Old Sep 13, 2001, 08:54 AM
climber is offline
Find More Posts by climber
Joined Sep 2001
APC electric props - Strong?
Hi there;
Do the new APC electric props have the
strength to withstand high revolutions?
I was thinking of using them to replace
my regular APC props on my Astro 15 (10
cell) and Astro 05 FAI (7 cell) airplanes
but worry they may lack the strength.
I was going to ask APC but couldn't find
a way to ask them directly from their website.
Craig
climber is offline Find More Posts by climber
Old Sep 13, 2001, 10:05 AM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
The APC Electric props are made for the type of application you mentioned. Just don't use them on "gas" engines.
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Sep 13, 2001, 12:52 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Craig
They'll do fine for the apps you are using. I've run their 12 x 10 E prop on 600 watts plus, for one example.
Don't confuse the regular E props with their Slowfly props though
The slowfly props come in some pretty large sizes, but definitely won't like up around 300 watts
Dereck
Dereck is offline Find More Posts by Dereck
Old Sep 13, 2001, 10:47 PM
guillaume is offline
Find More Posts by guillaume
Joined Sep 2001
I am using a Speed 400 motor on my "Fundango", wich of the APC props will give me the better performance the "E" series or the "Slow flyer" series ?
guillaume is offline Find More Posts by guillaume
Old Sep 14, 2001, 01:32 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Dereck
Good Call Dereck
I've spun the APC-E pylon props (4,7-5.5") upwards of 35,000 RPM on roughly 700W of power. No kabooms!! yet.
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Sep 17, 2001, 08:22 PM
Ron is offline
Ron
Find More Posts by Ron
Ron
Chilliwack B.C. Canada
Joined Nov 1999
I know of several planes that spin APC electric props 13 X 7 at over 9500 RPM. they stand up well. Havn't seen a failure yet, except when they strike the ground REALLY hard ( read crash )
Ron is offline Find More Posts by Ron
Old Sep 18, 2001, 02:04 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Re: APC electric props - Strong?
Absolutely. They can easily handle high revs. The "gas" props need to be stiffer to handle the explosions of torque that an internal combustion engine creates but electric power is very smooth.
As the revs get higher, balancing the prop becomes even more critical. The thin slow fly props are a little more susceptible to warping and aerodynamic imbalance. Finally, remember that a large diameter prop at high speed might go supersonic at the tips.
Rick.
rpage53 is offline Find More Posts by rpage53
Brittle APC electric props Paulus Power Systems 3 Apr 23, 2002 09:35 PM
APC electric props vs MAS electric props Rod Electric Plane Talk 11 Dec 01, 2001 07:26 AM
Using APC electric props on standard prop adapters Joe Elston Electric Plane Talk 4 Oct 17, 2001 09:39 AM
K prop & K eff for APC Electric Props (8x6)? BEC Electric Plane Talk 1 Jul 09, 2001 12:16 AM
How to make the new APC Electric props fit your adapter Joe Elston Electric Plane Talk 6 Jun 17, 2001 01:56 AM
