's that I put together from scratch with the exact same equipment on, but they both fly a little differently. I don't know if any bird flies exactly the same as another. It seems they each have their own characteristics, so I suppose that could be do to the material used, and the workmanship of the equipment. I know my 400D sure does handle nice, and I just wish the weather would cooperate more so I could be out flying it! I guess that's what I have the cx's for, so I can keep flying even in bad weather.
If they had them, Miracle Mart shows the 400D, without a transmitter, for $105!!!!!!
Latest blog entry: UM Stryker
miracle-mart had the 105$ Lama400D now for many weeks - if not several months already ... it's just that most people here in the forums really only care about the one heli the currently fly and pay very little attention to what is going on with the rest of the heli - or in our case CoAx - market ...
![]() The other point about it is the increased shipping costs from China lately ... maybe the bird is only 105$, but with S&H it is considerably more ... ... AND it is out-of-stock - like a more frequent times at MM lately ... Also, it would be nice of Walkera to make a BL model of this heli, but not for them, as it would reduce "after-purchase" business quite a bit. However, if there is any functioning BL upgrade for the Esky Big Lama (and there are pages over pages of stuff documenting how that works) it is (in the meantime) possible just to swap it from there to the 400. Plus, if you (would) read the Lama400(D) thread, there are several write-ups about Lama400 brushless conversions in there ... ... and as always: just my 2Cents
Latest blog entry: The WLToys V912
NO vendor that I know of ... at least not in the original 2.5mm diameter (this is the biggest problem about the Lama400 inner shafts, that they are [i[TOO thin[/i]!!)
Randy |
Randy, It's home made.6061-T6 turned on the outside as shown with 2.5mm holes turned in from each end if used with the standard head or 2.5mm one end and 3.0mm the other (for the BOL head). Then cross drilled to M2.5 for M2.5 grub screws. I have done it with the extreme, standard and BOL head. The main reason I like the BOL head is it doesn't wear out and the flybar plastic part is a lot beefier. You don't want to go to long on the extension as it will get too top heavy past the pivot point (where the bearing is) and the top head will vibrate at higher RPM when loaded up.
I use my dremel to put small groves in the saft for the grub screws to locate and lock into. Cheers... Mark |
| Thread Tools | |
| Discussion Walkera Lama 400D | beachbumbora | Coaxial Helicopters | 446 | Sep 04, 2010 06:52 PM |
| Discussion Walkera Lama 400D helicopter mini review: | ehirobo | Coaxial Helicopters | 28 | Jan 05, 2010 12:43 AM |
| Video Modified Lama 4 vid. | Stamp | Electric Heli Talk | 0 | Jan 31, 2009 12:39 AM |
| Discussion My modified lama 2 with lights | airmech1979 | Coaxial Helicopters | 1 | Jun 20, 2006 12:24 AM |
