Old Apr 11, 2003, 04:02 AM
Rick Eckel
Rick Eckel
Guest
n/a Posts
[RCSE] Full House Plus Throttle - JR 8103
It seems like I am getting asked more frequently how to do a full house
sailplane and throttle on the JR radios. So here is my solution. I put
the motor on the 3-position switch as my preferred location. If you want
it elsewhere you just need to modify the switch selected in the second mix.
Sure this isn't as much fun as the dive test but perhaps a few will be
interested.
Rick
JR 8103 Motor Control on the 3-Position switch
Pushing the 3-position switch to the up position turns the motor on. Both
neutral and down positions leave the motor off. (the gear/crow/butterfly
switch must be in flight mode for motor to come on. The motor will not
run in the landing mode.) Model setup must be GLID, Wing Type must have
DUAL FLAP ACTivated and the FLAP IN. must be FLP.SW+P6. All pots must be
inhibited.
Here is how to do it:
Use two mixes - one to null the Crow/Gear/Butterfly switch from Channel 8
(Aux3) and one to link the 3-position switch up-position to channel 8 (Aux3).
Here are the settings:
Crow Switch Null..........
Mix4
Aux3-Aux3
Rate: -100%
0%
Switch: BTFY0
Offset: -171
3-Position switch up-position link.........
Mix4
Aux3-Aux3
Rate: 0%
-100%
Switch: FLP-D
Offset: +171)
Reversing channel 8 will reverse the "throw" of the output of ch8(Aux3) to
match your speed controller requirements if necessary. Keep in mind that
mixes must always be turned on before you can make adjustments Rate and Offset.
Enjoy!
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
John Derstine
John Derstine
Guest
n/a Posts
RE: [RCSE] Full House Plus Throttle - JR 8103
As in any computer radio there are many ways to do this. I prefer a safer
(opinion) method with the motor on the throttle stick (also gives you
proportional throttle) and full trailing edge camber/neutral/reflex on the
flap 3 po. switch. Landing mode if you have spoilers IE scale, put spoilers
up and flaps down on the butterfly crow switch. Ailerons mixed to flaps via
quad flap, with flaps de mixed in landing mode.
John Derstine
Endless Mountain Models
johnders@npacc.net
http://www.scalesoaring.net/EMM/rand.htm
-----Original Message-----
Sent: Saturday, April 05, 2003 5:46 PM
To: Soaring@airage.com
Subject: [RCSE] Full House Plus Throttle - JR 8103
interested.
Rick
inhibited.
(Aux3).
Mix4
Aux3-Aux3
Rate: -100%
0%
Switch: BTFY0
Offset: -171
Mix4
Aux3-Aux3
Rate: 0%
-100%
Switch: FLP-D
Offset: +171)
Offset.
Enjoy!
MIME turned off.
Discussion Setting up a full house Glider with a JR 9X II colin wavell Slope 16 Dec 26, 2006 04:25 PM
Full house electric sailplane with the JR-8103? Falconator Electric Sailplanes 5 Jun 10, 2004 06:55 PM
Jr 8103 programming for full house ship? rbehrends Radios 0 Apr 13, 2003 09:32 PM
JR 8103 flap/throttle mixing with gear switch question bfraser Electric Sailplanes 0 Aug 30, 2002 07:50 PM
JR Radio for DLG or full house flyinhigh Aircraft - Sailplanes (FS/W) 0 Aug 16, 2002 07:27 AM
