Old Feb 20, 2010, 09:34 PM
jcervantes11 is offline
Find More Posts by jcervantes11
jcervantes11's Avatar
Joined Sep 2003
Originally Posted by Wrend View Post
Fair enough. But you're probably not switching your Rxs around that often.
Agreed.
Nah i have alot of receivers for dx6i. But i need to buy some receiver for 8fg, very nice radio, best thing i ever had.
jcervantes11 is offline Find More Posts by jcervantes11
Old Feb 21, 2010, 10:02 AM
air mail rcg is offline
Find More Posts by air mail rcg
Pittsburgh Allegheny, Pennsylvania, United States
Joined Mar 2004
Question, If you had a choice between the 8FG and the T10CAG about the same price what one would you get?
air mail rcg is offline Find More Posts by air mail rcg
Old Feb 21, 2010, 11:35 AM
micktol is offline
Find More Posts by micktol
Joined Mar 2009
stick mode
Hi, can anybody tell me if it is possible to change the stick mode from 1 to 2.?
as futaba say it needs to be sent to them
micktol is offline Find More Posts by micktol
Old Feb 21, 2010, 11:53 AM
rod.d is offline
Find More Posts by rod.d
Account Closed
rod.d's Avatar
United States, OH, Groveport
Joined Feb 2009
Yes, but to move a receiver from one model to another you have a rebind it, as a consequence of model match, right? Or change the programming for the model setup to which it is bound.
rod.d is offline Find More Posts by rod.d
Old Feb 21, 2010, 01:29 PM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
Page 47 of the 8FG manual describes changing the mode. Hope that helps.
rcwings is offline Find More Posts by rcwings
Old Feb 21, 2010, 01:44 PM
micktol is offline
Joined Mar 2009
thanks for the reply rcwings, but I want to change the spring and rachet so that the gas is on the left. I have changed it on the 6ex but I am not sure if its possible for the user to do it on the 8fg
Old Feb 21, 2010, 01:59 PM
rcwings is offline
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
That my friend I am not sure about...sorry.
Old Feb 21, 2010, 05:25 PM
krelis is offline
Find More Posts by krelis
NL
Joined Sep 2006
rachet
It is the easiest thing. Very clever design; I opened the entire joystick to make a modification and it's all self explanatory. just do it.
In my box there was even a spare ratchet in case you want boths sticks to 'ratch'
krelis is offline Find More Posts by krelis
Old Feb 22, 2010, 04:08 AM
pcmac is offline
Find More Posts by pcmac
Moscow, Russia
Joined Apr 2009
if they are about the same price then get the:
<<<T10CG>>>
pcmac is offline Find More Posts by pcmac
Old Feb 22, 2010, 10:13 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
I dont know how the price are for you guys, but here in Sweden the price differance is very little between the Futaba 8 and Futaba 10..... I dont understand, I can not think of 1 reason to choose the Futaba 8 instead of the Futaba 10 ????
Or what do you say.
sebbe is offline Find More Posts by sebbe
Old Feb 22, 2010, 10:48 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
The price difference here runs about 180 bucks. Both are great radios, but the 8FG has some software flexibility lacking in the 10C and SD memory vs Campac is a deal breaker for me. I have the 9C, and find the lighter, thinner 8FG more comfortable. Eight cell battery packs in transmitters are soooo 20th Century, the 8FG seems to run forever on the stock 1700mAh battery, replacement packs made up of Sanyo 4/5A cells for the FG radios are 2150mAh and a 2S lipo will also fit in the battery compartment if Lipos are your thing, no voltage issue
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Feb 22, 2010, 11:01 AM
rcwings is offline
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
Or what do you say.
Here in Canada the difference is about $190, so I did not even consider it. I like the 8FG for the weight factor (almost half the weight), thinner case, balanced for neck strap and unlimited models with the use of an inexpensive SD card. Also software updates will be available from Futaba and easily completed by use of the SD card (not sure if the 10CAG has that capability with the CAMPac???). Likely the 10CAG is a better radio, but for me the 8FG fit the bill in many ways....no regrets even if I did have a little more to spend.
Old Feb 22, 2010, 11:04 AM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Yeah, I was just going to say that the SD card compatibility of the 8FG makes it more desirable than the 10CG, even if they were the same price, to me.
You can look at the question from the other side. What reasons are there to get the 10CG instead of the 8FG?
If those reasons are worth it to you, then get the 10CG. Simple enough. They however aren't worth it to me.
(I'm also pretty fond of the way they sneaked the extra two switchable channels in for free. Now if they'd just make a 10 channel Rx... )
Wrend is offline Find More Posts by Wrend
Old Feb 22, 2010, 12:40 PM
CyberJay is offline
Find More Posts by CyberJay
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
Don't be fooled by the names either.. Both radios have 8 proportional channels and 2 digital channels.
In my mind, the 10C is an upgraded 9C.. And the 8FG is a scaled down version of the 12FG which strikes me as the "next generation" futaba platform.
-Jay
CyberJay is offline Find More Posts by CyberJay
Old Feb 22, 2010, 12:52 PM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
I agree. You can see how the 8FG has been redesigned from the ground up as a functionally capable 2.4GHz system.
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 11:59 AM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 06:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 04:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 08:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 05:41 AM
