Old Jul 30, 2009, 09:37 AM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Dx6i Antenna mod
I had a few people ask me what I did to my RX. I removed stock 2 DBi ant. found small cap for end, drilled hole and installed a 8" Reverse SMA Bulkhead to U.FL pigtail connector. which gives me the use of wifi antennas of differant gains. I also can connect up a wifi booster ( http://www.hawkingtech.com/products/...=72&ProdID=187 ) in the antenna link which I can switch powers from 100mw to 500mw output. That runs off a seperate battery. Now I have a lot better range.
Martin
Martin Y is offline Find More Posts by Martin Y
Old Jul 30, 2009, 11:00 AM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
But you told us what you did to your TX.
How much better is your range? Did you actually measure it?
Miami Mike is offline Find More Posts by Miami Mike
Old Jul 30, 2009, 05:18 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
CONFIRMED... Had to wait for someone to help me. Distance is confirmed with DX6i in EU power mode, no booster using 9dbi patch with LOS of 5.85 kilometers (3.63 miles). This is with using a AR6200 dual system with one RX vertical other horiz. No glitching or fade outs. Moving airplane around. This is second test and I wanted to verify my ground test before posting. Range in air should be much better, if you want to go that far
Old Jul 30, 2009, 06:54 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
That's some nice range!!
So far I have tested my bog standard DX7 to not much under 2Km with a stock AR6200. I had not gear to test fading - but it was flying fine!!
Here is the Vid
Getting Lost - FPV Style!! (3 min 34 sec)
I will follow this thread with interest.
Cheers
-J
The_Mongrel is offline Find More Posts by The_Mongrel
Old Jul 30, 2009, 07:14 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Here is the Vid http://www.youtube.com/watch?v=BGB2GfT5D0U
Cheers
-J
Is there an/what is FCC number on the back of your DX7? Just wanting to check the fcc site on the power output
Old Jul 30, 2009, 08:25 PM
Joined Dec 2007
Martin,
there is a number that states...
IC 6157 A-BRWDAMT
And then our C-Tick sticker
Cheers
-J
Old Jul 30, 2009, 08:48 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Hi -J
All I could find on that model. Is output is 22.4dbm plus antenna gain. I think thats mor than US at 178mw
M
Old Jul 30, 2009, 09:46 PM
Dennis H. is offline
Find More Posts by Dennis H.
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Might have to try this mod
Dennis H. is offline Find More Posts by Dennis H.
Old Jul 30, 2009, 10:16 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
I'd be a little nervous about showing up at the flying field with a radio that's altered like that. Even if it's actually a perfectly legitimate and safe modification, there's no way for others to know that. If someone else who's flying at the same time you are has any sort of radio glitch, you can expect to get blamed for it.
Old Jul 30, 2009, 10:19 PM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Yes that true too.
Old Jul 31, 2009, 07:17 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
CONFIRMED... Distance is confirmed with DX6i in EU power mode, no booster using 9dbi patch with LOS of 5.85 kilometers (3.63 miles). This is with using a AR6200 dual system with one RX vertical other horiz. No glitching or fade outs. Moving airplane around.
Could you see you're plane that far?. Are you doing this mod for normal flying or for FPV.
I have taken my plane so high and far that for me it was just a little dot in the sky. Don't understand why someone would hack a perfectly good radio to get further distance when the stock setup works beyond what I am able to see and control.
freechip is offline Find More Posts by freechip
Old Jul 31, 2009, 08:57 AM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
[QUOTE=freechip]Could you see you're plane that far?. Are you doing this mod for normal flying or for FPV.
QUOTE]
Did it for FPV. It's just a simple antenna mod. I had seen some posts about guys breaking off and faulty antenna's. Also makes it easier to pack away and not snapping it off as stock can do.
Old Jul 31, 2009, 09:02 AM
Joined Dec 2007
Hi -J
M
That was the info I was given. The Aus version was more powerful than the USA version.
I just wish I could find it!!
ALSO... i have asked this elsewhere but no answer,
I need to run 6 servos... so do I use a BEC or an RX battery?
Cheers
-J
Old Jul 31, 2009, 09:19 AM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
I'd use a Rx battery. I only run 4 servo's and I'm switching to a seperate battery just in case motor one runs out (if i'm not watching time). You do have higher power, no fare.
Old Jul 31, 2009, 12:39 PM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Mongrel, it would be safer to run a separate battery for the Rx
Discussion Lama 2 - Mini Antenna Mod HoverDown3K Coaxial Helicopters 8 Feb 27, 2006 03:26 PM
Cool My Blade CP Hidden Antenna Mod (Picts) SpyHawkFPV Micro Helis 34 Aug 18, 2005 08:51 AM
Base Loaded Landing Gear.....Antenna Mod... Geoffrey109 Micro Helis 0 Dec 31, 2004 05:02 PM
Simple Antenna Mod! eMeNeX Micro Helis 27 Oct 13, 2004 01:00 PM
antenna mod / am I asking for trouble? captain crunch Parkflyers 1 Apr 25, 2002 09:10 AM
