Go Back   RC Groups > Vendors > Castle Creations
This thread is privately moderated by Kate O'Neil, who may elect to delete unwanted replies.
Old Sep 08, 2009, 06:48 PM   #61
Ralph Weaver's Avatar
I've not my new ICE 50 connected to a Spektrum 6250 and it's hard to reach. Can I use a Y adapter to connect Castle Link while the unit is connected to the RX as well?
Ralph Weaver is offline Find More Posts by Ralph Weaver   Reply With Quote
Old Sep 08, 2009, 07:18 PM   #62
A man with too many helicopter
After 80 flights so far of plugging and unplugging the ESC I was wondering the same thing. I don’t want to risk blowing the receiver. Perhaps I could adapt a mini power switch harness.
Who makes the smallest power switch harness?
RC Man is offline Find More Posts by RC Man   Reply With Quote
Old Sep 09, 2009, 05:43 PM   #63
kyalamikid's Avatar
I am using a switch harness that I got with a Spin controller. On the off side of the switch it has 2 plugs, one goes to the esc, and one goes outside the heli for plugging on the data logger. If the heli is switched on, the data logger cant connect, so you need to have an isolate plug (no receiver in circuit). The switch is the best idea as you have full access via the second plug when the switch is off.
I think it would be a good idea for Castle to include such a switch in the kit, or at least as an option. I download logs after practically every flight as it is so accessible now.
kyalamikid is offline Find More Posts by kyalamikid   Reply With Quote
Old Sep 09, 2009, 06:15 PM   #64
What we need is a custom switch that switches all three wires. If I can find a small 3P DT switch that is reliable I will make one myself. My project list is getting too long these days.
It sure would be nice for Castle to offer them as an option.
Old Sep 09, 2009, 06:55 PM   #65
"Each Day Is A Lesson"
diver don's Avatar
Would you happen to have a link to that harness or could you point me to a vendor?
Don
diver don is offline Find More Posts by diver don   Reply With Quote
Old Sep 10, 2009, 08:20 AM   #66
Got my ICE 100a all hooked up to my Trex 600 ESP Heli last night and went to fly it....It browned out nonstop with any cyclic or collective input faster than a crawl. Changed voltages several times and appearently that SBEC cant handle it??? my align 6amp voltage Reg NEVER had this problem i hope im just doing something wrong because i really love this controller and want this to be all i need....Any help castle?
-Justin
patterkid is offline Find More Posts by patterkid   Reply With Quote
Old Sep 10, 2009, 08:41 AM   #67
RC Boat Addict
Raydee's Avatar
Send a message via AIM to Raydee
What setup are you running?
Raydee is offline Find More Posts by Raydee   Reply With Quote
Old Sep 10, 2009, 09:53 AM   #68
600 ESP with 4025-1100HK Motor
3 - DS620's
1 - Spartan DS760 with S9256
6s 5000mah 30+c Packs
A more descriptive way to describe what is happening would be if i move the sticks very fast they just start glitching and going full deflection, stop, other way, stop and the received is restarting itself and detects that a voltage glitch has occured which can only mean the ICE is not providing enough current or even a steady one.
-Justin
Old Sep 10, 2009, 10:16 AM   #69
3 - DS620's
-Justin
What radio?
Old Sep 10, 2009, 10:56 AM   #70
DX7 with AR7000 rx
Old Sep 10, 2009, 12:45 PM   #71
Registered Abuser
rolexcomex's Avatar
-Justin
I am using the ICE 100 lite on my Trex600. I removed, ie pulled out the red wire from the ICE controller and I am using the align external BEC with batt. I like the added safety of having an external batt for the radio specially in such a big machine.
So far works great comes down 115 deg after some sport/3D.
rolexcomex is offline Find More Posts by rolexcomex   Reply With Quote
Old Sep 10, 2009, 12:54 PM   #72
I am now too using the Voltage reg but i am wondering why it wont even work right.....Its not living up to what its supposed to do. I am running the sticks on the ground with the heli rotor stopped. those servos CANT be close to pulling 5amps
Old Sep 10, 2009, 01:20 PM   #73
Patrick del Castillo's Avatar
What kind of servos?
Patrick del Castillo is offline Find More Posts by Patrick del Castillo   Reply With Quote
Old Sep 10, 2009, 01:25 PM   #74
DS620's they have been tested with a current meter and they dont pull more than 2-3amps especially on the ground.
Old Sep 10, 2009, 02:06 PM   #75
Remember, on the ground they only draw idle currents, in the air, when the rotors are spinning and there are loads on the servos, the current can increase to five times what the ground currents are.
The DS-620 is a notorious current hog. They can draw upwards of 6A each when heavily loaded.
Discussion New Castle Creations Phoenix ICE ESC Jeff_edge540 Power Systems 7 Sep 20, 2009 01:49 PM
Hacker B20 15L and castle creations Phoenix 25 ok? Speed E Freak Power Systems 13 Aug 23, 2003 02:13 AM
Castle Creations Phoenix 35 ESC GKurt Aircraft - Electric - Airplanes (FS/W) 2 May 29, 2003 08:14 AM
FMA Rx, smallest 1.5" Azar ant. and a Castle Creations Phoenix 25 ESC. mars Parkflyers 10 Feb 10, 2003 09:02 PM
aveox 27/13/3 w/Castle Creations: PHOENIX-35 ramses787 Power Systems 2 Jan 03, 2003 03:15 PM
Bored? Want to fight?
Join the RCGroups clan!
