Old Jul 31, 2009, 03:17 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Question
Can you revive a dead LiPo cell?
Title of this thread was changed from
[Can LiPo battery be slow charged at 1/10C for 10 hours without harm]
using non-LiPo charger?
One dead cell in 3S LiPo was successfully revived using non-LiPo variable current charger at 1/10C for 10 hours. Cell termperature stayed within warm range. Only one dead cell was separately charged, not whole pack. Voltage was monitored during charge.
This method was used because LiPo balance charger rejected the dead cell and refused to charge, indicating too low voltage.
Now the LiPo balance charger has taken it over and charging it regular way.
During the experimental charge, the battery was placed in the mug for precaution.
If you have a dead cell, try it and report your result here so that we can judge whether it is acceptable method.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Jul 31, 2009, 03:42 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
No need to slow charge it. If one or more cells are below the threshold recongnised by your LiPo charger, they can often be brought above that threshold (somewhere around 3 volts, I think) by charging them at about 1C with a non-LiPo charger whilst constantly monitoring the voltage.
They should be switched to a LiPo charger as soon as the low cells are up to a voltage that the charger will accept. I think that leaving them for 10 hours -- even at 1/10C -- is asking for trouble.
By the way, what voltage were your dead cells showing?
abenn is offline Find More Posts by abenn
Old Jul 31, 2009, 06:00 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
hall whoo used to use a voltage clamp to charge his race ready LiPoly packs at 1/10 C all of the time. He no longer seems to be a member here but I believe Robynflyer knows how to get in touch with him.
Charles
Old Jul 31, 2009, 08:52 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Originally Posted by John Kim
Can LiPo battery be slow charged at 1/10C for 10 hours without harm using non-LiPo charger?
Charging LiPos at any rate for 10 hours without a voltage cut-off is not a safe practice. Suggesting that others do so is irresponsible.
If you want to resurrect an over discharged cell or pack, follow the procedure in post #2.
Bill
ebill3 is offline Find More Posts by ebill3
Old Aug 02, 2009, 04:19 AM
TheD is offline
Find More Posts by TheD
Joined Apr 2009
I had this problem with my 14.8V 2200mAh battery. It would only recognize 3 cells. I went ahead with a balance charge at 2.2 amps. This has brought the battery back up to voltage and the battery charger now recognizes (Turnigy 3e) 4 cells.
What damage could I have caused?
TheD is offline Find More Posts by TheD
Old Aug 02, 2009, 04:23 AM
nguyencuongaa is offline
Find More Posts by nguyencuongaa
Joined May 2008
Any Lithium Polymer (LiPo) battery with more than two cells should be balanced. A LiPo battery is composed of individual cells, and each cell can charge and discharge at different rates. Eventually, the difference will increase until it can harm the entire pack. When charging the pack, a balancer will set all the cells to the same voltage. By not having certain cells charged and discharged beyond their limits, the life of the entire LiPo pack is increased.
you can read more about Lipo battery here.
http://www.cuongnp.com
nguyencuongaa is offline Find More Posts by nguyencuongaa
Old Aug 03, 2009, 10:58 AM
John Kim is offline
Panorama City, CA
Joined Sep 2004
I think I caused unncessary commotion.
The dead cell I thought I revived did not hold charge.
My conclusion. When a cell in the pack shows 0 voltage, just discard it. Don't try to revive it. It is dead.
NiCd batteries revive after completely discharged. LiPo seems different.
Once discharged to zero, it does not revive. Finished.
Old Aug 03, 2009, 11:56 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
I agree with the cautions stated above.
That stated permanent death depends on a number of factors, not an unimportant one being YOUR willingness to take some risk. I have had cells discharge, and that was the end of it. No recovery possible.
I have a Hextronic 2S, almost new, I unfortunately was doing a discharge with light bulbs I forgot about and sent to zero. My fault completely.
I did the NiXX boost to 3v, then balance charged normally at 1/2C. It charged, balanced, puffed a little, and continues to function about as well as an identical mate. BUT, it ONLY has maybe 10-12 cycles since the incident and it is NOT a flogged lipo. I fully expect it to die early. I DO NOT advocate this behavior but am personally willing to accept the risk and watch that lipo very carefully.
flydiver is offline Find More Posts by flydiver
Old Aug 03, 2009, 01:56 PM
TheD is offline
Joined Apr 2009
Thanks man, thats really helpful. I worked out how to check on my balancer the voltage of each cell and all are holding a rather healthy voltage. The reason I was so concerned about this is that it's a second hand battery out of a 70mm F16 EDF I bought second hand, which when I took for it's maiden didn't have any power to fly.
I guess the cells had dropped to such a low voltage, one of them was just below the sensor threshold.
