Old Aug 05, 2009, 09:39 PM
jim florentine is offline
Find More Posts by jim florentine
Joined Sep 2004
Esc Getting Way Too Hot
I have the perfect set up brand new e-flight six series 2700 kv, new servos, new cc phoenix 35, running on a 3 cell lipo, but after fifteen seconds in the air I loose all power and the goes down no control over anything, I touch the speed control and it almost burns me, im running a small prop 5.5 -4.5 any suggestions why my esc is getting so hot ive even tried other esc. its on a 36 inch ritewing lightening
jim florentine is offline Find More Posts by jim florentine
Old Aug 05, 2009, 09:50 PM
grumman5277 is offline
Find More Posts by grumman5277
grumman5277's Avatar
Troy ,OH
Joined Jan 2004
have you run this on a watt meter? Your probably to close to the esc rating as well as the bec adding to the problem.
grumman5277 is offline Find More Posts by grumman5277
Old Aug 05, 2009, 10:39 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Hey budy Its most likley pulling around 40 amps thats why,is it vented.
The 3000 kv motors pull appx 43 to 46 amps at appx 26000 to 27000 rpms on the same prop on 3s dep on the battery.
Your pushing the esc pretty hard.
Ck
klique is offline Find More Posts by klique
Old Aug 05, 2009, 10:40 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Check you setup with a wattmeter then I would disable the on board BEC and run a separate one. Its worth a shot. The BEC overheating will kill the unit.
Make sure your bay is vented
Atom1025 is offline Find More Posts by Atom1025
Old Aug 05, 2009, 11:50 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
http://www.rcgroups.com/forums/showthread.php?t=1091035
mrforsyth is offline Find More Posts by mrforsyth
CC Phoenix 25 ESC Getting Hot? nub111 Power Systems 3 Aug 05, 2004 01:22 PM
Question Brushless Motor WAY TOO HOT!!! Help. Willmsy Power Systems 1 Jul 30, 2004 05:48 PM
Stock Corona, getting too hot.... Captain Carlton Electric Heli Talk 6 Oct 22, 2002 08:56 PM
S-400 Getting Too Hot? RICH S Power Systems 6 Aug 13, 2002 10:04 PM
