Go Back   RC Groups > Vendors > Castle Creations
This thread is privately moderated by Kate O'Neil, who may elect to delete unwanted replies.
Old Sep 04, 2009, 08:24 PM   #46
Originally Posted by rolexcomex
I am getting some pretty significant discrepancies on the logging feature of the ICE 100amp esc vs the Eagletree elogger V3 150amp.
Now I dont know who to believe..
Same session one from the eagletree and the second from the ICE 100
<snip>....
I wonder if the ICE is reporting average battery current or max (instantaneous) current. The Eagle Tree is certainly average battery current
It would be great to get a description of what the log-able parameters really are--and what they are. Their description might be in the CC software, but that you need to have installed (I'm still happily running summer 2008 software on my Phoenix controllers, a 45, two 35's, a 25, and a 10) that I use in Control line planes.
Alan Hahn is offline Find More Posts by Alan Hahn   Reply With Quote
Old Sep 05, 2009, 05:59 AM   #47
A man with too many helicopter
Has anyone done a bench test with a wattmeter? I don’t have an ICE installed on an airplane or I would do that myself.
RC Man is offline Find More Posts by RC Man   Reply With Quote
Old Sep 05, 2009, 08:12 AM   #48
RC Boat Addict
Raydee's Avatar
Send a message via AIM to Raydee
I wonder in a future firmware update if it is possible to log the BEC output. I would def like to make sure I am not overloading the bec in my Flybarless heli.
Raydee is offline Find More Posts by Raydee   Reply With Quote
Old Sep 05, 2009, 11:32 AM   #49
Patrick del Castillo's Avatar
Unfortunately, the hardware support for measuring BEC current isn't on the ICE series - -the BEC current is monitored by the switching regulator chip, and the processor doesn't have any access to the information.
Patrick del Castillo is offline Find More Posts by Patrick del Castillo   Reply With Quote
Old Sep 06, 2009, 10:12 AM   #50
Patrick, I have couple a questions about 50 Lite version:
1. Does info from http://www.castlespecialprojects.com...oenix_ice.html
apply to sellling units and ICE 50 Lite have a 90A burst rating?
2. Am I right that BEC 5A is a peak rating or continous?
3. Can you comment defference in rolexcomex logs between eagle and CC logs from this post
http://www.rcgroups.com/forums/showp...4&postcount=39
I've ordered ICE Lite 50 anyway
Thanx, Dennis.
dehicka is offline Find More Posts by dehicka   Reply With Quote
Old Sep 06, 2009, 01:29 PM   #51
2. It you look at the ICE page it says 5 amps continuous at 33.6 volts. Your ESC has a 22.5v limit so your BEC has a big margin built in.
http://www.castlecreations.com/produ...oenix_ice.html
Old Sep 06, 2009, 02:25 PM   #52
Phoenix Ice brings the ability to run at input voltages of up to 8S* (33.6) and use the built in switching BEC to output up to 5 amps of servo power all the way up to the 8S max.
No word about contionous or peak.
Old Sep 07, 2009, 02:50 AM   #53
DS JUNKY
Z06kal's Avatar
How does the 100 amp ICE compare to the HV85 when using both at 8S. Will the ICE 100 do 100 continuous even at 8S voltage? I remember that the older phoenix controllers could not handle their rated amperage when ran under max 6S voltage. If I'm looking to burst about 95 amps on 8S am I better off with the HV85 or the ICE 100?
Z06kal is offline Find More Posts by Z06kal   Reply With Quote
Old Sep 08, 2009, 12:25 PM   #54
Fly the plane:-)
FNFAL's Avatar
Ice 100 8S
Just got my Ice 100 8S from Tower Hobbies. I ordered a Lite (6S)...but this is what they sent me instead. This seems to be a re-occuring situation at tower based on others similar comments. I don't need 8S capacity or the weight...but oh well...it sure is a beautiful hunk of metal...and the "hard-case" kind-of protects the board from physical damage.
It's got big honking 10ga wire not only on the battery side, but the motor side too.
People say that the weight difference between the 75A and 100A is nill, so why not get the 100A. But what they don't realize, is that published weights are without wires, so the difference in real life situations will be more...especially if you plan to run 10ga wire back to an EDF or something.