Old Aug 03, 2009, 04:39 PM
trex-dude is offline
Find More Posts by trex-dude
Joined Jul 2009
After the flight, I left my FMA 18C 2100 4S pack connected in
my EDF jet for about a week . Voltage got so low.
The TP 425 could not recharge the pack. My early version
cellpro 4S recognized only 2 cells and could not
charge it. I thought of throwing that dead pack
away. Then....
A friend of my brought life back to the pack
with his Cellpro 10S. Now The pack works fine.
trex-dude is offline Find More Posts by trex-dude
Old Aug 05, 2009, 03:00 AM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
I have found that if I accidentally render a cell or two on my 4s2200mAh lipos, then all I do is set it up on my triton 2 at 11.1V or 7.4 instead of the usual 14.4. I also attach a blinky balancer to it. Usually after about 5 minutes I'm able to get the cell revived. I then switch the charger back to 14.4V and charge normally.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jun 16, 2015, 10:59 PM
chetan0412 is offline
Find More Posts by chetan0412
Joined Jun 2015
same here... i have HRB battery and after 10 days of use my first cell get complete drained. my B6AC charger wont charge. showing error cell. what should i do ?
i am planning to give 3.7 V 2000 mA supply to particular cell so my charger recognize battery.
See video
HRB Battery issue (0 min 15 sec)
bcoz of one single cell problem my whole batter useless even i cant get 5000mA of flying time.
chetan0412 is offline Find More Posts by chetan0412
Old Jun 17, 2015, 02:42 AM
abenn is offline
Joined Jul 2004
Welcome to the forum chetan0412
How did only one cell get drained like that? Is the charger saying that cell is only 1.0v, and have you checked with a voltmeter to be sure it's not a problem with the connection to the charger?
You can try to bring the low cell up to 3.0 volts or thereabouts, so that your charger will recognise it, and then do a normal balance charge. But you must monitor it constantly while you do that, for the voltage can rise quite quickly.
No guarantee you'll have a good battery though, because the cell has been so low
Did your pack charge okay the first few times? If it's a new battery, and you don't know how one cell has got so low, maybe you should take it back for a replacement.
Old Jun 18, 2015, 12:04 AM
Joined Jun 2015
HRB dead cell
1. How did only one cell get drained like that? = i dont know i think i left my dron switch on over night. i bought HRB battery before 15 days it was working fine for some flight only. than after only this cell was draining fast compare to others (like only this cell was showing 1.9V and others 2 cell nearby 3.55V at the end of use). i have B6AC charge. and i use to charge all lipo battery by balance mode only.
2. Is the charger saying that cell is only 1.0v - Right it was showing only 0.5 to 1V now its shows 0.05V only. i tried with balance charge but only this weak cell i cant charge, even at .5 A 2Hrs its shows 0.05V only. so i think its dead.
3. You can try to bring the low cell up to 3.0 volts or thereabouts, - How?, I saw different post like charge battery by Nicad (i tried For 1.5 Hrs @ 0.9 A) But no luck,
After disconnecting battery from charger show 0.06V. so i am planning to charge only single cell by regulated 3-5V 0.5 (By 7805 voltage regulator with revere supply protection) A by external power supply. definatly i will keep my eyes on battery temperature.
4. No guarantee you'll have a good battery though, because the cell has been so low - Its HRB battery 5000 mA, 50C-55C
5. Did your pack charge okay the first few times? If it's a new battery, and you don't know how one cell has got so low, maybe you should take it back for a replacement. - Not possible i was using from 20 days. and seller is refusing to replace.
Old Jun 18, 2015, 02:25 AM
abenn is offline
Joined Jul 2004
If it was 0.06v then I think that cell has had it. Even if you can get its voltage back up, from its history it sounds like it was bad right from the start, so it may not be worth even trying.
Leaving your model switched on, even though it's "disarmed", will always drain a battery, for the electronics still draw a current while they're in the standby state. So you should get into the habit of unplugging immediately after a flight.
Also, if your battery was showing 3.55v per cell after the end of the flight it suggests that you're draining it too much. It's normally recommended that you time your flights so that you land when there's still at least 20% left in the battery. That should result in the cells showing about 3.70v when you check them after landing.
Question Can LiPo slow charged at 1/10C without harm? John Kim Radios 7 Jul 31, 2009 03:46 PM
Discussion Can I charge lipo's at 1/10C and leave it on marcwv Batteries and Chargers 9 Apr 06, 2007 04:22 PM
Need Method to Charge at 1/10C PLRDad Batteries and Chargers 2 Oct 14, 2005 12:17 PM
Can I charge a 2 cell 7.2 volt Kokam 1020 mah at 1.2 amps? I FO nut Batteries and Chargers 0 May 09, 2003 12:57 PM
Long Can 480 Motor Growl at 1/2 Throttle JDCochran Electric Plane Talk 8 Jul 30, 2002 04:14 PM
