Old Feb 29, 2012, 07:26 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by CPMBOY View Post
whats new wt the V5.0 update?
Oh you know just the normal reverse motor function for electric models and stuff like that. You know the stuff no one cares about
losifanatic is offline Find More Posts by losifanatic
Old Feb 29, 2012, 07:31 PM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Here's a link to Steve's post that has a PDF attached that explains the update changes: http://www.rcgroups.com/forums/showp...postcount=4311
Wrend is offline Find More Posts by Wrend
Old Feb 29, 2012, 08:20 PM
skaffen is offline
Find More Posts by skaffen
Ook!
skaffen's Avatar
New Zealand
Joined Aug 2007
I just want to double check this is how the trim reset works.
Set the trim memory to active
Move trims back to centre
Set trim memory back to INH
Is that the right way to do this
skaffen is offline Find More Posts by skaffen
Old Mar 01, 2012, 03:52 AM
MalcolmHolt is offline
Find More Posts by MalcolmHolt
Brighton UK
Joined Dec 2010
No. Assuming that you have trimmed the model and want to reset the trim indicators to zero on the home screen while leaving the trimmed servo positions as they are you need to do the following.
In the T1 – T4 Set Menu scroll to Memory. Change INH to ACT. Now return to the home screen and scroll to each trim indicator in turn and hold RTN for one second. This will zero the indicators. (If you go back to the T1 – T4 Set Menu and reset memory to INH the trim indicators will return to their original trim positions).
Note that if you have applied full trim and then centre the display the trim lever will not let you increase the trim any further. Once a model has been test flown it is far better to adjust the control linkages so that the trim displays are naturally all at zero thus giving you maximum trim availability.
MalcolmHolt is offline Find More Posts by MalcolmHolt
Old Mar 01, 2012, 10:24 AM
Bax is offline
Bax
Find More Posts by Bax
Bax
Central Illinois
Joined May 2003
Originally Posted by vespa View Post
I noticed that Futaba has a cool virtual 18MZ radio on their website that allows you to browse/program the radio. Not that any of us are shopping in that price range but I did find a few things interesting about the 18MZ firmware. First, and most peculiar, it retains the misplaced "Model" menu of the 8FG -- Model selection is still done from the "Linkage" menu instead of the "Model" menu. Guess they're doubling down on that screwup. Second, it does the reversed motor channel thing!
The model selection has ALWAYS been in the Linkage Menu since this programming style first came out in the 14MZ. Selections in the Model Menu are functions specific to the model selected. Items in the Linkage Menu encompass things across many models, so that's where you select which model you want to use. It's not a "screwup", but just part of Futaba's philosophy of transmitter design.
Once you select a particular model, then you select its contol features in the Model Menu.
Bax is offline Find More Posts by Bax
Old Mar 01, 2012, 11:27 AM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
If I set up a plane with one servo per elevator should I:
set tail type to ailevator
or
Add a second ELE function to another channel in the function menu
Pro's and cons of each please.
teookie is offline Find More Posts by teookie
Old Mar 01, 2012, 11:40 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Either way is fine. The only limitation to adding a second ELE1 in the function menu is that you won't have the ability to have ailervators. That said. I have three planes on the 8FG with dual elevator servos, I do have all three with Ailervator selected in tail type, but none of those models have Ailervator settings programmed in. OK, I admit it, I'm a bit of a Wus
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Mar 01, 2012, 12:28 PM
Skaluf is offline
Find More Posts by Skaluf
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
As Pete mentions, if you don't need ailevators, the fastest way is to simply add another elevator in the Function menu. I personally seldom use the templates with the aircraft I fly. Instead I use the heck out of the Function menu.
Steve
or
Skaluf is offline Find More Posts by Skaluf
Site Sponsor
Old Mar 01, 2012, 03:41 PM
grummingoose is offline
Find More Posts by grummingoose
grummingoose's Avatar
United Kingdom, England, Slyne
Joined Jul 2008
I am unsure if during one of the updates that model select can now be used from the Home Screen, or it has always been there.
After updating to V.5. I was scrolling round the Home Screen and noticed I could choose a different model by going to the active one and press Return, you are taken straight to Model Select.
grummingoose is offline Find More Posts by grummingoose
Old Mar 01, 2012, 03:43 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
It has always been there. You can now also configure the model selection screen to come up when you power up the radio.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Mar 01, 2012, 03:51 PM
Joined Jul 2008
- Birger
Thanks for the info Birger.
This must be the most informative and kept on track discussion thread on the entire internet.
Old Mar 01, 2012, 06:47 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
. . .You can now also configure the model selection screen to come up when you power up the radio.
- Birger
This was available in 4.1 so it is not a new feature for 5.0.
ivanc is offline Find More Posts by ivanc
Old Mar 01, 2012, 07:30 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Never said it was and neither is model select from the main screen, as far as I know it has always been available, at least back to the version that my radio shipped with. I just figured that since he hadn't figured out you could model select from the main screen he probably hadn't figured out that you could set a system parameter for model select at radio turn-on.
- Birger
Old Mar 01, 2012, 07:47 PM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Sorry, I guess I misinterpreted the "now also" in your sentence:
You can now also configure the model selection screen to...
to imply it wasn't available in previous Vers.
Old Mar 01, 2012, 09:04 PM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Hey now... This is the internet. Leave the semantics and syntax at the door.
Speaking of syntax... I'm thinking about building a programmable robot. The question is: Do I use computer programs and WLAN to control it and have feedback from it, or my 8FG and FPV gear with on-board programming that I trigger with different channel settings?
Think Futaba will come out with a "robot" model template type for the 8FG any time soon? (After all, they're a Japanese based company.)
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 12:59 PM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 07:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 05:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 09:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 06:41 AM
