14sg
Here is a link to a short unboxing video we shot yesterday.
8FG on a trainer cord with a 9X radio ??
Hi
I just wonder if I can use a 9X Radio with a Futaba 8FG Super on a trainer cable to help other learn to fly ... I have the special futaba cable with regulater since the 8FG uses 7.2 V NIMH battery and 9X uses higher voltage battery ... But the question is Can I mod the cable so both radios can be used on that cable .. I also have the JR terminal .. for the 9X ... Has it been done before ... ?? Thanks a lot Khaled |
Joined Sep 2009
I run my 9XR on 2S which should comply with the 8FG. But you have to look deeper into it, havent tried and use mine, 9XR, on O9 r1947, for park stuff solely. |
United States, AZ, Tucson
Joined May 2003
Help with configuring an 8FG to 8FG training setup...
I eventually figured out the Trainer's (instructor's) radio is the one bound to the model. I've got the control semi figured out. The Trainer's control works fine. (I was hoping I could just copy models between radios, but of course it couldn't be that simple.) The problem is the student's radio doesn't control the model correctly. I would assume it has to do with the statement: "Reset the student's model data to the default condition." That is in the manual., but I don't know what that is. Can anyone help, or point me to a thread that answers this question? Thanks, John |
Rhondda. South Wales, UK
Joined Feb 2007
John it means that the students radio should have a default model profile. If you are unsure, just create a new one entitled "Train" (or whatever else) and start with that.
** It needs to be the same model profile (Eg: Plane: 2AIL Tail: Normal) as the one you are using on your radio. |
Joined May 2003
Thanks!
Got it figured out with your help. I still had to mirror sub-trims and servo assignments in the student radio. Why can't I just use a copy of the model program from the instructor's radio? (Maybe I can and I was just trying it in the wrong direction previously.) |
- Birger |
Latest blog entry: DSM2 for Futaba with Micro Trainer Port
| Thread Tools | |
| Focus 3 FM question. Also, about that new Futaba 3 ch. . . | EFoil | Parkflyers | 5 | Oct 19, 2001 11:59 AM |
| Wanted New Futaba T6XHS / Complete | xios3 | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 04, 2001 06:16 AM |
| 4- New Futaba S-148 Servos $45 Shipped | xios3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 01, 2001 04:49 PM |
| New futaba 3 channel ss radio! | carl schaller | Electric Plane Talk | 6 | Jun 24, 2001 08:21 PM |
| New Futaba FF9 to replace FF8? | John E | Electric Plane Talk | 5 | Jun 10, 2001 05:41 AM |
