Old Aug 06, 2009, 04:54 PM
robZulu is offline
Find More Posts by robZulu
inventor of flames decals.
robZulu's Avatar
Hamburg, Germany
Joined Dec 2008
Help!
Brass Pinions for 4#3B, 4G3, m0.25 1.5mm shaft diameter: 19,20,21,22 T - where??
hi,
im looking for pinions for the BL motors with 1.5mm shaft for 4#3s, 4G3s etc.
now ive only found two sources:
16 and 18 T from Terence (brass)
16 - 22 T from nanoheli (nylon, only small pinions brass)
the 21 T nylon i use on my C06 gets ripped pretty quickly, it still works, no tooth lost, but it looks like it will not last very long
now i want brass pinions with 19,20,21,22 tooth - but i cant find any
can anyone help?
cheers,
rob
robZulu is offline Find More Posts by robZulu
Old Aug 06, 2009, 05:31 PM
congoz is offline
Find More Posts by congoz
Joined Jul 2009
close to your home
http://www.shop.kkpmo.com/index.php/cat/c29_M0-25.html
genco
congoz is offline Find More Posts by congoz
Old Aug 06, 2009, 05:39 PM
robZulu is offline
robZulu's Avatar
Hamburg, Germany
Joined Dec 2008
thanks!
i read something about them some time ago which didnt sound good at all.. about shipping problems etc.
have you ordered from them recently?
Old Aug 06, 2009, 05:45 PM
sNstRflyEr4G3 is offline
Find More Posts by sNstRflyEr4G3
I NEED MORE FOAM...LOTS MORE
sNstRflyEr4G3's Avatar
United States, MA, Webster
Joined Mar 2009
What about WOW?
sNstRflyEr4G3 is offline Find More Posts by sNstRflyEr4G3
Old Aug 06, 2009, 05:46 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Originally Posted by congoz
Glad you're back.....again.
Rob that's the place I was going to link to. I find the brass are the way to go as well. I also fit a tiny spacer made from the ink tube of a pen above the gear just in case it should come loose. Had the gear move upwards a few times in crashes and it quickly bevells both gears.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Aug 06, 2009, 05:52 PM
robZulu is offline
robZulu's Avatar
Hamburg, Germany
Joined Dec 2008
amp, i had some crashes cause of plastics pinions moving on the shaft too... now im going for brass
does WOW carry 22 T? also its probably cheaper to ship form poland to germany then from the US
Old Aug 06, 2009, 06:01 PM
congoz is offline
Joined Jul 2009
thanks Amp.
robZulu, i ordered some 16t and 17t pinions few days ago and they are on the way now.
i have 16t and 18t brass pinions from cj but they are a bit noisy for my taste. i will try the poms for that reason.
Old Aug 06, 2009, 06:12 PM
robZulu is offline
robZulu's Avatar
Hamburg, Germany
Joined Dec 2008
yeah, brass are always louder, also the smaller the louder... maybe try some bigger ones
again, thanks for the link genco, just placed an order
Sold 5 Batteries & Charger for Walkera 4G3, 4#3B/A/Q, LAMA2-1, 5G6 $19.99!!! queadlunnrau Aircraft - Electric - Helis (FS/W) 0 Aug 06, 2009 10:21 AM
Discussion 1/80 PUMA AS 332 - Scale fuselage possibily for 4#3B Dark-Angel Micro Helis 2 Jun 19, 2009 02:50 PM
Wanted 4-1 RX for 4#3B Walkera......good used please, have trades. Wrench66 Aircraft - Electric - Helis (FS/W) 2 May 05, 2009 11:07 PM
Discussion Tips and Tricks for improving durability of 4#3, 4#3a, 4#3b, 4G3, 4#3q chadt Micro Helis 56 Apr 19, 2009 07:50 AM
Discussion HELP need a charger plug for 4#3b zenchal26 Micro Helis 4 Jun 06, 2008 04:28 PM