FNFAL is offline Find More Posts by FNFAL   Reply With Quote
Old Sep 08, 2009, 01:01 PM   #55
Thanx, Dennis.
1. Yes. Remember those burst ratings are for 10seconds on, 1000 seconds off, repeated.
2. The 5A rating is average current out from the BEC.
3. No, I can't comment on that, other than to say he's the only one who has seen a significant difference between the ICE and the Eagletree. With only two data sources, it's impossible to tell which logger is incorrectly calibrated. There have been lots of posts which show no significant difference between the Eagletree and the ICE datalogging.
Old Sep 08, 2009, 01:20 PM   #56
Registered Abuser
rolexcomex's Avatar
Just a follow up. I did do a repeat trial. ICE, eagletree, and bantam wattmeter. The numbers of the eagletree and wattmeter correlated very well, the ICE was about 10% higher in all parameters. So, I must have the only ICE controller outhere that is not correctly calibrated. For now, I will just continue to use the eagletree. The ESC works fine otherwise and its probably just not worth sending back for just that feature. I am a little disappointed.
rolexcomex is offline Find More Posts by rolexcomex   Reply With Quote
Old Sep 08, 2009, 01:33 PM   #57
Fly the plane:-)
FNFAL's Avatar
Yes, this is key. If you go up to 90A burst on a 50A unit, then with only 10 seconds of that you'll have to wait almost 17 minutes of off-duty to cool her down (sure, less if you're somewhere in the middle between 50-90A). But for the most part, that's more than the entire flight...and 10 seconds can go by pretty fast. Therefore, I won't be relying on bust figures for average flying.
Old Sep 08, 2009, 01:46 PM   #58
Originally Posted by FNFAL
Yes, this is key. If you go up to 90A burst on a 50A unit, then with only 10 second of that you have to wait almost 17 minutes of off-duty to cool her (sure, less if you're somewhere in the middle between 50-90A). But for the most part, that's more than the entire flight...and 10 seconds can go by pretty fast. Therefore, I won't be relying on bust figures for average flying.
No, you don't want to use the burst ratings for average flying, and that's the point. The burst ratings are for maximum current for short periods of time on a controller at room temperature ONLY.
Old Sep 08, 2009, 01:51 PM   #59
Sounds like there is a calibration offset on your unit. There is about a 5% variation from unit to unit, which we then calibrate to about 2-3% before shipping. It's possible your unit was incorrectly calibrated.
A 10% offset isn't terrible though -- the ICE wasn't designed to be a laboratory instrument. It wasn't designed to replace dedicated loggers like the Eagletree. It was designed to allow for some simple logging and checks for the average user.
You can return it to have the calibration checked, and recalibrated if necessary.
Old Sep 08, 2009, 02:05 PM   #60
Fly the plane:-)
FNFAL's Avatar
Patrick,
Your earlier liturature has what appears to be an Ice (lite) 100 rated at 58A continuous in 0 LFM air flow.
Does this apply for both versions of the Ice (6S) and (8S)?
Does this amp rating increase when operating an Ice under less than max Volt conditions, say at 5S supply?
If indeed the electronics are the same in the 6S and the 8S versions with only the heatsink as the difference, then perhaps the 58A can be bumped on the heatsink model?
Steve
Discussion New Castle Creations Phoenix ICE ESC Jeff_edge540 Power Systems 7 Sep 20, 2009 01:49 PM
Hacker B20 15L and castle creations Phoenix 25 ok? Speed E Freak Power Systems 13 Aug 23, 2003 02:13 AM
Castle Creations Phoenix 35 ESC GKurt Aircraft - Electric - Airplanes (FS/W) 2 May 29, 2003 08:14 AM
FMA Rx, smallest 1.5" Azar ant. and a Castle Creations Phoenix 25 ESC. mars Parkflyers 10 Feb 10, 2003 09:02 PM
aveox 27/13/3 w/Castle Creations: PHOENIX-35 ramses787 Power Systems 2 Jan 03, 2003 03:15 PM
Bored? Want to fight?
Join the RCGroups clan!
