| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
Thread Tools |
| This thread is privately moderated by Kate O'Neil, who may elect to delete unwanted replies. |
#16 | |
Pro Bro ozzyman
Tower moved the date to late Aug. Tim |
#17 | |
A man with too many helicopter
#18 | ||
That sickening crunch..
(applies to the ICE as well ![]() Quote:
#19 |
Pro Bro ozzyman
Tower sent me a note.
Their in stock.
#20 |
Hi,
I have the Phoenix 80A ESC, 80A in the Phoenix series means 80A continuous current and 120A surge. But now the ICE 75A means 75A Max ! so what's the safe continuous current rating for a ICE 75A ESC? Also for the BEC output too. Can Castle use the same rating standard like Phoenix? |
#21 | |
http://www.castlespecialprojects.com...oenix_ice.html
#22 | |
"Each Day Is A Lesson"
What's in stock? I have a "50" and a BEC on backorder and received nothing. Don .Tower has updated their site. Just my luck, the Ice 50 is still on BO, many others are in. Last edited by diver don; Aug 13, 2009 at 07:23 PM. |
#23 | |
Thanks for the reply, but is this apply to the selling products, the one without heatsink is called ICE Lite now.... also, the BEC rating information is not available yet...
#24 |
When is the heat sink 8s version going to be available? The lite version is in stock but not the heat sink version. I was under the impression that they would both be manufactured at the same time but apparently not.
#25 | |
Pro Bro ozzyman
Don, Sorry about that. I checked Towers site after I got their email and ALL 6 ICE models where listed as 'in stock". Tim |
#26 |
Firefox
Does anyone know if the ICE unit has settings for heli use, governor for example ?
thanks |
#27 | |
#28 |
Registered Abuser
just curious, it states that the light can handle 6s. If I plan to use 4s lipo, will I need a BEC ???
#29 | |
Hear is a quote from the spec page “Phoenix Ice brings the ability to run at input voltages of up to 8S (33.6) and use the built in switching BEC to output up to 5 amps of servo power all the way up to the 8S max!” So you will have the full 5 amps available up to the voltage limit of the ESC that you select. http://www.castlecreations.com/produ...oenix_ice.html
#30 | |
Registered Abuser
Thanks, I know its clearly marked but I did not want to find out that it only meant in "certain" situations and pull majic smoke or worse.... |
| Thread Tools | |
| Discussion New Castle Creations Phoenix ICE ESC | Jeff_edge540 | Power Systems | 7 | Sep 20, 2009 01:49 PM |
| Hacker B20 15L and castle creations Phoenix 25 ok? | Speed E Freak | Power Systems | 13 | Aug 23, 2003 02:13 AM |
| Castle Creations Phoenix 35 ESC | GKurt | Aircraft - Electric - Airplanes (FS/W) | 2 | May 29, 2003 08:14 AM |
| FMA Rx, smallest 1.5" Azar ant. and a Castle Creations Phoenix 25 ESC. | mars | Parkflyers | 10 | Feb 10, 2003 09:02 PM |
| aveox 27/13/3 w/Castle Creations: PHOENIX-35 | ramses787 | Power Systems | 2 | Jan 03, 2003 03:15 PM |
