Old Aug 22, 2011, 08:16 PM
ferch is offline
Find More Posts by ferch
Champlin, MN
Joined Feb 2010
I've only got a little more than a dozen flights on mine. So far though I've had to replace the elevator hinges (I used the Robart #309 hinges, but I think the smaller #308 would have been better). I've always landed on a tar road. I had the front retract get stuck out (won't retract) on mine last week after I dorked a landing - haven't had time to fix it yet though so I'm not sure what's wrong with it. If you're more consistent than I am at your landings you might be ok if you've got a smoother runway.
I initially looked at doing the airframe only, since many have said the ESC, motor, and servos are pretty cheap. While it's not a bad idea, it's not that much cheaper so I decided to get the ARF and replace stuff as it dies. Motor and servos seem fine so far though. Got mine from hobbyzone.com - they are local to me so I save on shipping. They also carry the airframe only, but I think they're out of stock at the moment along with the ARF.
Get one of these - you won't regret it. Do replace the elevator hinges though. I read a lot of people that told me to and I didn't listen. It was just dumb luck that I didn't crash and noticed the hinges were busted.
ferch is offline Find More Posts by ferch
Old Aug 25, 2011, 09:32 PM
johnbone is offline
Find More Posts by johnbone
Australia, WA, Perth
Joined Jun 2009
Originally Posted by Eddie P View Post
If only we could rotate like that, on the takeoff, and let it fly off the ground vs. snap off when the elevator finally overcomes the poor main landing gear placement
Now I'm getting motivated to mod the gear, come to think of it...
On my last flight with this plane it lept up vertically from a grass take off and then of course stalled. I managed to salvage a sideways nose first landing with not too much damage. I already had electronic retracts fitted because I could never keep the front gear from collapsing when landing.
In the repair process I shortened the main struts by 5 mm and moved them forward by 20mm. I have yet to test it because I still have some other work to do on it but I expect improvement.
johnbone is offline Find More Posts by johnbone
Old Aug 26, 2011, 08:26 PM
gcase1944 is offline
Find More Posts by gcase1944
RC Retread
Green Valley, AZ
Joined Mar 2007
Stock Battery and Battery Compartment Dimensions
I am enjoying reading this thread. I am now anxiously awaiting the projected October delivery of the F-35 from Hobby-Lobby, especially since the retracts will be electrically operated.
I've collected battery recommendations from the forum and I want to order additional batteries, preferably with a C rating above 20. However, I would prefer not having to modify the battery compartment, but I will do so if necessary.
To help me narrow the choices, would someone please measure:
1. The stock battery
2. The battery compartment
Thanks for the help.
Jerry
gcase1944 is offline Find More Posts by gcase1944
Old Aug 26, 2011, 09:36 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Jerry, did HL say the f-35 will have electric retracts??? Good new's!
capt soap is offline Find More Posts by capt soap
Old Aug 26, 2011, 11:10 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
The battery cage is 48mm H x 37mm W x 160mm long.
For the F-35 vs the SU-34 they have a separator in the cage at 120mm to put the battery on one side and the RX on the other. You can put the RX above the battery cage and get a bigger battery and move it back slightly.
Because it was a floater I went with a 4S 3000mAh battery.
This take as long to mod as it does to put the battery in.
Pull the battery cage out from the model take out the separator and cut out the back to move the battery aft for CG if needed. While the cage is out you can velcro or tape the RX to the ceiling above the cage.
Remember they added a dead weight ball bearing in the nose to sell the tiny batteries that they had to unload.
Take the bearing out of the nose cone and increase your battery weight to balance.
Poly glue the cage back in place very lightly so that you can take the cage out again if need be.
I might try the new PZ15094 rotating retracts on the mains for this model and the PZ15090 on the nose.
Which retracts did you decide to go with for this model.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Aug 26, 2011, 11:16 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
I have a set of e-flite's from my p-47.....Repairing my jet right now. Lee
Old Aug 26, 2011, 11:53 PM
ferch is offline
Champlin, MN
Joined Feb 2010
Stock battery is about 100mm long, 35mm tall, and about 31mm thick. The stock battery is a 20C 2200mah.
I bought a 30C 2200mah GForce battery from valuehobby.com (pretty cheap and came with the Dean's already connected) that's about 105mm x 35mm x 33mm that easily fits. I wish I had bought a higher mah battery - the flight times are a bit short. I can't tell much difference between the 20 and 30C batteries. If I were to do it over I'd get a 20-25C battery with higher mah capacity.
Old Aug 27, 2011, 12:34 AM
RC Retread
Green Valley, AZ
Joined Mar 2007
Maxthrottle, thanks for the info. I was already prepared to pull the battery cage so that I install a Spektrum AR7610-receiver w/ remote and the smaller TM1100 telemetry unit (for monitoring the flight pack voltage) above it. I now use the larger telemetry unit in a 3D plane to avoid dead stick landings.
The new ARF, due by October, will have electric retracts installed.
Jerry
Old Aug 27, 2011, 12:38 AM
RC Retread
Green Valley, AZ
Joined Mar 2007
ferch,
Thank you for the measurements. With the battery cage measurements from Maxthrottle and your data, I should be able to pick out a good upgrade LIPO from the many that were mentioned in the earlier posts.
Jerry
Old Aug 27, 2011, 12:42 AM
RC Retread
Green Valley, AZ
Joined Mar 2007
capt soap,
Hobby-Lobby told me that the delay in the August shipment of the F-35 is due to a redesign of the ARF for electric retracts. It is expected no later than October. Now I really am excited about getting this plane.
Jerry
Old Aug 27, 2011, 12:45 AM
High Orbit.....
Joined Jun 2009
Curious where did HL announce that the October orders are coming with Servoless Retracts?
Old Aug 27, 2011, 01:30 AM
RC Retread
Green Valley, AZ
Joined Mar 2007
Maxthrottle,
Customer service at H-L told me verbally on the phone. I was inquiring about my order that was originally scheduled for mid-August and now won't arrive until October.
Jerry
Old Aug 27, 2011, 11:49 AM
High Orbit.....
Joined Jun 2009
Ok cool.
When you get them can you post pics and or dimensions of the retract that they used.
Curious if they had another one created in a smaller size for them or if they just dropped in the PZ15090 or 94.
Old Aug 27, 2011, 12:24 PM
ferch is offline
Champlin, MN
Joined Feb 2010
Originally Posted by gcase1944 View Post
ferch,
Jerry
If you find a good one post the link please - I think I need a higher capacity pack for this plane. It's so much fun and right as you get comfortable it seems like it's time to land.
Old Aug 27, 2011, 12:25 PM
ferch is offline
Champlin, MN
Joined Feb 2010
I hope the new servoless retracts will drop in to the retract mounts on the original airframe. If not, rats I'll have to get a new one...
Idea X-Flight EDF-55 F-22 w/Thrust Vectoring MidNiteCM Foamy EDFs 4 Feb 07, 2008 04:24 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
Video Mini-Raptor W/ thrust vectoring LLoo Electric Plane Talk 0 Aug 19, 2007 10:57 PM
Discussion Foamie EDF w/ thrust vectoring? Elvis48 Electric Warbirds 2 May 09, 2007 08:16 PM
Idea Mr. Boogies JSF F-35 with thrust vectoring tow Electric Ducted Fan Jet Talk 26 Jan 16, 2006 07:45 PM
