High Orbit.....
Joined Jun 2009
I might add the detail about removing any servos... the three units that I've seen thus far are all using Silicon adhesive to hold the servos inplace. They don't pull so easily but if you cut around the edges first, watch the wires, they come out no problem. Oh and re HL picking servo's.... HL doesn't make this model, Freewing does. HL are just the distributor. If they had as much influence on design as some believe I would think they would be able to give some accurate information on what they commissioned. We've been asking for infromation on the ESC's for more than a year and we still can't get a clear answer. |
High Orbit.....
Joined Jun 2009
Australia, WA, Perth
Joined Jun 2009
Don't ask me how I know. The AXN ESC is an opto ESC so has no BEC output. Still has the 3 wires but these are opto coupled isolating the power input from the ESC and motor circuits but you know this already I am sure.
High Orbit.....
Joined Jun 2009
How'd u know I was in IT . More questions. looking over the F35 is the 120mm CG right. Looking at the Centre of lift and the main gear placement it looks like this should be much further back. I'll stick those HK gyros on roll and pitch on the tailerons so even if its twitchy..... Other question: Since the TV is 60mm and the intake is so cavernous I'm wondering if an 80mm or 90mm might not be another way to get the lead out. Trying to find a lite 90mm unit or maybe the 80mm of the HL F16 which is also an 8 blade. It may be a new set of batteries, which I was hoping to avoid but ..... And I'm still in a wait and see on the on the sky units. What do you think |
High Orbit.....
Joined Jun 2009
Joined Jun 2009
no, I read a post where you talked about public domain stuff... so extrapolated from there.The COG is correct. I did have it slightly back from that but was not sure whether it was the elevators or the COG that made it backflip for a hairy flight. It is a bit twitchy with the elevators so dial in a bit of expo initially. I am sticking with the 70mm for the moment. I made a tube from over the rear of the EDF unit to the TV unit as per recent post and pic on this thread. That helped noticably. 80 or 90mm sounds interesting. I haven't done the maths on 85-90% FSA for either but if it calculates for 60mm then it sounds like a good idea to burn some money on. The extra weight could be balanced by the battery.
High Orbit.....
Joined Jun 2009
So far the 80mm from the F16 may not be the answer as one site had the unit putting out low numbers. I came across the Fury Fans which look like RCLanders with different motors http://www.shulmanaviation.com/shopexd.asp?id=218. But the wieght.... Unobtainium?????? So now I'm looking into the FW 3800Kv motor for these to see what it may do. All the best to you and your. |
Paris - France
Joined Jul 2008
I bought this fantastic Freewing F-35 and I am just finishing it. I have only a pitch TV and I got the same problem as Mike when mixing my TV on channel 6 with elevator channel 2 on my Futaba 6 EXAP 2,4Ghz. The channel 6 is the flap channel. I can center the TV when it's off, but when it's on it moves half the way in only one direction. Does anyone can explain me how to mix, or tell me what Futaba transmitter I need to improve and fix this problem? Anyway, if it does not work, I will block the TV as suggested in the thread and fly without it.... Thank's a lot |
Joined Dec 2009
I just flew mine for the first time today. My only other EDF was a GWS A-10 5 yrs ago which was anemic at best so I didn't expect much. Two batteries through it and haven't even turned on the high rates yet, let alone 2 axis TV. It's super responsive, and very controllable. At 1/3 throttle and low rates it looks about as real in the air as you can get! It has TONS of power. It doesn't have 1:1, but it's close. It also slows down much more than I would have expected. With the CG per plans just a minor pitch bobble and no roll off at full aft stick. The main gear are back very far (I assume to accomodate the retracts) so a gradual rotation and realistic liftoff are hard to get. It speeds up very quickly and springs into the air when ITS ready to fly. It can tend to slap down on landing for the same reason (hence the spring nose gear). There are a couple other threads from myself and others on this plane, but I'd highly recommend it (and that's from a guy who used to despise electrics & even more ducted fans).
My radio has a flap switch. If yours has a knob, then my description will not work. I set the flap trims both to 0% (set one, flip the flap switch, set the other). Now program a mix from CH2 (ele) Master to Ch5(flap) slave. Set it to 100%. Set the flap switch as the mix controller (up or down, your choice). Check the thrust line (look at the markings in the vector unit), use the flap trim to make it centered. Remember to copy the value for the other position of the flap switch. Once you trim the plane, you may need to re-center the TV unit by adjusting the flap trims once more. Does this help on your radio? Marcelo.- |
Paris - France
Joined Jul 2008
Hey Marcello
Thanks for your reply. I did exactly what you say. My flap channel is 6. The fact is that the TV is centered, but it would works only one way, only when pulling the stick, so it works half way but one side only from the center position as on the scheme. I tried to use other settings as to change the flap trim setting, but it only changes the zero of your servo and to center the TV the flap trim must be near the zero position as you said. I could change the position of the servo arm by unscrewing it to change the zero position on 50 to the flap trim and have the arm center on neutral position, but in this case it would move only half way each side. But to do that I need to unglue the servo from the foam and it seems very well glue. I don't want to get a big hole or to break the foam. |
Paris - France
Joined Jul 2008
I guess i can't do it with flaps channel because on real planes you always lower the flaps from neutral position and raise them from down position, so it works only half way from neutral postion. Exactly opposite from airbrakes. So I think I will never get all the way up to down from the servo with flaps channel. I need a radio with a channel allowing full mixing from full up to full down.
| Thread Tools | |
| Idea X-Flight EDF-55 F-22 w/Thrust Vectoring | MidNiteCM | Foamy EDFs | 4 | Feb 07, 2008 04:24 PM |
| Build Log Mig-35 Twin EDF w/ Thrust Vectoring | tailslide5_0 | Foamy EDFs | 23 | Aug 27, 2007 09:20 PM |
| Video Mini-Raptor W/ thrust vectoring | LLoo | Electric Plane Talk | 0 | Aug 19, 2007 10:57 PM |
| Discussion Foamie EDF w/ thrust vectoring? | Elvis48 | Electric Warbirds | 2 | May 09, 2007 08:16 PM |
| Idea Mr. Boogies JSF F-35 with thrust vectoring | tow | Electric Ducted Fan Jet Talk | 26 | Jan 16, 2006 07:45 PM |
