Old Feb 22, 2010, 02:05 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OK, I didnt know the positve stuff about the Futaba 8....
How many free mixes does the Futaba 8 have? and the 10 ?
And how many model memories will the Futaba 8 have with a 2GB SD card ?
sebbe is offline Find More Posts by sebbe
Old Feb 22, 2010, 02:14 PM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Someone posted this early on in this thread. It's a comparison chart for the different Futaba radios.
http://www.futabarc.com/radios/feature-compare.html
Wrend is offline Find More Posts by Wrend
Old Feb 22, 2010, 02:20 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
The 10C has 8 P-mix, the 8FG only 5, if you're not into heavy mixing, like me, the 8FG has a lot to offer.
Here's the link to compare features.
http://2.4gigahertz.com/systems/futk9255.html
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Feb 22, 2010, 02:29 PM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
The 8FG has a limit of around 2000 model memory as stated in one of the Magazine reviews. With a 2GB card, I see 3750 memory slots when pulling up the card on my PC via the Futaba File System Utility. Suspect either one should be plenty for anyone.
rcwings is offline Find More Posts by rcwings
Old Feb 22, 2010, 02:52 PM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
As a rough estimate, based of the 12FGs statistics, the 8FG should hold around 3,764* model memories with a 2GB SD card.
Of course, if you ever run out of room, you can just get another SD card...
*Edited (Sorry, I forgot to carry the one... )
Old Feb 22, 2010, 03:12 PM
rcwings is offline
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
Originally Posted by Wrend View Post
As a rough estimate, based of the 12FGs statistics, the 8FG should hold around 2,764 model memories with a 2GB SD card. Actually, it should hold even more because it doesn't need to be double formatted. So the 3750 mentioned by rcwings is probably the right number.
Actually the number is 3746 as the first 4 are blanked out on the card. Sorry for the grave error.... I am not exactly sure what was meant in the MAN review with respect to a limit of 2000, unless it for some reason is a limitation of the radio, but I doubt it.
Old Feb 22, 2010, 03:22 PM
Kai_Shiden is offline
Find More Posts by Kai_Shiden
Crazy Heli Technogeek
Kai_Shiden's Avatar
USA, WA, Seattle
Joined Sep 2004
FYI, the 8FG only allows direct loading of the 20 memory slots in the TX, the card is used for backup/storage purposes and software updates (you can however just copy models to the TX from the card quickly).
What does that mean? Simply that while you have unlimited "storage" of models by just adding cards, it's not completely seamless if you wish to use more than the 20 slots in the TX.
This is not meant as a knock on the 8FG, just another point to the discussion. The 10C allows direct loading of models from the CamPac, just like the 9C did (as far as I'm aware, I don't own a 10C), so if you do have more than 20 models you'll switch through in a day , and waiting a few seconds for a model copy would annoy you, then the 10C has an advantage there .
-Kai
P.S. I suspect they went that route because they relinquished control over the quality of the flash memory used (going from CamPac under their control, to any SD card that the end user has laying around).
Kai_Shiden is offline Find More Posts by Kai_Shiden
Old Feb 22, 2010, 03:36 PM
jcervantes11 is offline
Find More Posts by jcervantes11
jcervantes11's Avatar
Joined Sep 2003
hey guys anybody using a lipo on this radio?
jcervantes11 is offline Find More Posts by jcervantes11
Old Feb 22, 2010, 03:45 PM
krelis is offline
Find More Posts by krelis
NL
Joined Sep 2006
lipo
yep, I had 2 old cells of a 2100 Mah pack left. Compared to my 6exa it has one great advantage: it swtiches off at low voltage. The 6exa has now killed 2 sets of lipo's after I forgot to switch off....
krelis is offline Find More Posts by krelis
Old Feb 22, 2010, 03:53 PM
Joined Sep 2003
Whats the max mah can we fit in?
Old Feb 22, 2010, 04:33 PM
krelis is offline
NL
Joined Sep 2006
lipo's
I think 2100 is about the max
Old Feb 22, 2010, 04:35 PM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
Gentlemen (and Ladies):
Had someone used his/her T8FG as the trainer instructor with a T7C as the student using the optional trainer cord?
Just wondering since I know the T7C I have is 9V while as I understand, this T8FG is 7V?
^R^
Edit: As jcervantes pointed out below, to be exact, T8FG is 7.2V (as 1.2V * 6 cells?) while T7C is 9.6V (as 1.2V * 8 cells).
Anyway, my concern is the voltage difference and what I got is the FUTM4415 trainer cable as suggested in another forum while the manual says FUTM4405. So, wonderin if anyone had done any trainer function and what cord they are using.
ricoalonso is offline Find More Posts by ricoalonso
Old Feb 22, 2010, 05:15 PM
Joined Sep 2003
^R^
7.4v lol
Old Feb 22, 2010, 05:43 PM
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
7.4v lol
7.4 or 7.2 as in 1.2V * 6 cells.?
Old Feb 22, 2010, 05:49 PM
Joined Sep 2003
Sorry 7.2 but still voltage is higher when its fully charge. I don't have my radio here. A fully charge 4.8 is over 5 close to 6 volt, and a 6 volt battery is over 7v.
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 11:59 AM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 06:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 04:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 08:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 05:41 AM
