Old Nov 06, 2012, 03:38 PM
Pilot232 is offline
Find More Posts by Pilot232
Pilot232's Avatar
United States, AZ, Peoria
Joined Jun 2004
Does anyone know if the 8GF Super has a diode in the charging circuit. I have the Sirius Pro Charger and would like to know if I can safely use it .
Warm Regards,
Travis
Pilot232 is offline Find More Posts by Pilot232
Old Nov 06, 2012, 03:47 PM
landeck is offline
Find More Posts by landeck
United States, GA, Sandy Springs
Joined Jul 2008
There is no diode in the charging curcit. You can use your charger.
Brue
landeck is offline Find More Posts by landeck
Old Nov 06, 2012, 04:09 PM
Pilot232 is offline
Pilot232's Avatar
Joined Jun 2004
Brue,
Thank you. It is good to know because I can not find a jack like the one on the factory charger, so I have to canabalize the factory charger.
Thaks again,
Travis
Old Nov 06, 2012, 05:12 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
You can always take the battery out when you charge it. That's what I do. I also swap in my spare.
teookie is offline Find More Posts by teookie
Old Nov 06, 2012, 05:58 PM
Skaluf is offline
Find More Posts by Skaluf
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
Travis, You should be able to find that size connector at Radio Shack. Also most suppliers making adapters also have them.
Originally Posted by Pilot232 View Post
Brue,
Thaks again,
Travis
Skaluf is offline Find More Posts by Skaluf
Site Sponsor
Old Nov 06, 2012, 06:04 PM
dbar101219 is offline
Find More Posts by dbar101219
United States, OK, Tulsa
Joined Nov 2011
Brue,
Thaks again,
Travis
I use this one
http://www3.towerhobbies.com/cgi-bin...4&I=LXSMF3&P=K
dbar101219 is offline Find More Posts by dbar101219
Old Nov 07, 2012, 02:02 AM
Petrik59 is offline
Find More Posts by Petrik59
Petrik59's Avatar
Sverige, Södermanlands Län, Eskilstuna
Hi,
Anyone knows whare I can find sensors for the Futaba 14SG telemetry and how are the price on them compared to other TX brands?
I have jist been able to find SBS-01A Atmospheric Pressure Sensor $72.99
, SBS-01RM Magnetic RPM Sensor $59.99, SBS-01RO Optical RPM Sensor $59.99 and the SBS-01T Temperature Sensor $84.99.
Above comes from Tower Hobbies.
I could not find any sensor form Amp and I feel the prices are a bit in the higher range.
I have been using a 8FG for a couple of years but now I want a TX with telemetry.
So it is eather a new Futaba 14SG or I will switch to Multiplex to get the Telemetry.
I really do not need 14 ch but I want the telemetry.
Petrik59 is offline Find More Posts by Petrik59
Old Nov 07, 2012, 03:04 AM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
Think the 14SG is worth selling my JR 9503?
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Nov 07, 2012, 06:55 AM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
I would say yes...even for the 8FG! Almost bought a 9503 when they came out as I was a JR man for many years and needed to move to 2.4. When I weighed all the options, the 8FG was the one I came home with a couple years ago and do not regret the purchase. Am seriously thinking if even worth upgrading to the 14SG as the 8FG does all I really need and more. However, if I was to buy a new radio, would more than likely be the 14SG.
rcwings is offline Find More Posts by rcwings
Old Nov 07, 2012, 07:48 AM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
I had radio issues with my 9503 so I switched to the 8FGH, it is a great radio. biggest problem I had was buying the new rx's. My boy still flies his trusty old dx7. I am thinking I will upgrade to the new 14GS and give him my 8fg. It just makes life easier to have us both on same radio systems.
bigmoebbq is offline Find More Posts by bigmoebbq
Old Nov 07, 2012, 01:16 PM
Dan Zero-G is offline
Find More Posts by Dan Zero-G
France, PACA, Aix-en-Provence
Joined Dec 2007
Warm Regards,
Travis
I charge with my fast chargers through the normal futaba jack (I cut it off the supplied futaba slow charger).
The only thing worth noting is that if I charge anything faster than 0.4A it seems to disconnect. However, charging at 0.3A is good enough, as the transmitter does not seem to use up much power.
Dan Zero-G is offline Find More Posts by Dan Zero-G
Old Nov 07, 2012, 01:28 PM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Disable Steering
This question has surely been asked and answered a few times... But couldn't find the answer using the search function
How can I set-up the nose wheel steering to disable (centered) when the landing gear is up? (using SF for the retract/extend function).
Step by step instructions or references anyone?
Thanx a million
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Nov 07, 2012, 01:37 PM
Skaluf is offline
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
Thanx a million
Set the steering servo up as a p-mix with rudder, next use the retract switch to turn that mix off when the gear is retracted. When you drop the gear the mix turns back on.
Steve
Site Sponsor
Old Nov 07, 2012, 01:38 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Deecee,
The same switch that retracts the U/C is also the one that enables/disables the mix from rudder to nose-leg steering servo, simple.
A.
AndyOne is offline Find More Posts by AndyOne
Old Nov 07, 2012, 09:56 PM
Woodbender is offline
Find More Posts by Woodbender
Is it coming or going??
Woodbender's Avatar
United States, CA, Aguanga
Joined Dec 2008
Speculative question:
What is the likelihood we'll see future software updates for the 8FG?
Woodbender is offline Find More Posts by Woodbender
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 11:59 AM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 06:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 04:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 08:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 05:41 AM
