Old Dec 02, 2012, 03:04 PM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
Originally Posted by MCrites View Post
Ideas?
The FrSky TFR8S should work, I believe you can bridge port 1&2 and use the other channels for 9-14.
http://www.frsky-rc.com/ShowProducts.asp?id=51
shdwkeeper is offline Find More Posts by shdwkeeper
Old Dec 04, 2012, 07:09 PM
jwilson32 is offline
Find More Posts by jwilson32
Loving Life!!!
jwilson32's Avatar
United States, MO, St Louis
Joined Jan 2010
What are the differences between the 8fg and 14sg? Just curious as i have the 8fg and extremely happy with it.
jwilson32 is offline Find More Posts by jwilson32
Old Dec 04, 2012, 07:53 PM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
14SG has telemetry and works with all Futaba 2.4 receivers: cheap FHSS, old FASST, and new FASSTest. No other major differences exist but a number of minor ones do (vibrator, SDHC, etc.)
14SG has it's own thread which of course discusses the many similarities and differences with the 8FG.
vespa is offline Find More Posts by vespa
Old Dec 04, 2012, 08:00 PM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
How many chsnnels are fully proportional and how many ar On/Off switches.
Buschbarber is offline Find More Posts by Buschbarber
Old Dec 04, 2012, 08:42 PM
vespa is offline
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Everything is the same as the 8FG (12+2) but there is a high-speed FASSTest mode with limited telemetry that is 10+2.
Old Dec 04, 2012, 08:45 PM
Joined Apr 2004
Thanks!
Old Dec 04, 2012, 10:51 PM
DaxFX is offline
Find More Posts by DaxFX
Play tetris with my english
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
No money now for a new 14sg, i only want the telemetry update to my 8fg, or any hacker that can put 14sg firmware on a sd card to upload to 8fg,
Also this thread should keep the original title and take out the 14sg from it, there is already another thread thread for that, we should keep simple
DaxFX is offline Find More Posts by DaxFX
Old Dec 05, 2012, 05:02 PM
bossee is offline
Find More Posts by bossee
Bo Edström, Sweden
Joined Jan 2009
DaxFX,
There will probably not be any telemetry update to 8fg - You just buy the external (Robbe/Futaba, in Europe) telemetry box and R6308SBT receiver (FASSTest capable) and voilà You have telemetry with Your present Futaba 8FG.
http://www.robbe.de/rc-fernsteuerung...elemetrie.html
http://www.robbe.de/robbe/downloads/...ff6d8ad55efd4a
/Bo
bossee is offline Find More Posts by bossee
Old Dec 06, 2012, 05:54 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The 8FG and 14SG have the same programming except for telemetry so all the programming discussions apply to both.
If you want an excellent low cost receiver get the FrSky TFR8S. I just ordered a couple more of them. Actually they are better than Futaba in that they have an RSSI output port.
RC Man is offline Find More Posts by RC Man
Old Dec 06, 2012, 05:58 AM
landeck is offline
Find More Posts by landeck
United States, GA, Sandy Springs
Joined Jul 2008
What is an "RSSI output port"?
Bruce
landeck is offline Find More Posts by landeck
Old Dec 06, 2012, 06:12 AM
RC Man is offline
United States
Joined Feb 2001
That’s the signal strength (Relative Signal Strength Indicator). If you have a FPV, data recorded or TM it can be useful.
The current 14SG TM only tells you the signal from the telemetry transmitter down to the ground. With receiver RSSI you can see the signal at the receiver.
Also some that fly FPV have reported that the FrSky TFR8S has slightly more range than the FUTABA FASST 8-channel receivers, but I have not tested that myself.
Old Dec 06, 2012, 06:45 AM
landeck is offline
Joined Jul 2008
Thanks RC Man. After 40 years of RC building and flying I still learn something new every day.
Bruce
Old Dec 06, 2012, 11:13 AM
arnav is online now
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
I finally wanted to switch my 48" Edge from using a Y-connector to separate Aileron channels. When I switched the wing type, I noticed I have lost all of the settings (D/R, expo, trim, F/S, etc'). I have backed up the model before hand so I didn't lose anything...
However, is there a way to switch the wing type without having to key all the setting again?
Thanks!
arnav is online now Find More Posts by arnav
Old Dec 06, 2012, 12:18 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Nope
There probably is a good reason they have to reset all the data when changing the wing type or tail type. They at least should have a warning message come up, giving you the option to cancel out of the change.
In your case, you could leave the wing type to 1AIL, and add the second aileron channel in the function menu, though I don't think you'll have differential throw available with that arrangement.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Dec 06, 2012, 01:52 PM
RC Man is offline
United States
Joined Feb 2001
14SG has telemetry.
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 12:59 PM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 07:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 05:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 09:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 06:41 AM
