Old Jul 28, 2009, 05:30 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Keel Cooling
Most modern harbor tug's i have seen have an enclosed cooling system and radiators / keel coolers under the hull and so not have to draw water from around them to cool on board equipment before pumping it overboard once it has done its cooling job.
Seeing as I'm building a modern style harbor tug with a heavy duty pair of Z Drives, i thought i would have an attempt at producing a pair of keel coolers to fit under the hull.
This tug will be doing some heavy pushing and shoving, so I'm going to do an enclosed cooling system with the ESC's cooled and the motor's cooled via these keel coolers and a pump.
Using some brass and copper tube, I've produced these...
toesup is offline Find More Posts by toesup
Old Jul 28, 2009, 05:34 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
OOOOO, copper cores!!!
NEAT!!!
Aerominded is offline Find More Posts by Aerominded
Old Jul 28, 2009, 05:50 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
novel idea, complete with header tank as well?
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Jul 28, 2009, 05:52 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Yup Ghost, the smallest Nitro car tank i could find...
Old Jul 28, 2009, 05:55 PM
Joined Feb 2004
Are you threading your own end-caps or buying them ready made somewhere? (I have a displacement oiler and oil trap I need to make in the next week or two...
col_426 is offline
Find More Posts by col_426
from downunder Downunder
col_426's Avatar
Hobart, Tasmania, Australia
Joined Feb 2008
Very nice, you have been busy the last couple of months! It would be interesting to measure the temperature of the equipment with and without the cooling system to see how well it works compared to the normal "suck in in from the pond, and pump it out the side" approach. It will look impressive though, and that's what really counts .
Phillip
col_426 is offline Find More Posts by col_426
Old Jul 28, 2009, 06:05 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
I made them this morning Mr Aero...
Old Jul 28, 2009, 06:14 PM
Ghost 2501's Avatar
stoke on trent
whats driving the pump, seperate motor or is it PTO'd on the propshaft?
Old Jul 28, 2009, 06:28 PM
Tugboat Andy is offline
Find More Posts by Tugboat Andy
Joined Apr 2007
Hmmm - I seem to think that Toes showed us a nifty pump he had milled up a few months back..... I wonder....
Tugboat Andy is offline Find More Posts by Tugboat Andy
Old Jul 28, 2009, 07:21 PM
jeno is offline
Find More Posts by jeno
United States, ME, Bar Harbor
Joined Sep 2005
Most keel pipe systems use a circulating pump, like an automotive water pump. No pressure as such created. I'm willing to bet that your pipes would woke fine by convection alone. Simplify the system, and if that is insufficient add a pump later.
Hats off to you for replicating the system.
jeno is offline Find More Posts by jeno
Old Jul 28, 2009, 07:53 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
It looks really neat! But I am betting the usual 'suck and discharge' cooling would actually keep the components cooler than this enclosed system.
Kmot is offline Find More Posts by Kmot
Old Jul 28, 2009, 07:58 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I have seen, and considered something similar, but as a between component cooler.
So that the water would come into the boat, cool a component, dissapate heat
through the "keel cooler, then run through the next component, then overboard...
It's neat to see someone setting one up in any configuration.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jul 28, 2009, 08:45 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Each system will have a separate pump / motor Ghost and in to a common header tank... though i do like your idea of PTO from the prop shafts...
Old Jul 28, 2009, 09:44 PM
Joined Feb 2004
Of course an open system would be "cooler" but it isn't as "cool"
Old Jul 28, 2009, 09:59 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
That's Cool, Toes.
MILLERTIME is offline Find More Posts by MILLERTIME
