China
Joined Jun 2008
Hey Wrend,
Thanks for the help, I am not able to see any servo slow down using the delay, Has anyone else seen this? I can't seem to get the servo speed to change, I get a slower reaction from the servos but not a servo speed change. I'm not sure if that is making any sense, let me know if someone alse has figured this out yet. Thanks again, Rockitglider |
United States
Joined Feb 2001
Hey Wrend,
Trying to set up Butterfly. When I enter a value for "offset" ie, move my left stick (flap control) to point I want ailerons to start to rise at 80% of full flap travel; then push RTN button. Problem is the the ailerons start to rise immediatly as I lower the stick, but at about 80% of stick travel , ailerons stop moving. I want the reverse to happen; ie as I start to deploy flap, no aileron rise until I have 80% of flap deployed, THEN ailerons start to rise. Going crazy kind of like setting up swash mix on a new heli
St. Mary, Maryland, United States
Joined Dec 1996
There is probably a field on that screen that says "norm", if you select it and change it to "REV" your selected point will change from on to off or the opposite. Not actually looking at the Tx right now so I may be all wet
United States, MI, Durand
Joined Feb 2004
Well I've had my new 8FG for a week now, and I must say Futaba has put some serious thought into this radio. Quite honestly, this may be the last radio I ever need. I have been slowly going through the manual and different menus, amd so far I've had no real programing issues. Having an 8UA previously has probably helped as a lot of the programing logic is similar. However, there is one thing which I can't quite figure out. Maybe someone here has the answer. On the prog. mix function when choosing an activatoin switch and then setting the on/off positions for that switch, there is a selection at the bottom of the screen "Alternate On/Off". The manual has brief paragragh about this on the next to last page but does not explain the use of it. Anyone?
Bill |
I only mention that last bit because I didn't realize until after scrolling through all the control inputs that I could have just scrolled backwards one space instead...
You can use this when using one of the two position switches to effectively be able to double-switch back to where the switch location started while alternating between having a mix on or off, such as one tap of the momentary switch.
well I initally SET J3 as control input for FLAP (single servo on center flap). Now I am trying to deploy butterfly as I reach 80% of full Flap with the J3 input. I did not set Butterfly to any switch. Can I select J3 to ALSO control butterfly (and Flap)? I just want the ailerons to "rise up", as I exceed 80% of full flap. I will re-read your post, and thanks. This is all confusing, my previous Tx was Dx-7.
Yes, you can have J3 set for both. On the third page of the BUTTERFLY menu for SW select J3, then under the On/OFF settings select REV instead of NORM and SET where on J3 you want BUTTERFLY to deploy. Back on the third page of the BUTTERFLY menu, set OFFSET to about 50. You'll have to make sure BUTTERFLY is activated too of course. There might be a better way of doing it, but this seemed to work for me.
| Thread Tools | |
| Focus 3 FM question. Also, about that new Futaba 3 ch. . . | EFoil | Parkflyers | 5 | Oct 19, 2001 11:59 AM |
| Wanted New Futaba T6XHS / Complete | xios3 | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 04, 2001 06:16 AM |
| 4- New Futaba S-148 Servos $45 Shipped | xios3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 01, 2001 04:49 PM |
| New futaba 3 channel ss radio! | carl schaller | Electric Plane Talk | 6 | Jun 24, 2001 08:21 PM |
| New Futaba FF9 to replace FF8? | John E | Electric Plane Talk | 5 | Jun 10, 2001 05:41 AM |
