here's a 15min battery at WOT that works great... hope it helps:
http://www.headsuprc.com/servlet/the...-35C-EZ/Detail |
United States, MO, Branson
Joined Jun 2011
removal of engine cap?
Hello thanks for all the help on this thread it has made the plane build much quicker and more enjoyable.
took the plane out taxied around for about 30 seconds getting the it all straitened out lined up hit full throttle and poof either the engine or the esc died. all that to say has anyone removed the front engine cap. I do not want to completely destroy the decal looking for the spot to cut a slit. would love to see a pic of the exact location to make my cut. thanks |
Joined Jun 2011
Joined Jun 2011
modification built for speed!
Hello
the esc being replaced flew the plane several times loved it! Now I'm ready to see what you guys have done to give it more speed and power. different esc? different motor? an esc with a higher pwm rate or is that even applicable today? is there a thread somewhere that already has some tried and true mods (I could not find any) already flyng with a 2200mah and 30c thanks again for all the help |
You have a whole lot of reading ahead of you........... http://www.rcgroups.com/forums/showthread.php?t=767759 Enjoy. This will answer any question you may have! |
Joined Jun 2011
great stuff
Joined Jun 2011
2 changes that will really make a difference!
after much much reading I found two changes that really made a huge difference and cost almost nothing!
1) A 2 blade prop 11/4.7 2) removing the weight in the battery compartment can complete two 360 aileron rolls before a stall while climbing strait up! wow what a difference! |
That sounds great! My only concern is if youre putting that 11x4.7 prop on the stock motor for an 800mm corsair, that motor won't last long...! But if you have an upgraded motor or the 1400mm corsair, then i take it back and say good job! In fact, if you have the 1400mm corsair, try putting a small mAh 4 cell in there (maybe 1800mAh if it will fit)... it will be a heat seeking missile!!! (but with a 4S batt you'd want to downsize the prop a bit too) |
Uuhhh....
The 11x4.7 will work just fine on that motor.... the stock 3-blade attached to it now is an 11x6. You are assured it won't tax the motor at all.
However. As regards the 1400mm Corsair - please go to either of those 2 threads to see what you will need for them, there. BTW, that one swings a 14" diameter prop. ..........And you will need a whole lot more than a "small mAh 4 cell" for her, too
| Thread Tools | |
| Article E-flite Blade CX2 All-in-One with Spektrum 2.4 GHz Radio System Review | Michael Heer | Coaxial Helicopters | 128 | Jul 31, 2011 08:52 AM |
| Discussion SIAP HL Art Tech 2.4 Corsair | GiusedtoBe | Electric Warbirds | 0 | May 08, 2009 03:44 PM |
| For Sale Art-tech 2.4 ghz 4 channel radio w/ receiver | Doby | Aircraft - General - Radio Equipment (FS/W) | 0 | Mar 11, 2009 02:11 PM |
| For Sale Art-tech 2.4 ghz 4 channel radio w/ receiver | Doby | Aircraft - General - Radio Equipment (FS/W) | 8 | Mar 07, 2009 10:17 PM |
| Discussion Art-Tech 2.4 Radio | Gordito Volador | Radios | 2 | Jan 05, 2009 07:36 PM |
