Old Dec 28, 2012, 12:25 AM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
Originally Posted by dnbarrie11 View Post
The SBus 2 port is for peripherals such at Telemetry and the SBus 2 servos that are coming soon.
SBus is great. Once you use it you'll be sold on the benefits.
Darwin N. Barrie
Chandler, AZ
Team Futaba
Thanks I know what S.bus2 is.
The discussion is around the R6202SBW which has 2xS.bus ports and not a S.bus +S.bus 2 port.
TimBle is offline Find More Posts by TimBle
Old Dec 29, 2012, 09:47 PM
jwilson32 is offline
Find More Posts by jwilson32
Loving Life!!!
jwilson32's Avatar
United States, MO, St Louis
Joined Jan 2010
Does anyone have a part number for the part that will give me a "smooth" throttle?
jwilson32 is offline Find More Posts by jwilson32
Old Dec 29, 2012, 09:53 PM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
Probably just have a screw loose behind the remote...
RotorJockey is offline Find More Posts by RotorJockey
Old Dec 29, 2012, 10:02 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Yeah open it up and take the little metal bar off the throttle...
Alex Schauer is offline Find More Posts by Alex Schauer
Old Dec 29, 2012, 10:04 PM
bdelapen is online now
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
That typically won't work as you need some pressure on the ratchet to keep it from moving on it's own. The radio has a teflon cap that goes between the ratchet and the metal bar but no, I don't know what the part number is. If you do find one please let me know what it is or where you got it as I want one too.
- Birger
bdelapen is online now Find More Posts by bdelapen
Old Dec 29, 2012, 10:10 PM
Joined Feb 2011
What if youmput a peice of tape over it?
Old Dec 29, 2012, 10:19 PM
Jackson, MO
Joined May 2009
Sell your 8FG and buy one of mine. Mine are both helicopter radios with a smooth throttle.
Old Dec 29, 2012, 10:48 PM
bdelapen's Avatar
Joined Aug 2008
As a stop gap I slid a piece of fuel tubing over the metal bar and this gives you some of what you need. However, it is not as smooth as the teflon cap however and there is a little bit of stickiness to to the fuel tubing.
Ideally I can find the teflon cap but if I can't what I have will have to do for now.
- Birger
Old Dec 29, 2012, 10:58 PM
Loving Life!!!
jwilson32's Avatar
Joined Jan 2010
Or you could just be a hell of a friend and trade me! Haha
Old Dec 30, 2012, 12:08 AM
DaxFX is online now
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
I smooth out a bit my sliders by bending a bit bit the metal string. Not sure on the throttle but you can check that out,'in my old 7c I manage to take out the ratchet feel by doing the same, a little V shape that i flat out
DaxFX is online now Find More Posts by DaxFX
Old Dec 30, 2012, 05:58 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
Hi Guys! Happy New Year to all. We have a problem getting a T8FG Super to connect to a Futaba T6J S-FHSS using the trainer function. We want the T6J to be the control (student) TX and the 8FG to be Instructor so that when the 8FG is not being used the Student can fly on his own with his TX settings. We have both TX's set to NORM and when I fire up the 8FG the 6J lights up but the RX stays red. With just the 6J on the RX binds fine.
Also I cannot seem to get my 8FG to show an ON setting for the Trainer function either, only INH or OFF.
We want the 6J to be the control and independent and with the Student and the 8FG to be in the hands of the instructor when connected.
Threshold is offline Find More Posts by Threshold
Old Dec 30, 2012, 08:14 AM
numnutchris is offline
Find More Posts by numnutchris
numnutchris
Joined Sep 2009
The 8FG cant link, nor bind, to the 6J Rx, as its S-FHSS not FASST.
numnutchris is offline Find More Posts by numnutchris
Old Dec 30, 2012, 09:22 AM
bdelapen's Avatar
Joined Aug 2008
So a little more detail. In a teacher / student setup the teacher radio is the one bound to the the Airplane. Usually, if the owner of the plane is the student then you will use a 2nd radio for them to learn with moving to their own radio once they can "solo". In this case that would make the 6J the master as this would have to be bound to the plane.
In order to have this differently then you would have to bind the plane to the Instructors radio during training and re-bind it to the students radio when training is over. With the 8FG and the 6J this is not possible unless you swap out receivers during the transition as the 8FG "speaks" FASST protocol and the 6J "speaks" S-FHSS protocol.
Hope this helps.
- Birger
Old Dec 30, 2012, 10:57 AM
Threshold's Avatar
London UK
Joined Jul 2004
Thanks Birger, I am still wondering why my 8FG won't show ON in the Trainer setup process though?
Old Dec 30, 2012, 11:06 AM
bdelapen's Avatar
Joined Aug 2008
OK, so I wrote this before I realized what you wanted so here it is anyway (it may help someone else):
If the 8FG is being used as Teacher you need to turn on the radio and it will show the regular transmit icon, radio with antenna and lightning bolt.
If it is being used as the student and the teacher radio sends out a Vswitch signal then the 8FG will turn on automatically and will show the little icon with the two radios and the trainer cord between them in the middle:
In this state the radio is not transmitting through it's built-in FASST module.
Here is the answer I believe you are looking for:
As for the trainer setup. When you set up a model for using the 8FG as the Teacher radio then it will be set to INH by default (inhibited). You need to set the type of control you want for all channels you want to share with the student, you need to assign a switch (the spring loaded switch is defaulted to), and then you need to enable it. Once you enable it it will default to OFF, for it to move to ON you actually need to pull the switch that turns on the student radio.
Hope this helps.
Regards,
- Birger
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 11:59 AM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 06:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 04:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 08:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 05:41 AM
