Old May 03, 2012, 03:50 PM
espe is offline
Find More Posts by espe
I sink, therefore I am...
espe's Avatar
United States, CO, Fort Collins
Joined Jun 2009
Originally Posted by Slats! View Post
Thanks guys I know its a PINA when people come on the boards like this when its in the manual hahaha.
Doesn't bother us, as there's very little in the manual that is actually useful. It's all good here.
Sam
espe is offline Find More Posts by espe
Old May 03, 2012, 03:57 PM
DaxFX is online now
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Description: Name: ImageUploadedByTapatalk1336078650.293678.jpg
Description:
DaxFX is online now Find More Posts by DaxFX
Latest blog entry: Puerto Rico Drone Prix 2016
Old May 03, 2012, 04:20 PM
TG43 is offline
Find More Posts by TG43
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Originally Posted by DaxFX View Post
Wierd VELOX thing. I will try on mine to see. You try on both CAP and small?
Ya it sure is wierd. The only way I could get it to work was move everything over one spot (1st space is blank) and it finally worked.
TG43 is offline Find More Posts by TG43
Old May 03, 2012, 04:31 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Now isn't that weird. Reserved keyword?
tracknoob is offline Find More Posts by tracknoob
Old May 03, 2012, 04:49 PM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
As you can see the pics i was able to do it with no problem
Old May 03, 2012, 04:58 PM
vespa is offline
Find More Posts by vespa
First pull up, then pull down
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Maybe you're not pressing enter? Most changes on the 8FG are immediate but name changes require you to press enter. This has nailed me many times, usually after I've spent 10 minutes painstakingly entering a particularly complex name.
vespa is offline Find More Posts by vespa
Old May 03, 2012, 05:25 PM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
Yes i press enter. Did you see the picis , 1 is in home screen and other in model select screen. so is obvius i press enter.
Description: Name: ImageUploadedByTapatalk1336083903.616015.jpg
Description:
Old May 03, 2012, 05:55 PM
vespa is offline
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Yeah pretty clear you pressed enter. What about the other guy? :/
Old May 03, 2012, 06:27 PM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
Sorry! I was thinking you was the other guy. I just got confused.
Old May 03, 2012, 07:06 PM
numnutchris is offline
Find More Posts by numnutchris
numnutchris
Joined Sep 2009
Well this is kinda frustrating...my 8FG doesn't like the name "Velox" apparently. It wouldn't let me create that as a new name. After messing with it I got as far as "Velo" but if I put the x at the end, it just goes back to "Velo".
Is it a know problem with the 8FG naming models?
Try move to after the last character, o in your case, then move to the DELETE and hit RTN a couple of times; you probably have entered some spaces into it all. Then you should be able to enter the x and dont forget to ENTER before leaving the naming menu.
numnutchris is offline Find More Posts by numnutchris
Old May 03, 2012, 07:13 PM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
What exactly means the VPP #1 on FASST 7CH mode and why is mixed with J3 throtle stick
Old May 03, 2012, 07:25 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Stands for Variable Pitch Propeller / Throttle curve #1.
It is there in case you fly one of those fancy foamies they fly in ETOC or other VPP enabled aircraft. If you don't have a VPP just go into the function menu and un-assign it, all the inherent mixing will be ignored.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old May 03, 2012, 07:31 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by RC Man View Post
That is very confusing the way that Futaba names the radios.
The 10C is a 8+2 channel transmitter and has no upgrade capability – it’s a very old design.
The 8FG is a 12+2 channel transmitter.
The 10C doesn't have ball bearing gimbles like the 8fg does
losifanatic is offline Find More Posts by losifanatic
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
Tanks. Now i get. I will love to hover my 3Ds prop down.
Old May 03, 2012, 10:06 PM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
While diving?
Wrend is offline Find More Posts by Wrend
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 11:59 AM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 06:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 04:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 08:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 05:41 AM
