Espritmodel.com Heli Air
Old Jun 27, 2012, 05:07 AM
Australia, WA, Perth
Joined Jun 2009
Originally Posted by jussyjonny View Post
Thanks! Yeah, it wasn't too bad so I just patched it up. Had two great flights last night, tho still can't orient it in the sky very well. Happened into a high alpha maneuver by chance when using the 2200 (and a rock as ballast), was 20g lighter than the 3000mah batt
I fly only with 2250mah batteries and it does the high alpha at 70 or 80 degrees well. Several batteries makes the shorter flight times a non issue. Almost hovers vertically and would do if I removed the landing gear. Single nozzle might make it difficult to stop roll though. I did paint an off white strip on the bottom to help with orientation on my first one.
johnbone is offline Find More Posts by johnbone
Old Jun 28, 2012, 02:59 PM
eroeder's Avatar
United States, HI, Kailua
Joined Jan 2004
eroeder is offline Find More Posts by eroeder
Old Jul 01, 2012, 03:07 AM
Tape n' glue, Good as New!
Chilliwack, B.C. Canada
Joined Aug 2009
Ok, finally got some video… Sorry it's un-edited...but still pretty good I think! I have to say after eight flights that it was worth it, although the build was loooong! Tell me what you think, and what my estimated speed is. Thanks!
70mm Freewing F -- 35 w/ thrust vectoring (3 min 19 sec)
jussyjonny is offline Find More Posts by jussyjonny
Old Jul 01, 2012, 12:48 PM
Champlin, MN
Joined Feb 2010
Nice video. No retracts on yours? It sure is a lot of fun to fly isn't it.
ferch is offline Find More Posts by ferch
Old Jul 01, 2012, 02:21 PM
Joined Aug 2009
Yes, I put electric retracts in for the mains but left the nose gear mechanical, and to my surprise it's only collapsed once! (on the maiden of course!!) it will be replaced with a servoless electric one as soon as I get some cash.
Old Aug 12, 2012, 11:15 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Looking for a brand new fuselage only. Lee
capt soap is offline Find More Posts by capt soap
Old Aug 13, 2012, 09:42 AM
Wave off!!! Wave off!!!
Joined Aug 2011
Electric Retracts
Thats it! ... I have had it with these stock retracts.!!! I know a lot of you guys are putting electric retracts in this model. Can someone here please recommend some elec. retracts that are dependable and economical. If I have to get some e-flite elec. retracts than I will, but I would like a more economical option if it is available. Thanks guys.
zoomzoom7435 is offline Find More Posts by zoomzoom7435
Old Aug 13, 2012, 12:10 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
x-flight as a good set for a cheap price.
Old Aug 13, 2012, 06:28 PM
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
only bad item on this plane
Retracts, they do suck but if you come in on them like a feather they do work well. They cant handle a hard landing too many times, the retract will break.
Wargassm is offline Find More Posts by Wargassm
Old Aug 14, 2012, 07:48 PM
Joined Aug 2009
I use these...
http://www.hobbyking.com/hobbyking/s...5F18%5F8g.html
But for the price, I would recommend these
http://www.hobbyking.com/hobbyking/s...%5Fetc%5F.html
Never had a problem with anything I purchased from Hobby King so far
Old Aug 15, 2012, 07:07 PM
R&D experimental
Joined Apr 2012
F35 Lightning Freewing II thrust vectoring
Hey i just got the plane, maidened it, and had a problem with it.
-plane has all stock materials
-servos, motor, ESC, RX, TX, everything.
I got the plane off of BH and on my first maiden, the plane took off and it couldnt fly straight and level, it porpoised very violently and sometimes fliped over on itself, The CG shudnt be an issue becaiuse it has a designated battery spot on it. It landed fine but has anyone ever had an issue with this? it would be great to hear your opinions on this.
-THx RCE
Rcexperimental is offline Find More Posts by Rcexperimental
Old Aug 15, 2012, 09:41 PM
gilford, new hampshire, usa
Joined Nov 2003
Did you actually check where the CG was compared to where it is supposed to be according to the instructions?
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old Aug 16, 2012, 08:04 AM
Beancounter's Avatar
USA, MA, Sterling
Joined Sep 2009
Like he said actually check CG , turn of thrust vectoring until all trimmed out. Lastly check position of tv nosels mine was a bit (upthrust) and it made for one interesting flight. It also kept wanting to flip every time I gave it throttle.
Beancounter is offline Find More Posts by Beancounter
Old Aug 16, 2012, 03:25 PM
R&D experimental
Joined Apr 2012
Yeah mine just wanted to keep fliping downwards doesnt seem as if the TV nozzle is turned down.
Old Sep 10, 2012, 01:02 PM
Joined Dec 2010
Originally Posted by Rcexperimental View Post
I got the plane off of BH and on my first maiden, the plane took off and it couldnt fly straight ...
-THx RCE
** Who is BH ?
Bille
BilleFly is offline Find More Posts by BilleFly
Idea X-Flight EDF-55 F-22 w/Thrust Vectoring MidNiteCM Foamy EDFs 4 Feb 07, 2008 04:24 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
Video Mini-Raptor W/ thrust vectoring LLoo Electric Plane Talk 0 Aug 19, 2007 10:57 PM
Discussion Foamie EDF w/ thrust vectoring? Elvis48 Electric Warbirds 2 May 09, 2007 08:16 PM
Idea Mr. Boogies JSF F-35 with thrust vectoring tow Electric Ducted Fan Jet Talk 26 Jan 16, 2006 07:45 PM
