| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
| Thread Tools |
| This thread is privately moderated by lestingoy, who may elect to delete unwanted replies. |
#1 |
Lee Estingoy
Castle Introduces CC BEC PRO
CC BEC PROs are in the oven now. First batch should ship early next week. Look for them at the usual dealers in about 2 weeks.
Technical details are listed in the attached docs. Lee Last edited by Kate O'Neil; Aug 07, 2009 at 02:23 PM. Reason: Text |
#2 |
RC Boat Addict
Hmmm, no indication that these will work in boats?
#3 |
Can you explain why the output current drops so dramatically with the input voltage?
Is it a thermal issue, or just IR limitations of the switching FETs? |
#4 | |
At 16V in, 5.0V out, the circuit runs at a 30% duty cycle. At 48V in, 5.0V out, the circuit runs at a 10% duty cycle. Therefore, peak currents at 48V are about 3 times as high -- this limits maximum output current at higher voltages. |
#5 |
That sickening crunch..
![]() ..a |
#6 |
Misguided Advertising?
Looked at the press release and thought WAHOOO 20A for helis on 12S, untill I read the specs
only 8A and the max continuous ever can only be 15A on 6S.Come on guys/girls give us the truth instead of some sales hype. Pretty Pleeeeeezzzeee |
#7 |
A man with too many helicopter
I have run a data recorder on my 620-size helicopter and only got peaks of 2.6 to 2.7 amps during 3D with high-powered servos. So 8 amps is way more than any helicopter flyer will need. Besides the radio wiring is the limiting factor. Not sure what the limit is but I’m sure it’s way below 10 amps.
I think that you might be right about advertising. Saying 20 amps and 12s in the same statement is very misleading. The table does not even list how low the input voltage has to be to get 20 amps output. It’s probably lass than 12v which means that you have to use a 3s LiPo to get max output current. That would be good for nitro applications. I wonder why you are limited to 6s for cars and 10s for airplanes? |
#8 |
RC Boat Addict
I have been using a 3.5amp Western robotics BEC on my 6s Logo Vbar for two seasons now without a single glitch in the system. 8 amps is plenty unless you have some serious servo binding.
#9 | |
ASA all the way!
The WRL website provides some test information, but it is lacking because it gives two of the three test parameters: input voltage, output voltage, and output current.
The manual for the WRL-HBECS states that it "...MUST BE used cautiously with forced cooled air ventilation directed at the Hercules" for 10A continuous operation. Even though WRL provides a link to the manual, this information would be helpful on the website. |
#10 |
Some people are never satisfied..
(further thoughts on this deleted..) ..a |
#11 | |
ASA all the way!
It is not a matter of being satisfied because I am going to buy a CC BEC PRO when I find a stocking dealer. However, I prefer specifications to be relevant and in context, not ambiguous with key information buried in manuals. I can afford to test a $40 regulator. I prefer not to experiment with a $100 regulator. |
#12 | |
I was referring to this:
![]() Thankfully, their main distributor has it listed (from http://www3.towerhobbies.com/cgi-bin...?&I=LXYCA6&P=7 ): Code:
SPECS: Max Input: 12S LiPo (50.4V)
Max Output Current: 20 amps peak
Max Continuous Current: Input Voltage Max Continuous Output Current
16V 15A
24V 13A
32V 11A
40V 9A
48V 8A
#13 | |
ASA all the way!
These are the same specs in the first post below. I did not go to the CC website until now so I did not realize that CC did not have the information there. Still, it would be nice to have that third parameter (the output voltage) that corresponds to the table, unless the current is constant over the 4.8V to 12.5V output. |
#14 |
The next think that they need is to make a helicopter version with dual outputs. One high current adjustable output for most of the helicopter and a 5v 2A output especially for the rudder servo.
I have tried the step down circuits be they are not regulators so I don’t like them that much. Some of my helicopters I use two BEC’s so I can get both 6v and 5v regulated. Two BEC Pro’s would do the trick but it would be good to have it all in one package. . . . CC, BEC Pro Heli – Put it on the to-do list.
#15 |
Lee Estingoy
re specs. These aren't engineering spec sheets. Our ratings are for hobby use. Stock/default output for those ratings. 5.1 volts I believe.
Re dual output. That would be 2 becs in the same package. Not much advantage in that, just use 2 becs. Could event use a BEC and BEC PRO. Lee |
| Thread Tools | |
| Question Where is the CC BEC Pro? | Mike66 | Castle Creations | 4 | Aug 04, 2009 08:34 PM |
| Re:While in Monticello IL next week.... | MSu1049321@aol.com | RCSE | 0 | Jun 08, 2003 04:01 AM |
| Airtronics RD 8000's will be here next week | George Voss | RCSE | 0 | Apr 15, 2003 04:03 AM |
| what's happening near London next week? | avie | Electric Plane Talk | 3 | Aug 11, 2002 01:20 PM |
| Anyone going to be at Mid America next week? | Dave Campbell | High Performance | 3 | Jun 30, 2001 11:58 PM |
