Old Aug 08, 2009, 10:28 AM
pick013 is offline
Find More Posts by pick013
pick013
pick013's Avatar
United States, KS, Shawnee
Originally Posted by Umi_Ryuzuki
Here is a couple pictures of the demo pieces that are programmed into
the techshop machine... And once the support material is removed, the
crescent wrench, and the... uhh.. gear thingy actually work.
I have seen print outs of the granular printers, and it reminds me of
making sand candles at the beach...
Gear thingy is a Geneva mechanizm...used for indexing, still used, but is slowly getting replaced by servomotors
pick013 is offline Find More Posts by pick013
Old Aug 12, 2009, 07:33 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
this was on wired this morning for the full up kit it was $950!!! Not bad!
http://www.wired.com/gadgetlab/2009/08/makerbot/
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Aug 12, 2009, 07:55 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
interesting, but see the rough resolution... it's still challenging to use the process for small finely detailed parts.
I'd sure like to have a laser cutter at home though!
patmat2350 is offline Find More Posts by patmat2350
Old Aug 12, 2009, 04:57 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
I think we have a winner...
Got my parts today from Shapeways in the Netherlands. Hard to capture white parts in the photo, but they have all the same detail (and strata) as the PrintaPart parts, and similar plastic "hardness". Pricing was better, overseas purchase was easy with Paypal (not offered by PaP), and delivery was UPS with tracking, which only took a few days from the shipping notification (PaP used USPS Priority, which was fine).
Old Jun 19, 2010, 07:22 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Cowl Vents
Finally got around to ordering some 3D-printed cowl vents from my own design, for use on the 1:32 Foundation Franklin steam tug.
Exceeded my expectations!
These were ordered in a photo-polymer material, which means the process uses laser hardening of a liquid polymer. I've also ordered other parts (like the anchor) in SLS, which is Selective Laser Sintering... dry nylon powder is fused together in layers, which produces a slightly porous, gritty part. This photo-polymer process produces smoother, non-porous parts, but they need to be washed... a bit of the wet stuff leaves a tacky film on the parts, as-delivered.
These vents are sized to fit standard English sized brass tubing, with a small shoulder adapter. I'll build a base for the tubing to finish off the parts.
You just can't order anything anywhere that approaches this quality for these hard-to-build cowl vents. I'm happy.
Old Jun 19, 2010, 10:36 AM
osalvat is offline
Find More Posts by osalvat
osalvat's Avatar
Joined Sep 2007
how cool...how nice!, very impressive Pat.
man FF is getting top notch tech!
osalvat is offline Find More Posts by osalvat
Old Jun 19, 2010, 10:38 AM
osalvat is offline
osalvat's Avatar
Joined Sep 2007
...can't wait!
Old Jun 19, 2010, 12:32 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Wow,... Pat,
The resolution on those looks excellent.
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Jun 19, 2010, 03:55 PM
craig_c is online now
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
Makerbot's Cupcake 3d ABS plastic printer
craig_c is online now Find More Posts by craig_c
Old Jun 19, 2010, 04:16 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Interesting... but I found no detailed images of finished parts. Given that it's extruding blobs of molten plastic, I expect it will be pretty coarse. With the parts above, I get a smooth surface out of the box... and that's the real key to being able to use these methods for scale model parts.
Old Jun 19, 2010, 04:28 PM
caymin last is offline
Find More Posts by caymin last
So broke I can't pay attention
Naples FL USA
Joined Mar 2009
That's fantastic!
Yep! it's time for me to drag the big garbage can into my shop, and get rid of all my hobby tools ect. and maybe take up knitting with the wife.
caymin last is offline Find More Posts by caymin last
Old Nov 26, 2010, 03:04 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Check out this 1:9 scale pilot someone has listed at Shapeways:
http://www.shapeways.com/model/17027...9th_scale.html
3D figure modelers (in CAD!) have my respect... I can draw circles and boxes...
Gritty, yes.... not sure how to get around that. I think some modelers use a dip, but that will soften the details...
Old Nov 29, 2010, 07:04 AM
seegurke is offline
Find More Posts by seegurke
seegurke's Avatar
Joined Jul 2008
The vents are really impressive! I heard of the technologie but until now I didn't know that there are companies that make it availible for private use. Have to start some CAD-drawing in winter to test it.
There are two small questions left at the moment:
What material did you exactly ordered for the vents? Is it this one?
And did you try to paint and glue it already? The glossy surface makes me think about problems but may be for no reason.
seegurke is offline Find More Posts by seegurke
Old Nov 29, 2010, 07:56 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Yes, I used the "white detail" photopolymer. But in the future, I would use "strong white flexible", which is laser-sintered dry nylon powder. It is rougher, but stronger and with a higher heat deflection temperature. It also avoids the sticky surface that seems part of the photopolymer process.
I washed the parts in solvent and soap, and they were painted without problem.
Old Nov 29, 2010, 10:10 AM
seegurke is offline
seegurke's Avatar
Joined Jul 2008
Thanks!
