United Kingdom, England, Chorley
Joined Jul 2008
Wireless is definitely the way to go. No voltage conflicts, no tripping over the buddy lead.
When your friend is at the stage of almost becoming solo, you can walk away a safe distance so he can experience flying alone. When he is flying solo the rx can be used in an airframe. My tfr4 is attached using a small square of hook & loop. |
Joined Sep 2009
And you UK guys seem to have the stuff around the corner (when in stock)
http://www.giantshark.co.uk/frsky-tr...-p-406511.html http://www.giantshark.co.uk/fasst-c-40_160_312.html
Joined Jul 2008
One thing to be careful of with the lead:- the pins push back when inserted into the TX. I took the cover off the plug and a tiny drop of cyano fixed them. |
For the US fellas, here is a local vendor: http://www.alofthobbies.com/futaba-w...ner-cable.html http://www.alofthobbies.com/tfr4-b.html For the HK customers: http://www.hobbyking.com/hobbyking/s...dProduct=21732 http://www.hobbyking.com/hobbyking/s...dproduct=22692 Regards, - Birger |
Latest blog entry: DSM2 for Futaba with Micro Trainer Port
Joined Sep 2009
http://www.rcgroups.com/forums/showp...postcount=3744
Describes the principles, the clip is pretty old and there were no fasst clones available at that time. |
Hungary, Somogy County, Kaposvár
Joined Feb 2009
Motor timer
I have a question about timer programming on the 14SG.
For an electric glider I have the motor function activated so that the throttle stick only controls the motor at a certain position of a switch. At other position the throttle stick controls the butterfly. Now I would like to configure timer #1 to measure the motor run time, however I can only seem to assign the J3 stick for the timer trigger, so it also counts the butterfly time too. On my 10CG this setup was possible by using the logic switch feature. I could AND the switch and the throttle position and use this to trigger the timer. Is there a solution for this on the 14SG (or 8FG)? Thanks in advance. |
I tried searching but no luck. I am adding a playstation SP joystick to my 8FG super. I just need to know what the four wires are that come off the switches. There is one white and three blue wires. The PSP switch only needs one + one - and two signal wires. I plan on using the leads fron the two side lever switches. Again, there is one white an three blue inside the futaba tx per switch, I tried searching the web all day and found nothing. Your help is greatly appreciated. Good day!
United States, TX, Houston
Joined Jan 2012
I have a R6208SB and just got a FrSky TFR8SB. My Naza is setup on the SBUS on the R6208SB which HAS TO BE channels 1-7. Basically that fills up my R6208SB because I cant assign the normal ports to other channels. SO I bought a FrSky TFR8SB to use for my gimbal/camera control... the problem is the FrSky website is completely down and I can't access any manuals.
How exactly do I bind this AND my other RX to my 8FGS? Anyone running a Naza with 2 rx's? How are you powering them both? |
| Thread Tools | |
| Focus 3 FM question. Also, about that new Futaba 3 ch. . . | EFoil | Parkflyers | 5 | Oct 19, 2001 11:59 AM |
| Wanted New Futaba T6XHS / Complete | xios3 | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 04, 2001 06:16 AM |
| 4- New Futaba S-148 Servos $45 Shipped | xios3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 01, 2001 04:49 PM |
| New futaba 3 channel ss radio! | carl schaller | Electric Plane Talk | 6 | Jun 24, 2001 08:21 PM |
| New Futaba FF9 to replace FF8? | John E | Electric Plane Talk | 5 | Jun 10, 2001 05:41 AM |
