Old Aug 02, 2009, 08:33 PM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
Cool
New Electric Planes... FULL SIZE!!!
I just got back from Oshkosh Airventure... if you don't know what that is better look it up you are a disgrace to aviation!! well not really but you better learn.
Anyhow, I could not believe how many companies are putting out electric airplanes! One in particular seems to be the most advanced, www.yuneec.com . They have a line of Brushless motors and controllers that are amazing. They have a 10kw (13hp) 20kw (18hp) and 40kw (54hp). They have a Backpack paraplane, an Ultralight, and a 2 place composite Light Sport Aircraft.
The 2 place has a 28:1 glide ratio (sailplane range) and they are claiming a 3 hour endurance with 6 - 28 lb Lipo Batteries.
A year or so ago i put up a thread asking what people thought about making a man powered foamy. Pretty much everyone thought i was crazy - mainly because no one thought that you could get enough endurance out of it. Well i am telling you this is the wave of the future! Amazing results from these guys.
Anyhow here are some pics.
SGTalon is offline Find More Posts by SGTalon
Old Aug 02, 2009, 08:50 PM
pyrobus is offline
Find More Posts by pyrobus
outstanding in the left field!
pyrobus's Avatar
USA, IL, Marengo
Joined Feb 2007
sweet
The easy riser was from 1979 and also part of the museum up there. Looked like a starter motor out on the tail, but the new planes are pretty cool. Did you see the throttle quadrant on the motor glider had a little slider switch for the power, pretty neet. Quite a few electrics, next will be a hybrid.
Pyro
pyrobus is offline Find More Posts by pyrobus
Old Aug 02, 2009, 09:09 PM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
I was more impressed with the cool multifunction display they had for the big motor. It sounds like you were there. Did you see the display model they had sitting there? It was very cool. Had Power level (throttle), amps, battery, temp for motor and batteries, and a few other readings. It looked great. I wish i would have gotten a picture of the motors and displays. I never did get a chance to go back to the tent and talk to them again.
I talked with the Yuneec sales guy a bit. He said the big motor was putting out 150 volts! That has to be a shocker!
Old Aug 02, 2009, 11:24 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
I want one, and an elrectric PPG !! Smooth and quite. perfect
OzparkPilot is offline Find More Posts by OzparkPilot
Old Aug 02, 2009, 11:34 PM
jaguar75 is offline
Find More Posts by jaguar75
jaguar75's Avatar
Sacramento
Joined Mar 2007
EV Planes
It is easier to covert an airplane to electric propulsion than a car because the airplane is so light and the prop turning at such a low speed does not require the slow revving electric motor to have a gear reduction drive system.Here is the supplier for evs and airplane ev drive systems.
http://www.thunderstruck-ev.com/
jaguar75 is offline Find More Posts by jaguar75
Old Aug 03, 2009, 12:16 AM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
I think what needs to be done is just copy existing RC motor designs and scale them up to where they need to be. There are so many awesome designs out there it should be simple to scale up. Same thing with the ESC and batteries. Why not use the same designs with components that can handle the 150 volts that these motors need. If you keep the volts high you don't need as many amps.
That Yuneec company is from China... I bet they are thinking the same thing i am. I played with their motor. It looked like a standard RC style brushless. It cogged like a high KV motor. So cool!
Old Aug 03, 2009, 12:31 AM
Boxhead is online now
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
SG, thanks for the insight. Picy's where Great. I was thinking along the same lines. Maybe they have been looking up the Scratchbuilt Forum for inspiration..
B x
Boxhead is online now Find More Posts by Boxhead
Old Aug 03, 2009, 01:55 AM
icrashrc is offline
Find More Posts by icrashrc
icrashrc's Avatar
Indiana
Joined Jul 2003
It was nice to see the well thought out products from Yuneec at Oshkosh. Motor, speed control, charger/balancer all working together. No surprise it's from a RC company.
Hopefully the hack from Florida is at the end of his 15 minutes of fame...
icrashrc is offline Find More Posts by icrashrc
Old Aug 03, 2009, 06:54 AM
pyrobus is offline
pyrobus's Avatar
USA, IL, Marengo
Joined Feb 2007
also
they also had electric backpack power units for paragliders.
Cheers!
Pyro
Old Aug 03, 2009, 08:01 AM
MTDV is offline
Find More Posts by MTDV
Software always has bugs
United States, TX, Missouri City
Joined Nov 2008
Very Cool
NASA has done that too.
http://www.grc.nasa.gov/WWW/RT/2003/...400berton.html
MTDV is offline Find More Posts by MTDV
Old Aug 03, 2009, 08:29 AM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
Actually MTDV they are using battery packs instead of Fuel Cells. A lot more power/weight.
A couple of the geezers that were hanging out there at the tent kept talking about how it would be no good for long distance travel because of the recharge time. Who cares about the recharge time? I bet 90% of general aviation flight time is local flights of less than 2 hours. This fits into Yuneec's current capabilities. And with the emerging battery technologies i am sure that they will see even more performance increases.
I am seriously thinking about getting into the large brushless motor business. How hard would it be to scale up some nice cheap Towerpro style motors?
Old Aug 03, 2009, 09:59 AM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
These aren't new but they are electric powered. Technically I guess they'd be called "sustainers" but I'm pretty sure both can takeoff under their own electric power.
Interesting.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Aug 03, 2009, 10:05 AM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Recharge Faster
MIT just added a nano particle to the A123 battery chemistry that will create a 5 minute charge with a 3-phase charger.It also enables the battery to discharge at a more rapid pace without heating up.These batteries will drop in price in the next two years to around $250.00 a KW.You need about 10KW battery pack to fly long distance.If you build an ultrlight plane a 4 hour flight time would be possible.A pusher prop plane is the way to go.It is almost as silent as a glider.
Old Aug 03, 2009, 11:06 AM
Joined Jan 2004
I've passed a small private airstrip on Pine Island just south of Corolla , NC on our way to vacation on the northern Outer Banks at Corova on the 4wd beach. After our 9 hour drive I'd fantasize about flying a motorglider/powered glider down and landing there. Problem is that if I could afford and Antares there wouldn't be any $$ left to buy a house in that neighborhood. The view and sights must be spectacular.
Discussion New props for full-size Storm Launcher dj_d Micro Ready-to-Fly 4 Jan 24, 2008 08:34 PM
wonderful Unicorn Electric wing full size - Brushless setup - econokote covered F.Uhlemann Aircraft - Electric - Airplanes (FS/W) 3 Jun 23, 2004 03:40 AM
Full size SPA3D with electric power? S.A.P. Sport Planes 2 Sep 25, 2003 02:26 PM
Full Size Electric blfinche Electric Plane Talk 1 Mar 30, 2003 10:48 AM
Full size electric aircraft! Ragnar Electric Plane Talk 4 Mar 24, 2003 07:08 PM
