Old Feb 09, 2010, 07:15 PM
HogCrewChief is online now
Find More Posts by HogCrewChief
Terryville,CT (USA)
Joined Mar 2006
I got my 8FG from Tower today!!! I am really impressed with this radio! I can't wait to take it out and try it. It won't be anytime soon though, big snow storm on the way!!!
HogCrewChief is online now Find More Posts by HogCrewChief
Old Feb 09, 2010, 07:40 PM
hannson is offline
Find More Posts by hannson
hannson's Avatar
Poland / SILESIA
Joined Nov 2005
i`m impressed too after change from DSX9..
very nice radio
P1050850.MOV (0 min 13 sec)
hannson is offline Find More Posts by hannson
Old Feb 09, 2010, 08:28 PM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
I am thrilled with mine! I really like the case design and do not feel anymore that it looks "cheap" as it has really grown on me!
I too can't wait to use it in something.
rcwings is offline Find More Posts by rcwings
Old Feb 09, 2010, 09:15 PM
Terryville,CT (USA)
Joined Mar 2006
I agree. When I first saw one at my LHS I thought it looked a little cheap but after playing with it more I don't feel that way at all anymore. I cannot get over how comfortable it is to hold.
Old Feb 10, 2010, 06:42 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Originally Posted by rcwings View Post
Thanks guys. Getting my wife to pick up a 2GB card from The Source (Radio Shack) hopefully today. If it fails will try one of ones you are having luck with.
New SD card works - It is a Dane-Elec 2GB at $12.99 on sale. Odd that the Kingston SD card does not work.
Good to go now! Thanks for the help.
When I first got my 8FGH tried several SD cards that I had and found that some work and some donít. They were all a couple of years old. Not really sure what the magic specifications are that determine whether it will work or not.
RC Man is offline Find More Posts by RC Man
Old Feb 12, 2010, 09:38 PM
TooSLow2Care is offline
Find More Posts by TooSLow2Care
insert witty phrase here
Joined Aug 2006
I just got my 8FG. I've go Two questions.
1: does anybody else find it difficult to move the Slide Switches (LS & RS) from their end points? Should I start SolidWorks development on replacements. Either of Delrin or Aluminum.
2: how would i setup 'Flaperons' with a plane that has individual servos for each flap. Activated by one o the switches so the ailerons still operate while they are set down by 30%-50% as flaps.
Thank you.
TooSLow2Care is offline Find More Posts by TooSLow2Care
Old Feb 12, 2010, 11:16 PM
bigslopegrin is offline
Find More Posts by bigslopegrin
Wind Happens
bigslopegrin's Avatar
So California
Joined Feb 2009
"1: does anybody else find it difficult to move the Slide Switches (LS & RS) from their end points? Should I start SolidWorks development on replacements. Either of Delrin or Aluminum."
YES they're too recessed, my only real gripe so far.
bigslopegrin is offline Find More Posts by bigslopegrin
Old Feb 13, 2010, 07:50 PM
Joined Aug 2006
So Let it Begin
so here we go. after feeling these Sliders (LS & RS) i'm fed up with how short they are.
I'm starting to reverse engineer the round slider control and replace it with one that has a longer lever by about 1/8" (3mm) more... or i could make one that uses the same length adjustment technology that the major joystick controls (J1-J4) utilize.
anyone have a recommendation as to where i should put my progress? open a new thread or something in the CAD CAM, or DIY section? or even here in the Radios section?
thanks
Old Feb 14, 2010, 07:19 AM
krelis is offline
Find More Posts by krelis
NL
Joined Sep 2006
Ls&rs
thanks[/QUOTE]
Keep it here! got any pics/ drawings? I've been contemplating a simple/ugly solution but will wait for you and steal with pride!
krelis is offline Find More Posts by krelis
Old Feb 14, 2010, 10:26 AM
tkna is offline
Find More Posts by tkna
TKNA
Joined Apr 2007
Does anyone have a problem with the sensor touch? I just got my 8FG from Tower a month ago and the sensor doesn't actionize on the FIRST touch sometimes. It will take a few touches to get it going. Is this the way it works as I expect it to work every time I try on the first go. I know that I'm touching it in the correct area as I've tried different areas to the sensor. When I do get it going, I use the same spot the next time and again, it won't come on sometimes. At other times it seems to be very sensitive.
tkna is offline Find More Posts by tkna
Old Feb 14, 2010, 11:07 AM
krelis is offline
NL
Joined Sep 2006
sensor touch
There seems to be a bufix for this from the German counterpart of Futaba:
http://www.cms.robbe.com/downloads/
if you already have software version 1-1-675 or higher it's probably not worth trying, otherwize it won't hurt.
I also noticed that it helps if you don't hold the x-mitter with the hand that you operate the sensor with. It needs the little electric force field from your finger, and if you 'connect it to ground' there less potential.
Old Feb 14, 2010, 11:08 AM
simages is online now
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
I just got mine so, I'm just getting the feel for it. Most activation seems to be double tap, saves from accidentally touching something on/off.....
simages is online now Find More Posts by simages
Latest blog entry: SAL-SA Wing
Old Feb 14, 2010, 11:21 AM
Joined Aug 2006
I have also noticed that the sensor touch ring needs to be double-tapped to make your selection into each menu. the return function to make any other selection is only a single-tap.
i think this is all programming. like simages said, to prevent accidental activation.
Old Feb 14, 2010, 11:40 AM
Joined Aug 2006
here is my progress so far:
I've only disassembled the radio thus far according to the Futaba manual and a step further.
Disclaimer: should you do anything to your radio it's not my fault. you make the choice to do anything to your own radio. I am only documenting my own progress. I am making no recommendations to augment or change your own radio in any way shape or form.
Images,
1: the radio... 'nuf said
2: Removed the cover and battery as per the manual regarding stick tensioning.
3: Removed the Five(5) screws holding the back cover on. also per the manual regarding stick tensioning.
4: image of the open radio. tip-make sure the sliders (LS & RS) are set towards the middle of their travel. the back cover may hang up on them.
5: the culprit slider with it's poorly endowed tab...
6: once the axel screw is removed i placed the pieces in the order they go back for my future reference.
7: the slider that needs to be reverse engineered and milled out of some scrap Delrin i have laying around on my mill.
Old Feb 14, 2010, 12:48 PM
fritzthecat is offline
Find More Posts by fritzthecat
Send Money, Women & Guns!
fritzthecat's Avatar
Virginia Beach
Joined Sep 2002
Yes, the sliders are too small. Especially at either extreme of travel, the radio case makes it hard to catch the slider hiding in the corner.
Simple solution is a 2mm hex head bolt. Drill a small hole in the slider, trim 2mm bolt to a length so it won't protrude out the other side and screw in with a little CA.
Fritz
fritzthecat is offline Find More Posts by fritzthecat
Focus 3 FM question. Also, about that new Futaba 3 ch. . . EFoil Parkflyers 5 Oct 19, 2001 12:59 PM
Wanted New Futaba T6XHS / Complete xios3 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 07:16 AM
4- New Futaba S-148 Servos $45 Shipped xios3 Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2001 05:49 PM
New futaba 3 channel ss radio! carl schaller Electric Plane Talk 6 Jun 24, 2001 09:21 PM
New Futaba FF9 to replace FF8? John E Electric Plane Talk 5 Jun 10, 2001 06:41 AM
